Jayco Sterling Fridge
Submitted: Wednesday, Nov 02, 2011 at 19:51
Clint & Chell
Hi Guys,
Help please! We have just realised this afternoon that things in our freezer have defrosted and it appears as though the fridge is not as cold as it should be.
We are hooked up to 240v.
We are in
Darwin and have been for a while but things are obviously heating up, up here. But I would not have thought the freezer would be defrosting.
The van is in the sun all day.
We still have power as the a/c is going.
It is a 3 way Dometic Fridge/Freezer.
I have just cranked it up to max.
Thanks for your help guys
Clint
Reply By: Ozhumvee - Wednesday, Nov 02, 2011 at 20:04
Are you running it on gas or 240v, they usually struggle on 240v, more efficient on gas.
Most 3 way fridges as installed by caravan builders will struggle in warm weather.
They are rarely installed correctly to provide correct airflow at the rear, nor are they properly sealed to the internal of the van.
There should be a free flow of air in at the bottom of the fridge and out at the top, no obstructions and the air must be ducted so it flows over the fins at the rear of the fridge, not just past/behind them. That same hot air should also be prevented from accessing the space around the sides and top of the fridge or exiting into the van interior.
Many owners also fit a couple of computer fans to aid the airflow in hot weather.
There are also models specifically built for Oz conditions, not sure these days but they used to have a T (for tropical) in the model number.
469084
Reply By: Boris S - Wednesday, Nov 02, 2011 at 20:21
I am a refrigeration mechanic and i can say that the door seals play a MAJOR factor in efficiency. Check the seals for a tight fit, and make sure they are clean including the mating surface on the fridge body. The bottom corner of upright refrigerators are a common bad spot for door seals to fail as that is where gravity pushes most blood,softdrinks,and any other food, and it causes warpage of the seal. If the seals are good then airflow is the next thing to look at. Also, your 240v supply may have been interrupted and these 3way fridges take ages to get down to temperature, so patience is a must. Last thing is that the 240/12v element is cactus, in which case it will need replacing. On the odd occasion the actual sealed refrigeration system has failed, in which case it might mean a new refrigerator, all the best.
469085
Follow Up By: Clint & Chell - Wednesday, Nov 02, 2011 at 20:31
Thanks heaps for the feedback guys.
The weird thing is my missus put a few beers in the freezer for me at 3 o'clock for when I got home from work. They were straight from the box so they were not chilled at all.
At 6 oclock the beers were chilled, albeit starting to condensate (sweat up), but the ice block tray was defrosting and the fridge warm.
Weird!!!
743430
Reply By: 93maverick - Wednesday, Nov 02, 2011 at 21:02
Check the model of the fridge. It is found inside near the door. If it has a T after the model no. It should work to about 38`c. If not they often die after 33`c.
Try shielding the outside vents from the sun do not restrict the air flow above the vents. This may help. I fitted some computer fans to expel the hot air.
469087
Follow Up By: Clint & Chell - Wednesday, Nov 02, 2011 at 22:13
Thanks Maverick.
Unfortunately no T in the model number.
Have switched fridge over to gas and it has started to cool again. I am going to switch back to 240 and then monitor.
I am thinking that Boris might be onto something or it was just too bloody hot today :)
Thanks again for the feedback
Clint
743439
Follow Up By: Member - Barnray (NSW) - Thursday, Nov 03, 2011 at 07:53
If it is working on gas then it can only be a couple of things. The element or thermostat are U/S or there is no power to the fridge. barnray
743454
Reply By: landed eagle - Thursday, Nov 03, 2011 at 07:03
The fridge label inside the door will have a separate box which will be called 'climate class' . It should have a 'T' stamped in it. It won't be in the model number.
Depending on the age of the fridge I'm pretty sure that once the dometics get into the larger sizes (
mine's a 150L) they are all 'T' climate class regardless.
In 2009 I was in the
Sydney Goulburn area at this time of the year and it was a constant 38-40 degrees outside.
Mine was freezing stuff on a setting of 4! On 240V too.It works really
well.......maybe it's faulty. :)
469103
Follow Up By: ozjohn0 - Friday, Nov 04, 2011 at 11:56
With the newer models the 'T' starts with the 120lt model which if correctly installed should work up to an ambient temperature of 43c.
Note: If it's one of the 'modern' slimline models with the curved doors then it's only rated 'ST' and will give up the ghost
well before then.
Ozjohn.
743531
Reply By: aka - Thursday, Nov 03, 2011 at 08:56
Ours did the same in
Darwin 2 years ago there is a jayco agent who was in the
park at the time he replaced the element all good he also said to put a surge protecter on the plug .On another
forum I got told of for suggesting that
469110
Follow Up By: oldtrack123 - Thursday, Nov 03, 2011 at 17:10
Yes with good reason
Any competent electrician knows that your everyday surge protector, does not function below about 370v AND if it is subjected to an excess voltage for a length of time will itself burn out
THEY are made to absorb very short high voltage spikes not prolonged over voltage
The simple fact is that the current run of Dometic fridge elements are not really suited for what are the generally available supply voltages in AUS
THAT IS WHY THEY ARE GETTING A VERY BAD reputation for failure of the 240v element
743473
Reply By: deserter - Thursday, Nov 03, 2011 at 15:20
Common with fridges that aren't T rated.
469123
Reply By: Member -Dodger - Thursday, Nov 03, 2011 at 16:56
If it is cooling on gas then the problem more than likely will be the 240v element is on the way out and will need replacing.
469132
Reply By: oldtrack123 - Thursday, Nov 03, 2011 at 17:20
Hi Clint
The 240v element will either be working or burnt out Easy way to check is run it on 240v for an hour or so the see if the boiler @the back is very hot , if not you have THREE possabilities:
[1]It is not getting power, check the plug is in & switched "oN"
[2]Rotate the thermostat back a
forth it may be stuck
[3] the element has burnt out.
You should ALWAYS post the model number as there may be other possabilities
469134
