12v power
I have an engle 40l. Which I have been running as a freezer when free camping.
I also have a thumper 75a/h battery and an 80w solar panel.
The problem is that battery is not lasting as long as I would have expected. It sometimes Runs overnight.
I also have the feeling that the solar panel is not fully charging the battery during the day.
Could anyone shed some light on this problem, and any solutions.
Regards.
Reply By: Rangiephil - Friday, Nov 18, 2011 at 14:36
If you run an Engel as a freezer I would expect it to use more power than your 80W panel provides.
Remember an 80W panel wiill only charge at full belt for about 4 hours say 80X4 = 320 Watts = 25Amps plus say another 10=35 Amp hours MAXIMUM
The Engel will take probably 2amps x 18hours at say 66% duty cycle 36amp hours
Just a quick calculation shows that you are pretty borderline and any cloud or inefficiency of the panel will mean far less generation, and a hot night more usage.
Check the state of the battery at say 4PM and see if it is fully charged at 12.7-8 volts
I am currently looking at buying a panel and I would only get a 120watt panel using the Engel as a fridge only.
Regards Philip A
AnswerID: 470345
Follow Up By: Rangiephil - Friday, Nov 18, 2011 at 14:41
Also check how many minutes in each hour the Engel is running to give you an idea of duty cycle. It could be way above 66% in hot weather as a freezer.
Regards Philip A
FollowupID: 744811
Follow Up By: olcoolone - Friday, Nov 18, 2011 at 18:49
Phillip you have hit the nail on the head..... our Waeco 60 liter that's only meant to use .85 amps per hour uses 3.5 amps per hour when set to -18deg C at 25deg C ambiant...... so over a 24hr period it uses 84 amp hours.
An Engle uses a far bit more then a Waeco so I think your on the right track.
Our figures were obtained using a data logger.
FollowupID: 744828
Follow Up By: paulnsw - Saturday, Nov 19, 2011 at 13:29
olcoolone "An Engle (Engel) uses a far(fair) bit more then a Waeco"
size for size, the difference between Waeco and Engel is minimal enough to say they are the same. Insulation makes the difference. Engel and Waeco are not suitable for use as freezers.
FollowupID: 744885
Reply By: Battery Value Pty Ltd - Friday, Nov 18, 2011 at 14:52
Hi Bob,
possible causes are:
battery having lost part of its rated capacity due to long storage.
Try the following remedy: connect your solar panel to it without any regulator and let the panel charge it for a whole day.
Another cause could be a sub standard solar regulator, such as the ones which come with folding solar panels.
These can cause the battery to be under-charged, especially if some load is connected during charging.
None of these el cheapo regulators offer multistage charging, which is so important in a cyclic battery application (cyclic means discharging at night, charging during the day).
If you succeed in getting sufficient capacity back into your battery by the method above, the next step is to invest in a suitable multistage solar regulator - ideally MPPT which can make available about 20% more solar power from the same panel.
The solar regulator also should have battery temperature compensation (with a sensor) to prevent accelerated battery aging in summer and sulphation in winter (sulphation is a gradual and mostly permanent loss of battery capacity).
Just in case your battery is beyond repair, get a new battery and charging gear - in a perfectly matched combination from someone who's doing both (stops the guessing and blame game if something fails within the system).
cheers, Peter
AnswerID: 470347
Follow Up By: paulnsw - Saturday, Nov 19, 2011 at 13:21
"ideally MPPT which can make available about 20% more solar power from the same panel"
under correct conditions and circumstances. Cheap MPPT regulators are generally more inefficient than quality PWM controllers. Under 300W+ solar panel capacity PWM is better. Adding more panel capacity is better option than MPPT in most circumstances.
FollowupID: 744884
Follow Up By: Lex M - Saturday, Nov 19, 2011 at 21:29
"Under 300W+ solar panel capacity PWM is better."
RUBBISH!!!!
FollowupID: 744935
Follow Up By: Member - Gordon T (NSW) - Saturday, Nov 19, 2011 at 23:09
Can somebody suggest please - without crossing swords with each other - what might be a suitable MPPT for a 160w (2 x 80) solar panel? Thanks.
