ICOM PRO 400 UHF ISSUES
Submitted: Sunday, Dec 11, 2011 at 14:50
Member - Allan H
A week ago I installed Icom 400 Pro UHF into 80 series, if anyone can help me solve a some issues that would be great, as the instruction manual is confusing in my opinion.
(1) When you turn the uhf on a loud high tone comes from the speaker. This happens I turn the unit on everytime. Very annoying. Is this normal?
(2) I have the uhf on channel 40 when I start the scan (open) the channel jumps from 40 to 48 ?
(3) Not sure if I have the squelch adjusted correctly. Adjustment goes from 0-250 I have it set on 60 the instructions seem to be wrong way around.
I would appreciate any feed back, I have read the forums on EO and non of these issues have come up.
Many thanks in advance.
Reply By: Member - Peter S (NSW) - Sunday, Dec 11, 2011 at 15:22
I may be able to help with the tone, if you unclip the mike lead from the unit and look into the hole you will see the head of a small screw, that screw will adjust the tone, I have done this on
mine and it works, I think I have my squelch about 120 but not to sure, hope this helps,
Pete
472275
Reply By: snapper49 - Sunday, Dec 11, 2011 at 15:24
The loud beep is normal
It can be programmed to turn off usually via a computer hook up
the scan channels can be turned off or on so more than likey channels 41 to 47 nhave been turned off for scanning
472276
Follow Up By: snapper49 - Sunday, Dec 11, 2011 at 21:57
just add to turn off the start up beep when hooked to a computer its just a matter of unticking a box
747086
and again I run
mine on 25 watt
747088
Follow Up By: olcoolone - Tuesday, Dec 13, 2011 at 14:33
How dare you run your CB radio on 25 watts.... do you know it's illegal..... BLAH BLAH BLAH.
Just thought I would get in before all the do gooder do.... LOL
747246
Reply By: MEMBER - Darian, SA - Sunday, Dec 11, 2011 at 16:25
I agree re the manual - it assumes far too much prior familiarity with advanced radio programming - clods like me are left head scratching for hours (days sometimes). I think the 400 Pro is actually designed 'primarily' for commercial users (it can run at 25W, not our 5W) and would commonly be programmed in multiples by an expert - they would then just dump the program onto the units via a PC - I guess many organisations would use them every day and never tweak anything .
1. Yes re the loud start up beep - I have not seen an 'off' for that anywhere in the menus. (I think it is the same loud beep that heralds a timed shut down if you accidentally leave the radio on - a very handy programmable feature). 2. Can't say -
mine is still programmed for 40 CH - might pay for an update at some stage, but for now I have 80 ch hand-helds). 3. Suggest you experiment -
mine was on 125 but have changed that a few times up and down - the lower the number, the easier it is for a channel to open - if there is habitually hash only on 'opens', raise the number. In my view, this setting can only be arrived at after monitoring transmissions in the field over a good period of time.
Oh... and...re AF Min - handy it seems - will be adjusting
mine up from 0 soon - info at hand says this sets the lowest speaker volume setting, regardless of volume knob position - meaning that if a 'certain person' brushes against the volume setting and turns it to zero, we will still hear anything coming in.
BOL
472282
Reply By: 944runner - Sunday, Dec 11, 2011 at 21:28
Reply By: Member - Bucky - Monday, Dec 12, 2011 at 04:33
Allan I can help
Have an electronic version of a simplified user manual
Actually written by someone who can speak and write Engrish
Bucky
472338
Reply By: Member - Chris & Debbie (QLD) - Monday, Dec 12, 2011 at 12:42
For people that are interested, I have just uploaded the simplified users guide as a PDF file for the 400Pro into a blog
Chris
472353
