Just bought Nissan 2.8 diesel turbo
Submitted: Saturday, May 26, 2012 at 12:37
Jim M1
Hi just bought Nissan 2.8 diesel turbo. Found in a bit sluggish so I put 3" Exshust from the back of the turbo witch made it come On earlier gave it more down low. I improve the air in take. I add more boost got the Exshust temp right. It has turn into a animale. Grate for towing, 4wd.
Reply By: Dust-Devil - Saturday, May 26, 2012 at 13:26
And ?????????
486811
Follow Up By: dazren - Saturday, May 26, 2012 at 14:57
What's up ? Dust-Devil, you having a bad day ??
I think Jim M1 was just telling us he bought a 2.8 diesel nissan, and as we all know they are slow and sluggish, And he has done some little Mods that have made a marked improvement on the perfomance,
I think he has the right to pass on that info without, getting any sarcastic remarks, Hope your day improves,? Rgs dazren
762043
Follow Up By: Dust-Devil - Saturday, May 26, 2012 at 19:47
Well there you go Dazren, even you should be able to deduce what the 'and????'
He wanted to know about Diff lockers and if you weren't so occupied with being the
forum Nazi you might like to tell him all about them
DD
762060
Follow Up By: dazren - Saturday, May 26, 2012 at 23:17
Sorry dust devil, You may call this ''' AND ????? Info on diff lockers, however i still see it as sarcasm, and you are correct, i know very little about diff lockers but apparently you do, so where is your knowledgable assistance to Jim M1
762079
Follow Up By: Dust-Devil - Sunday, May 27, 2012 at 01:09
Dude.
Sarcasm about what may I ask,and while your explaining that, how about elucidating your theory on my knowledge of diff lockers.
Jim M1 himself is the first to mention diff lockers in this thread and his requirement for info on them. I was just indicating that requirement to you.
762085
Follow Up By: Shaker - Sunday, May 27, 2012 at 16:43
Am I missing something?
I can't see any reference to diff locks in the original post!
762125
Reply By: Kev - Member - Wynnum - Saturday, May 26, 2012 at 18:01
HI Jim,
Stick with it and don't worry about any criticism, they know not of what they speak.
The 28Td is as magic truck I had one and it took us and the camper all over Australia.
You have done some mods. I'm not sure where you are from but there is a mob at Sandgate, Qld who will put a chip in it for you which gives the same effect as a 3" turbo exhaust.
There is nothing wrong with the 2.8 Nissan turbo Diesel.
Kev
486826
Reply By: Jim M1 - Saturday, May 26, 2012 at 18:59
Hi thanks for the support guys. Iam thinking about putting front and rear air diff lockers in my GQ 1996 do thay have any problems with diff centres braking or snapping axles
486837
Follow Up By: Dust-Devil - Saturday, May 26, 2012 at 19:44
Thank You
762059
Reply By: Mudripper - Saturday, May 26, 2012 at 23:52
Hi there Jim,
Firstly, don't pay any attention to the sarcastic comments. It seems an inherent feature of this
forum.
Look, the GQ's are a great vehicle. Regarding the drive train, I haven't heard of any issues with these models. However if you start running large tyres (35's or something) then you can *probably* expect to start breaking things (CV's in particular). ARB air lockers are a great investment, being stronger than the stock diffs. If you're just running standard tyres (or a BIT bigger) and you go easy on the old girl, the truck will give you years of service.
Tim.
486862
Follow Up By: Jim M1 - Sunday, May 27, 2012 at 08:12
Thank you
762091
Reply By: GT Campers - Sunday, May 27, 2012 at 07:44
Good to see the 'old skool' hot rod tricks work on the 2.8.
Leave the big tyres to the P-platers, taller tyres will destroy its around-town and low-speed off-road performance, and its fuel economy
486868
Reply By: Member - Bucky - Sunday, May 27, 2012 at 09:44
Jim
Jump onto the Patrol
Forum
Lots of advice there.
Plenty of them around,
Plenty of tricks you can do to get them up and running.
Just remember they can run with the best of them, if you go set them up the right way..
As far as Hard Core 4X4 Driving goes, don't wind them up too much, as the drive train (I have been told) lighter than their 4.2 lt, or 3 lt, counterpart.
Bucky
486876
Reply By: SDG - Sunday, May 27, 2012 at 18:43
I have a 96GQ 2.8 as
Goes great.
Only problem they had was that around 250 000 k's they can wreck their heads. I had
mine rebuilt when
mine happened.
As for gearboxes etc, I was talking to the Nissan mechanics here recently. Rarely did they have trouble with the gear boxes on GQ's, but apparently they always had one on the self for the GU's as that was a regular job.
A
snorkel works
well as
well, but, you can hear a lot of induction noise with one. Apparently also common.
486923
Follow Up By: Jim M1 - Sunday, May 27, 2012 at 20:38
Hi ur not wrong about the induction noise, it sounds like its going to suck the world through the
snorkel. I have a question? any body know how much boost the 2.8 GQ can take befor everything falls out? It has a after market intercooler fitted.
762179
Follow Up By: Penchy - Monday, May 28, 2012 at 16:44
+1 have a GQ 2.8. everyone hates them but I like
mine. Economy is good and its a 4wd not a race car so I expect to be slow. Jim, if your in
Sydney would be good to get a bit more info on what you have done and where you got it done.
Jase
762252
Follow Up By: Jim M1 - Tuesday, May 29, 2012 at 01:32
Hi jase. yes I am in
Sydney. I'm a mechanic I did all the little mods myself. Yes thay are a bit sluggish but a little bit of boost makes a big differents. It just has to be done right, diesels are very touchy it is all about the Exshust temps. Get it right & you will get good fuel economy when cruising and power when u need it. My GQ has done 462000km when I got it.. So I pulled the sump off check the bearings thay look good clean the oil pick up it had slug build up i also removed the turbo oil feed line put air through not happy so I changed it with a braided hoes just for peace of mind so far happy as.
762304
Follow Up By: SDG - Tuesday, May 29, 2012 at 08:17
Keep working/experimenting like this, and your going to have us 2.8 owners at your doorstep for some business.
762315
Follow Up By: Jim M1 - Tuesday, May 29, 2012 at 20:03
Thanks SDG. I will, I'm willing to brake one to find out its limits. I don't want to but when you want more and more power something has to give. I would like it to hold about 12-16 pounds of boost and be reliable. Slowly I will found out.
762371
