Saturday, Dec 31, 2011 at 13:16
Hi Rich,
The
Savannah Way goes from
Cairns to
Broome and has many "alternative" roads on it for you to pick from, if travelling in August you could do it on a pushbike ...... and it has probally 2 - 4 go past us here each year ......
Do you have a plan of the roads you want to travel on as that will determine what gear you will need, if it is for instance coming from South and you start at
Cairns you will have Telstra coverage off and on to
Normanton and sealed roads and a zillion other travellers,
Normanton to
Lawn Hill via 4 ways RH to
Gregory Down, also sealed roads, short trip out to Lawn Hil is dirt but good, patchey Telstra coverage at
Lawn Hill, and half a zillion travellers, back to
Gregory Downs to Burktown, some dirt again but good condition, Telstra Coverage at Burky..... Burky to
Doomadgee with the
Gregory river and Nicholson to cross, most probally in Aug will be 200mm deep at the MOST if not dry, both concrete crossings and only 20ks of dirt in the 100 odd klms, about 29k dirt to Kingfisher
Camp turnoff from
Doomadgee, road into Kingfisher is a "track" but always repaired after the wet and goos enough for vans to be towed in at a "safe" speed......... Kingfisher to Hells
Gate mostly dirt some patches of sealed, after Hells
gate all the way to Boorlooloola is dirt and condition varies greatly, on average it is a good enough road to drive a car down ..... Burktown and Doomagee are the last Telstra
services up until Booloolooloolololololaaaa
Gear needed for that trip taking into account you will be towing a van so restricted where you can go and dont dream that because it is an "off road" van you can go bush ....... being "off road" means it """should"""" still be in one peice when you have done 300klms of corrigations....
Good basic 40ch UHF and the best antennea you can buy for off road stuff, corrigations will bust then off and get one of the cheap ss wire ones to store in ya spares box just incase........
Spot is perfect, Sat phone is the best but ya need money for them .... wait an hour at the most and someone will be along ........
Tarp over front is fine, most rivers up here run fast so you dont want to go in if it is deep enough to need a snorkle ....
Dont need a winch, remember you will have a van on, look ahead and plan carefully as you also cant reverse in a sticky situation with a van, carry plenty of ropes/straps as there are heaps of other travellers then and they will help you ........
Need near new tyres all round and 2 spares same condition, as long as they have a good LOAD rating, August is dry so you will be fine with a light truck hwy patten but make certain whatever they are, they MUST be in excellent condition, you will pass 6 wrecks of vans, probally more, that have rolled or in general destroyed due to TYRES BLOWING and operator losing control, $70,000 one sitting at Burktown right now ....
Fuel, you can get
fuel at
Doomadgee and Hells
Gate, Hells
Gate to Booloola is 400 odd klms from memory, dont carry jerrys if you can help it, waste of space and weight, far better to carry a second spare for that weight and alway keep the tanks full ...........
Basic tool range making CERTAIN you have a good hydrulic jack, dont bother with a Kangaroo Jack, few wooden blocks are handy additions, you can use them for bait boards, always carry silicon, cables ties, 500gm tin of bog (plastic
putty) ..... and whatever else you are capable of using and might need ........
Just remember to start checking road conditions at least 4 weeks befor leaving and if not sure check every day up to leaving date so you know EXACLY what you are up against, if you plan ahead and know the road conditions you could drive a 2wd car from
Cairns to
Broome in August ...
Cheers and enjoy, call in and have a coffee with us at
Doomadgee
473694
Follow Up By: Member Andys Adventures - Saturday, Dec 31, 2011 at 14:29
Hi Joe , I think you mean
Borroloola.
748524
