Dust proofing a Dual Cab
Submitted: Monday, Oct 31, 2011 at 23:28
Outnabout..
Getting close to the time to be updating and was thinking of possibly a dual cab with a canopy. What do owners do to stop dust getting into the tray as none of then seem to have a good seal on the tailgate.
Reply By: Member - Joe n Mel n kids (FNQ - Monday, Oct 31, 2011 at 23:46
forward facing vents as high as possible, i have seen them with "rain" traps on the work utes we used in
Darwin, not an ounce of dust came in as it pressurised the canopy, the rain trap stopped the
water in the rain, and heavy rain at that .... just like the snorkle tops that seperate the
water ...
468983
Reply By: Sand Man (SA) - Tuesday, Nov 01, 2011 at 07:08
I have an ARB canopy on my dual cab and fitted a vent (also from ARB) to the leading edge on the roof of the canopy. It's only small but boy does it work.
The vent can be fitted either front or back, as long as it's facing towards the front.
I fitted
mine to the front as I also employ a roof rack and cage when travelling and the vent sits just below the front cross rack.
The only dust that I notice now is a small amount along the bottom edge of the tailgate and I can easily live with that.
Perhaps with
cargo drawers fitted, the positive pressure is reduced along the bottom edge of the tailgate, but it is nothing of concern in my case.
From memory the vent was around $40.00 and is easily fitted either by yourself, or "in shop".
The vent can be closed and this is the way I leave it around town, but flipped up when off road and it works really
well to keep the tray area clean.
468986
Follow Up By: Member - John D, Wandong (Vic) - Tuesday, Nov 01, 2011 at 11:04
Have to agree with Sand Man, I had the vent fitted at the rear of my canopy when installed by ARB, and have had virtually no dust inside the canopy when travelling on dirt roads, the dust was also reduced from the bottom of tailgate when I built the false floor in the tray, see pic...
Image Could Not Be Found
Regards, John
743329
Reply By: Member - Stevo_62 - Tuesday, Nov 01, 2011 at 09:06
I have had 4 dual cab utes and always fit canopy with sliding window on front ( behind rear window of ute ) and when on dirt road leave the window slightly open ( 25 mm ) . This works the same as above solutions pressurising the canopy and keeps out nearly all dust .
468991
Follow Up By: louie the fly - Tuesday, Nov 01, 2011 at 19:48
We've just bought a Triton with a canopy and sliding front window. The dude we bought it off said exactly the same thing - leave the window open slightly. I've not tried it yet but have no doubt it will work.
743357
Reply By: Kimba10 - Tuesday, Nov 01, 2011 at 13:29
Had the vent as
well in
mine but must remember to close it if in heavy dust and following some one else other wise work
well. In regards to tail
gate I had 2 1.5m alloy plate made up approx 10cm wide and height from floor to top edges of utewell. Bit hard to describe and dont have any pictures handy at the moment but it ran vertical from floor up level with top of tailgate. I pop riveted one half to just inside where
gate closes and put rubber seal on the other half that is hanging out so when tailgate is shut it closes up against the rubber seal. Along the bottom of it I used a strip from bunnings that you put on the bottom of a door but it was like very light brush, I reckon it stopped 99% of dust coming up through
the gap on bottom of tailgate. never had any issues with the canopy itself with dust or
water entering the rear tray, was sealed down with rubber strip then I had 6 clamps, two on either sides and two up front pulling it down nice and firm but could take it off in 10 minutes if I wanted to use it as an open ute Definately one thing I miss with having a prado.........and dogs in the back of the ute is the best place for them when there wet and sandy........................just hose them and the ute out
469007
Reply By: Patrol22 - Wednesday, Nov 02, 2011 at 18:53
Those solutions work
well provided you don't travel in convoy for protracted periods on dirt roads and/or you don't fall into huuuuuuuuuuuuuuuge bulldust holes like I did. I've managed to seal the rear of my D40 using low density foam with sticky on one side. It has now been in place for 3 years and still holding up.
469080
Follow Up By: Fatso - Wednesday, Nov 02, 2011 at 19:37
Patrol22 you just reminded me of a bloke I met in
Alice Springs about 10 years ago. He was travelling in a Landrover Disco with the air on fresh air to pressurise the car & keep the dust out when he hit a massive bull dust hole. He reckoned he buried the nose into it & dust poured over the bonnet & got blown into the cab through the vents.
When we met them, a week or so after the event, they were still cleaning.
I remember he & his girlfriend had a good sense of humour & we & they had a good laugh when they told us the story.
743420
Reply By: luhuanhuan l - Saturday, Nov 26, 2011 at 17:33
This post has been read by the moderation team and has been moderated due to a breach of The Spamming Rule
Forum Moderation Team
471026
