Hema Maps
Just a short note to say that the Hema 2012 Raster Map Collection does NOT work on Trackranger Navigation Program, Hema Maps have to upgrade there ECW Files,
Reply By: Grumblebum and the Dragon - Sunday, Jun 17, 2012 at 11:46
I do nt think the Hema 1/250,000 are as detailed as the same series supplied by Natmaps from Aust. Geosciences. I am going to run the latter on my Hema 6 Navigator
AnswerID: 488712
Follow Up By: Sand Man (SA) - Sunday, Jun 17, 2012 at 18:29
John,
I'm surprised the Navigator 6 doesn't come with the Natmap series of maps like the Navigator 5 did, as well as the Hema range of maps.
Bill
FollowupID: 763872
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Jun 17, 2012 at 19:23
Hi Bill
That is the only downside, but I copied my Natmap 1:250K from the HN5 onto the HN6, dead easy.
Below is what John is talking about.
Image Could Not Be Found
Apart from this issue, which you can live with, the new HN6 is even better and it is now even possible to import tracks directly into the normal OziExploer as you would for any user track, and not as a GPX File.
FollowupID: 763877
Reply By: Member - Josh- Sunday, Jun 17, 2012 at 14:57
Have you contacted Hema and discussed it with them???
Josh
AnswerID: 488724
Follow Up By: Plonk - Monday, Jun 18, 2012 at 09:18
HI Josh
Yes they said they are working on the problem.Bit its a bit disappointing when you buy the program for $170.00 expecting it to work.
FollowupID: 763941
Follow Up By: Member - Josh- Monday, Jun 18, 2012 at 17:39
Yeah fair call. You would think in todays world of technology it wouldn't be that hard.
Josh
FollowupID: 763963
Follow Up By: The Explorer - Monday, Jun 18, 2012 at 18:10
It probably isn't that hard (in fact Im pretty sure its an easy fix) - more likely an oversight. Not many people use Trackranger (as far as I can figure) so maybe they (Hema) didnt do a test before release.
FollowupID: 763970
Reply By: The Explorer - Monday, Jun 18, 2012 at 14:05
Has any one figured out why they dont work? Do the ecw files lack the required coordinate header information (contained inside ecw file structure) required by Trackranger?
AnswerID: 488805
Reply By: Plonk - Monday, Jun 18, 2012 at 19:31
Hi Greg
I dont know But 35 of the 60 od maps come up with no coordinates calibrated and the one that is calibrated showing my position 200ks where i supposed to be its just a balls up.
AnswerID: 488841
