UHF 477mhz CB Aerial
I have a aerial stainless steel 1310 mm in length with a coil at the base How do I know if it is a UHF aerial.
The base I have is just the plastic base can you tell me what is required in the base to connect the aerial to and coax as I can make the connection if I know what is required and the length of the coax.
Reply By: sweetnam - Wednesday, Nov 16, 2011 at 08:16
It actually sounds like the top half of a HF aerial, the section that goes on top of an auto tune.
Is the thread hole at the bottom of the spring about 20mm wide?
Ben
AnswerID: 470142
Reply By: vk1dx - Wednesday, Nov 16, 2011 at 09:06
It may be easier for us to identify it if you can post up some photos.
AnswerID: 470146
Reply By: wombat100 - Wednesday, Nov 16, 2011 at 11:17
Sounds like an old 27mHz CB....
AnswerID: 470152
Reply By: gregrae - Wednesday, Nov 16, 2011 at 13:11
how do I go about posting photos on the post
AnswerID: 470163
Follow Up By: Robin Miller - Wednesday, Nov 16, 2011 at 13:54
If it has a 1310mm length of unbroken stainless steel then its not a uhf Greg.
Possibly a 5/8 amateur 2m whip as they use about 1300mm with small base coil.
When you post or reply their appears some options at the bottom of your text entry window - you should have an option titled Insert Image.
FollowupID: 744622