FollowupID: 744944
Reply By: ross - Friday, Nov 18, 2011 at 17:13
What do you need to be kept frozen?
It all gets much easier when you take along foods that dont need freezing or vacuum packed foods.
AnswerID: 470361
Follow Up By: Member -Dodger - Friday, Nov 18, 2011 at 17:24
Vacum packed foods at fridge temps can last more than 5 weeks.
so why bother freezing food?
Cheers Dodg.
FollowupID: 744823
Follow Up By: paulnsw - Saturday, Nov 19, 2011 at 13:35
"Vacum (Vacuum) packed foods at fridge temps can last more than 5 weeks" a FEW vacuum packed foods can stay safe for 5 weeks PROVIDED the vacuum packing is done on a machine up to commercial standards. Fridge temperatures are critical and need to be maintained in the main at 3C and below. Food poisoning kills and can kill quickly. Been in a remote area taking chances with food storage
FollowupID: 744886
Follow Up By: ross - Saturday, Nov 19, 2011 at 21:52
The overwhelming majority of people that get food poisoning get it from bad hygene at the preparation stage.eg hands not being washed or food left out of the fridge for too long.
Im getting a sense that you have a fixation about food temperature that is not really relevant to most people standards.
FollowupID: 744937
Reply By: Goldmad - Friday, Nov 18, 2011 at 17:23
Hi. I run a 80lt as a freezer and a 40 lt as a fridge. I will turn my 80lt back to about 2-3
overnight. The temp will drop back from about -17 to -8 overnight in the morning when the sun is up I crank it back up.If a cloudy day I will also ease it back
Cheers Brian
AnswerID: 470362
Follow Up By: Lesley & David P - Friday, Nov 18, 2011 at 17:55
G'day,and we are new to this forum but have been on the road for over 4 years now so pretty much been there and done that.We have a engel freezer fridge as well and what we do is when travelling have it going full bore on 12 vault while on the move and for about an hour or so after we stop.We then turn the freezer off all together and if you have a cover for it you will find every thing is still good next day.We then wait a couple of hours then turn it back on and with the solar panels etc we have never been caught out with food spoils.If you do not have a zip cover for it then a a blanket or towel anything like that will do to help keep the cold in.
FollowupID: 744825
Reply By: ABR - SIDEWINDER - Friday, Nov 18, 2011 at 17:58
Hi Bob
I did a newsletter a while back on how to test your battery capacity.
Here is the link: Capacity-Test
Derek from ABR
AnswerID: 470364
Reply By: Member Andys Adventures - Friday, Nov 18, 2011 at 18:25
Hi Bob48, I have 2 engel 40 lts one as a fridge and one as a freezer, I have 2/80w solar panel's and find that if you turn the fridge on to cool and the freezer down to 3 it lasts all night. The battery will be low in charge but they still work. If I'm camped up for awhile then I use the car to charge for the first 15 min in the morning and turn the freezer up to full. Again I only open it a couple of times a day. Hope this helps
AnswerID: 470367
Reply By: The Bantam - Friday, Nov 18, 2011 at 19:25
This seems to be a re-occuring theme......and across several forums.
There is a vast difference between running portable refrigerators as fridges and freezers.
Running as a freezer at -15C, the same unit will pull 4 times or more as much average power that it would under the same circumstances running as a fridge at +2 or 3C.
As you wind the temperature down you get a double whammy.
the cooling looses due to transmission thru the insulation dramaticaly escilate, that combines with the refrigeration efficiency dropping massivly.
In some situations and some fridges the refrigeration system may not even be able to achieve the target temperature.
for example
If a fridge system has a maximum temperature difference of 45deg C (that is the maximum difference it is capable of producuing between outside and inside the fridge) on a 35C day the fridge is only capable of producing -10C inside the fridge, and then incredibly inefficiently.......set at -15C the example above would run continuosly and still not keep up.
The same unit running at +2C will be capable of achieving its goal temp and its efficiency will massivly better.
Its all about temperture difference......its like trying to fill a bucket with a hole in it.
Forget any published average power consumption figures you may have......they will be optomistic at best.
