Sunday, Jan 01, 2012 at 01:39
G'day Marny,
Well, I'm sorry to say, but it appears (as I suspected) that the leopard has not changed it's spots..
That seller has a
well known &
well documented history of supplying undersized / over-rated / fraudulently labelled panels, and it appears that they're still doing it..
In my case, I ordered an 80W folding kit & received a 40W kit (2x 20W panels) labelled as 80W.. How the h*ll he thought he could get away with that is beyond me... Several others on this
forum have had similar experiences, and there's plenty of anecdotes on other forums as
well...
Those dimensions that you've quoted (1200 x 600) are simply not big enough for a 120 Watt panel..
For comparison, here's some specs I found on the net...
Sharp 120W .. 1449 x 662 , Kyocera 120W .. 1425 x 652, Projecta 120W .. 1335 x 670...
As you can see, quite a difference in size between these and yours..
I'd strongly suggest you do some testing ASAP, & determine the true output of those panels.. measure the output before the regulator, & with a 15Amp load connected.. I'd be surprised if you can get more than about 10.5 - 11Amps (@18.5V), whereas 240W should produce around 13Amps...
When it'a all said and done, a 200W kit for the price you paid is still not too shabby, but it's the mis-representation that is just plain wrong.... (simply put, it's fraud!)
By contrast, the seller linked above (by Ozhumvee) is of known good repute..
Happy New Year!
Regards,
Ed C
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
748590
