Sunday, Dec 21, 2003 at 17:21
Hey there,
been to Frazer several times, and blieve that you should not have a problem actually driving on frazer, as i have seen many rav's travel up
the beach. The only problem as many have mentioned will be clearance on the inland track, but as long as you take it easy, lett tyre pressure down to about 18 - 20psi and have a shovel you shouldn't have a problem. I personally would suggest to take the black top to the barges at
inskip point being a little under experienced, and this way it will allow you to organize
camping and vehicle permits, confirm tides etc the same day.
I would recommend that your friend goes to ARB or TJM and purchases a good recovery snatch strap, and confirms that there is a rated recovery point on the vehicle, if not they should be able to help install one for for about $80 - $100 it's a small amount of money the pay for piece of mind, and most of the people on the island are willing to help tow private vehicles out. Avoid the tourist back packers troopies - (to much trouble).
With a vehicle that is so light, you chouldn't have to to much problems getting bogged, or a bit of digging and a push should get you out. Anyway my best adivise is take it easy driving up
the beach, as some of the freshwater inlets can get quiet deep, and read the tides, as without a low range 4WD could cause a problem, also travelling at low tide, you should be able to pass most of the fresh
water inlets, without worrying about there depth and the air intake.
Anyway, if they follow these simple rules, they should have a fantastic holiday, and make sure they visit lake mackenzie - (unreal).
PS I would recommend them to go to there local
camping store, 4wd store and pick up a map of the island, they are alot more detailed then what you get with your permits, and
well worth it. And maybe a 20ltr gerry can.
Fuel is about $1.20 a ltre - topup at
rainbow.
Happy
camping....:)
40788