Rely only on the current consumption figures while the motor is running ( often listed as the maximum current draw)....the duty cycle ( how long the motor runs and how long it is off) will vary wildly depending on circumstance....freezers will run for hour after hour after hour
While most of these compressor bassed portable fridges WILL freeze and produce ice, they are primarily designed as fridges.
The bottom line is realy think serioulsy ..do you realy need to be running a freezer.
There are alternatives, like vac packing.
The other issue is that people have very much over optimistic expectations of solar panels..........Solar panels will only produce their rated output in the highest radiation parts of the country and only in the height of summer and only during the middle of the day.........In some situations the panel may average as little as 20% of its rated ouput over over the daylight day.
If you are running on solar panels...unless you have sufficinet output to fully charge the battery during the day and early in the day.....fiddling with the temp is completly pointless.....because all you are doing is robbing peter to pay paul.
remember the maximum safe temperatures are +5C for a fridge and -15C for a freezer.........If you can not maintain those temperatures realy think about it.
And most beer educated drinkers will think a +5C beer is warm..some goes for anybody who likes any type of COLD drink......+2C is tolerable.
AnswerID: 470369
Reply By: Bob48 - Friday, Nov 18, 2011 at 21:30
Thanks for all the info.
I forgot to mention that also run a two zone on top of the engle. Seems to work ok when battery power is sufficient, I dont think that the manufacturers claims of no extra power consumption are in fact correct.
I have also fitted a low voltage cut off switch to the fridge to stop running batteries down too low.
Any further feedback will be greatly appreciated.
AnswerID: 470379
Reply By: paulnsw - Saturday, Nov 19, 2011 at 13:18
This is the power consumption of your Engel 40L
25C +5C 24% run time .54Ah/Hr 12.96A/24Hr
35C +5C 47% run time 1.14Ah/Hr 27.36A/24Hr
45C +5C 78% run time 1.92Ah/Hr 46.08A/24Hr
25C -5C 52% run time 1.18Ah/Hr 28.32A/24Hr
35C -5C 76% run time 1.75Ah/Hr 42.00A/24Hr
45C -5C 100% run time 2.32Ah/Hr 55.68A/24Hr
25C -18C 87% run time 1.96Ah/Hr 47.04A/24Hr
35C -13C 100% run time 2.25Ah/Hr 54.00A/24Hr
45C -1C 100% run time 2.35Ah/Hr 56.40A/24Hr
Take note of the 100% run time where the compressor never switches off.
Figures courtesy Sunwires.
All portable fridges regardless of compressor brand for the same size physical unit use the same power consumption to achieve the same outcome. If you take a Waeco with the Danfoss compressor or the Engel with the Sawa Fuji compressor, using the same fridge, the power consumption of both will be close to identical. Where the difference comes in is in cabinet quality, seals and insulation.
Many here should take a chill pill especially when it comes to making ridiculous and ludicrous claims.
AnswerID: 470410
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 14:31
HI Paul
Perhaps you could quote which model ENGEL only draws 2.35Amps when running??
You do have a problem with with those figures
Perhaps you should have another look!!!
FollowupID: 744892
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 14:36
These figs are far more correct
"olcoolone posted:
Our figures were obtained using a data logger. [end quote ]
FollowupID: 744893
Follow Up By: paulnsw - Saturday, Nov 19, 2011 at 15:55
This post has been read by the moderation team and has been moderated due to a breach of The Personal Attacks Rule .
Forum Moderation Team
FollowupID: 744898
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 17:07
HI Paul
QuoteFollowupID: 744898 Submitted: Saturday, Nov 19, 2011 at 14:55
paulnsw posted:
The Engel power consumption figures are certified from the Sawafuji Electric Co. Ltd
only an ignorant inept incompetent fool would dispute those figures
a blind person could see they are correctEnd quote ]
YES,
I wonder WHO the blind fool is Who does not understand what he is reading??
Anyone who has checked the current draw of these fridges KNOWS they draw 3.5<4amps when running 3.5amps by24hrs [100% duty cycle ]=84AMPHRS
ANYONE WHO UNDERSTANDS the figs posted by most portable frig makers represents the average daily use as a fridge @
2.5 ampshrs per hour is typical for that @ a set ambient temp[about 25c]
You need to get some practical experience my friend ,it will help !!
