Monday, Dec 19, 2011 at 23:03
firstly the vast majority of UHF aerials sold are ground independent....In particular the elivated feed units mentioned.
At UHF particularly ground independednt, the ground plane plays a far less significant role than it would on VHF....so much so that it is praticaly irrelivent.
There is a reason why 6 dB elivated feed aerials like the one mentioned are used in volume in commercial UHF two way, and why almost every manufacturer makes an almost identical unit for UHF CB...because this is where all the factors converge to give the most effective unit for the size and price.
As far as mounting high.......the importance of mounting high for UHF can not be over emphasised...it is gives a significant and profound advantage to keep the whole radiating portion of the antenna high and unobstructed.
There is realy no problem making and fitting a knock down mount..and besides lots of people remove their bullbar mounted Big White Sticks arround town.
One reason so many people run Big White Sticks, is because they look tuff.
The claim that stanless whips fall appart on bullbars is simply overstated, my neices husband has had an elivated feed aerial like the one I mention on his bull bar now for over 10 years and it is still just fine and it has done plenty of rough road work.
There are plenty of reports of Big White Sticks falling to bits, braking off at the base and other downfalls....in many cases it is the size and mass that is their downfall..... vibtarion will kill anything eventually.
That brings another very good reason to get the blasted aerial off the bullbar.....the bullbar is rigidly attached to the chasis, and thus the worst of the vibration is transmitted to anything mounted there.
The cab on all relativly moden 4wds is rubber mounted to isolate vibration from the occupants.....this reduction in vibration is good for the antenna too.
As for stanless whips laying over at speed & so
forth..if that worries you, opt for an elivated feed unit with a fibreglass whip and a stiff base spring instead of the stanless whip......functionaly identical, but stiffer and only marginally more expensive.
Again the highway speed thing in my opinion is over stated....this is UHF and is very limited in range........line of sight........any effect will be slight, besides if you are trying for long distance communication on any radio, if you are wise you pull up and get a good position.....the electromagnetic noise generated by the vehicle running will be far more of an impediment than any slight bend in the antenna.
Like so many things, people get preoccupied with minor details and fail to achieve in the simple basics.
and the simple basics of UHF aerials are.
Get it high and unobstructed.....it is UHF and is line of sight
Get an areial with a fair amont of gain....arround 6db is fair, easy and economical, more than that gets expensive and technicaly harder at UHF, less than that realy gets no cheaper.
Do the terminations properly.
Fail to do the above and you are simply wasting time and money.
747757
