Nappy sand for use in Porta Potti
Submitted: Saturday, Dec 10, 2011 at 20:22
ThreadID: 90579 Views:4152 Replies:4 FollowUps:5
I read a while ago about using nappy sand & eucalyptus oil in a porta potti . Could someone tell the quantities please.
Thanks Julie
Reply By: Shaker - Saturday, Dec 10, 2011 at 20:31
I don't know the ratio for the mix, but if you try searching for 'Napisan' you may have more luck.
AnswerID: 472184
Reply By: Motherhen - Saturday, Dec 10, 2011 at 20:31
Hi Julie
Because this question gets asked so often, i have written a Blog - click on my blogs near my signature and find the one on toilets. I do not use eucalyptus oil - some people do because they like the scent.
AnswerID: 472185
Reply By: P2D2 - Saturday, Dec 10, 2011 at 20:35
DO NOT USE eucalyptus in a cassette toilet. Eucalyptus will soften/melt the plastic material.
2 cap fulls nappy treatment with 1.5L water and good squeeze of dish washing liquid is the go.
AnswerID: 472186
Follow Up By: Member - Old Girl - Saturday, Dec 10, 2011 at 22:06
Second that
FollowupID: 746985
Follow Up By: Fred G NSW - Saturday, Dec 10, 2011 at 22:12
Ditto...Ditto.....
Do not use euclyptus oil in the porta potti. If you do want to use it, sit the porta potti on a bath mat, and sprinkle some eucalyptus oil on the mat. Much more effective.
There is no set rule as to the ratio of napisan in a porta potti. Use the HOMEBRAND at about $3 a container, and it should last 2 adults for at least two months. Just chuck a couple of capfulls into the pan, pour a litre or so of water into that, then flush. Adjust as necessary, being guided by any odour, as the bottom tank fills. Just keep in mind, it is only a porta potti, not a septic tank. Whenever another option is available, I prefer to use that.
I don't put any in the top tank. You will find that in cold weather you will use less, and you will use more as the weather heats up.
Much cheaper and more effective than the horrible smelling chemicals.
FollowupID: 746986
Reply By: raincloud - Sunday, Dec 11, 2011 at 07:57
using any type of "sand" will not be good!!!!
AnswerID: 472221
Follow Up By: Smudger - Sunday, Dec 11, 2011 at 11:45
Just a tad abrasive I'd expcet.
...Oooh! makes the eyes water.
FollowupID: 747029
Follow Up By: Fred G NSW - Sunday, Dec 11, 2011 at 20:37
raincloud and Smudger......
I hope your contributions to threads on this site improve in 2012.
I know for a fact that you 2 don't, and never have, walked on water :-)
Have a good Xmas.
Fred.
FollowupID: 747074
Follow Up By: Graham C3 - Monday, Dec 12, 2011 at 06:48
Go to Lets-Getaway and click on RV Extras.Than go to Home Made Toilet Chemicals. I have used Remedy Two with great success.
Get a four litre contaiiner and mix together in that. Cheap and lasts a long time.
FollowupID: 747105