"olcoolone" posted actual factul figures which illustrate just how wrong you are!!
THOSE figs are TRUELY representive of such fridges@ that ambient
BEST get your facts RIGHT before you lead people astray
FollowupID: 744902
Follow Up By: paulnsw - Saturday, Nov 19, 2011 at 17:23
FollowupID: 744903
Follow Up By: Dennis Ellery - Saturday, Nov 19, 2011 at 17:32
Hi Paulnsw – Thanks for the figures.
I have both an Engel and a similar size Waeco – they don’t vary much in power consumption - when tested on 250 volt (I don’t have a dc kWh meter).
There is a lot chaff with the wheat on this thread and quoting facts and figures will only confuse them.
FollowupID: 744906
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 17:40
HI Paul
Like many of your ilk you are only digging yourself in deeper
& resort to personal abuse to cover your lack of knowledge.
YOU obviously do not have ANY pratical experience OR even have clue
Engel SWING motors have ONE speed
DO you even KNOW what type of motor the ENEL SWING motor is?
Waeco's are a multi speed motor & on boost draw < 7amps
Again the figures quoted in literature are AVERAGE AMPHRS PER HOUR used as a FRIDGE
AS many have found out when they seriously under estimated their power requirements
"olcoolone"
Posted factual figures ,he stated that ACTUAL recorded conditions
Are you suggesting he too does not know what he is doing or talking about??
Sorry but every post you make shows how little you realy know!
FollowupID: 744907
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 17:52
Hi Dennis
Before you accept Paul's figures I suggest you do a simple amp meter current draw test on 12v
You WILL SEE that an Engel draws 3.5<4amps when running
3.5amps @ 100% duty cycle is 84amphrs per day
3.5amps@ 50% duty cycle is 42amphrs per day
3.5amps @ 25% uty cycle is 21 amphrs per day
This IS something the proponentsof compressor fridges seriously underestimate much to their sorrow
FollowupID: 744909
Follow Up By: paulnsw - Saturday, Nov 19, 2011 at 17:53
FollowupID: 744910
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 18:18
Hi Paul
Again paul you are good with the personal attacks
I guess that does show the type you are
To all others I strongly suggest you disregard this person's posts
He is obvously a troll with little practical knowledge
What I & "olcoolone have posted can be easily verified by anyone with a dc ampmeter
Anyone who has a Waeco,I am sure,will have heard it go to high speed[boost] when the need is there for more cooling capacity.THAT HIGHER SPEED MEANS IT IS DOING MORE WORK
THAT MEANS IT WILL DRAW MORE AMPS
The <7amps is a max but in boost [high speed] it will be higher than normal
I have not checked the actual figures myself
The Engel has a current draw when running of 3.5<4amps on12v
That depends a little on the voltage @ it's terminals
The actual run time WILL give the ACTUAL amphrs used per 24hrs
IT WILL BE MUCH HIGHER THAN MANY EXPECT
PERHAPS Paul with so much to say could posts SOME ACTUAL FIGURES FROM HIS OWN TESTS IF he can???
I also note You did not answer about the Engel motor !!
OR IS HE JUST A READER with no pratical experience??
Can't you find THAT in your readings
YEP continue to dig a deep hole!!
FollowupID: 744911
Follow Up By: paulnsw - Saturday, Nov 19, 2011 at 18:31
FollowupID: 744914
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 18:37
Hi All
I think I understand, Paul is a desk boffin with no practical experience & little knowledge of what he is reading actually means,
WHAT ARE YOUR TRUE qualifications?
Of course the figs posted by CO's must be CORRECT, For the condition under which they were obtained
Perhaps PAUL has a serious problem in that area??
AS I have said to all who are now totally confused, if you have a multi meter & know how to use it do a simple check of the current draw of your fridge
Then estimate or keep a check on how many hrs per day the fridge will actually run
multiply your meter reading by the ACTUAL run time over24hrs & you have the AMPhrs used in that 24hrs
From that you can see how long your battery may last if @ its full rated AMPHR capacity
If anyone other than Paul wishes to discuss the matter further in a civil manner I will only be happy to oblige
Paul
I will have no more direct conversations with you , but be very careful of the rubbish you post.
It will not go unchallenged
FollowupID: 744915
Follow Up By: paulnsw - Saturday, Nov 19, 2011 at 18:46
FollowupID: 744918
Follow Up By: ModSquad - Saturday, Nov 19, 2011 at 19:19
Guys,
The tone of your postings above are unacceptable and any future posts in a similiar fashion will be moderated accordingly.
The mod team
Moderation is just rules
FollowupID: 744923
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 19:57
HI ALL
Now for the CORRECT figures in Paul's post
paulnsw replied:
"25C +5C 24% run time .54Ah/Hr 12.96A/24Hr " should be 3.5amps x by 24% dutycycle=20.16amphrs per 24hrs
"35C +5C 47% run time 1.14Ah/Hr 27.36A/24Hr " should be 3.5amps x 47% duty cycle =39.48amphrs per 24hrs
"45C +5C 78% run time 1.92Ah/Hr 46.08A/24Hr " should be3.5amps x 78% duty cycle=65.52 amphrs per 24hrst
"25C -5C 52% run time 1.18Ah/Hr 28.32A/24Hr" should be 3.5amps x52% duty cycle=43.68amphrs per 24hrs
"35C -5C 76% run time 1.75Ah/Hr 42.00A/24Hr " should be 3.5amps x76% duty cycle =63.84 amp hrs per 24hrs
"45C -5C 100% run time 2.32Ah/Hr 55.68A/24Hr " should be 3.5amps x 100%duty cycle =84amphrs per 24hrs
"25C -18C 87% run time 1.96Ah/Hr 47.04A/24Hr " should be 3.5amps x87% duty cycle =73.08amphrs per 24hrs
"35C -13C 100% run time 2.25Ah/Hr 54.00A/24Hr "Should be 3.5amps x100% duty cycle =84amphrs per 24hrs
"45C -1C 100% run time 2.35Ah/Hr 56.40A/24Hr " should be 3.5amps x100% duty cycle =84amp hrs per 24 hrs
I will leave it to all of you to determine the worth of some of the other posts by Paul
figures courtesy Sunwires ???????
FollowupID: 744925
Follow Up By: paulnsw - Saturday, Nov 19, 2011 at 20:09
FollowupID: 744926
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 20:54
Hi All
Another way to check just what your Engel draws while running is to read the wattage on the name plate for 12v operation
Divide that by 12 & you have the current that it will draw while running
You can then do your own calculations based on different running times
But bear in mind run times will vary with thermo settings ,ambient temp,
warm loading, frequency of door opening etc BUT the current when running will remain the same with an Engel
The same constant current does not apply to Waecos as they do have a variable speed motor
The current they draw will depend on the motor speed @that point in time!
FollowupID: 744931
Reply By: Member -Dodger - Saturday, Nov 19, 2011 at 22:46
When I run my Engel off the van battery it consumes 4amps on start up quickly dropping to 3amps after about 1 minute.
The van has a battery monitor that shows what is being used in amps.
The fridge is set at 2% Cel which means it roughly cycles on at 4% C and off at 1%c.
This engel was purchased in 1995 and hasn't missed a beat since.
Cheers Dodg.
AnswerID: 470453
Follow Up By: oldtrack123 - Saturday, Nov 19, 2011 at 23:49
Hi Dodge
Thanks for your post
So even your fridge will use 72amphrs @ 100% duty cycle in 24hrs
You can just substitute 3amps for the 3.5 ,to to see what yours will use over 24hrs @ different duty cycles.
At that age it may have loosened up a liitle or the voltage @ the fridge may be on the low side
That does make a difference[lower volltage =lower current] Have you checked the name plate of yours for rated 12v wattage?
FollowupID: 744946
Follow Up By: Member -Dodger - Sunday, Nov 20, 2011 at 10:38
Peter we never use this fridge as a freezer so the 100% cycle for us does not come into it. From my observations when traveling with ambient temp around 30C it cycles about every 15 minutes if it is not opened.
We rarely freeze anything as the van fridge freezer works pretty well.
All our meat etc is cryovaced and lives in the engel with the beer.
Also when stopped I immediately hook up the 120 watt solar panel to the system and this takes over until dark. Any fish we catch is filleted cryovaced and goes into the engel also. In over 15 years we have never had a battery problem as the Patrol has a dual battery system and the van also has it's own battery system. Voltage at fridge is around 12.7v so i'm happy. Sometimes higher when the solar is at it's best.
Cheers Dodg.
FollowupID: 744970
Follow Up By: oldtrack123 - Sunday, Nov 20, 2011 at 12:29
HI Dodge
My post was just an indication of what such a fridge would draw if running@ 100% duty cycle,72anphrs per 24hrs not the 54 + amphrs submitted by Paul @100% duty cycle
To calculate duty cycle one also needs to know just how long the "ON" & "off periods are Or how long the fridge ACTAUALLY RUNS IN TOTAL IN 24HRS
12.7v AT THE FRIDGE is a good voltage for these fridges to run on, but your current draw is a little below what most draw, but nothing to be concerned about
It could be due to a number of factors.
FollowupID: 744987
Reply By: Ross M - Sunday, Nov 20, 2011 at 23:05
Lots of talk and good advice but the original question was about "it doesn't charge up fully"
One commonly often overlooked fact with energy coming from a solar panel is the voltage drop between the panel and the charge controller and batter/ies.
All too often this wiring causes a voltage loss because of resistance in the wiring, eg to thin.
Even a very small amount of resistance ( voltage drop) in the wiring (positive and negative wires to the reg and to batt, greatly affects the performance and total energy which can reach the battery.
Yes the Texans are right. Bigger is better in wiring in a solar charge system.
Most people have too small a cables and therefore lose a lot of efficiency.
Battery doesn't charge fully as a result.
I agree with one comment which said the system in question is hardly up to the challenge. More watts, bigger store battery and suitable wiring and things will improve. But it costs money. Please check the wiring size before upgrading anything.
Ross M
AnswerID: 470526
Reply By: oldtrack123 - Monday, Nov 21, 2011 at 00:05
Hi Bob
Back to your problem
[quote[1]..I have an engle 40l. Which I have been running as a freezer when free camping.
[2]I also have a thumper 75a/h battery and an 80w solar panel.
[3]The problem is that battery is not lasting as long as I would have expected. It sometimes Runs overnight.
[4]I also have the feeling that the solar panel is not fully charging the battery during the day.
Regards. end quote
[1] the figures I have posted above give a range of power reqs for differnt conditions
At the very best with the thermo set to any degree of freezing you will probably be using 50plus amphrs per 24hrs
[2]Your 75 amphr battery should not be discharged below about 50% capacity for long life
50% 0f 75 =37.5 amp hrs over 24hrs
[3]as you can see in any one 24hr period [without any charging input] you will have taken the battery below its recommened level just running the fridge Any other loads [lights ,tv etc will further worsen the problem
[4] your 80watt solar working @ it's very best will only replace about 25amp hrs of that used capacity
AS you can see you are going backwards very fast
YOU are taking out 50amphrs & only replacing 25anphrs
Yoare going backwards @ the rate of25amphrs per day
IF you 75 amphr battery is healthy & fully charged it will only last a little over 24hrsbefore it is below the rcommended level
What can you do
Options
Turn the thermostat to the warmest acceptable level.
add what ever you can as extra insulation,
but do not block any of the fridges ventilation areas
But those will only have a minor effect.
YOU need more means of charging
solar panels, generator,
To run an Engel or Waeco as a freezer [but not at max deep freeze] you do need at least 200watts of solar& they need to be in full sun for a min of 6hrs per day
You also need overnight & poor weather battery backup again around 200amp hrs, even that it is an absolute mIn INMHO
You will get caught @ times
People often under estimate or are mislead on the power requirements of compressor fridges
Many choose to remain with 3ways for this reaon, running on gas when away from mains power
GIVE the above some thought ,if any further questions just come back
AnswerID: 470528
Follow Up By: Bob48 - Monday, Nov 21, 2011 at 11:41
Oldtrack123,
Thanks for your imput and figures, this has backed up my feelings,
I will have to make a few decisions now regarding the way I run my system.
Thanks again, have enjoyed all the barter on this subject.
Regards Bob
FollowupID: 745051
