2 x 6v batteries in series
Submitted: Tuesday, Jan 13, 2004 at 15:54
ThreadID: 9716 Views:1911 Replies:5 FollowUps:1
So if one such 6v battery has an amp hour rating of 65amps at the C20 rate, if i connect two at the same condition in series does this give a genuine reserve capacity at the C20 rate of 130amps at 12v ?
Reply By: Leroy - Tuesday, Jan 13, 2004 at 15:59
Hmmm I would say 65Ah at 12v as each batt is supplying 6v the current draw is the same. If they were in paralell then it would be 6v at 130ah.
Leroy
AnswerID: 42819
Follow Up By: Member - Rohan K - Tuesday, Jan 13, 2004 at 16:34
That's correct. Series adds the voltage, not the current and parallel add the current not the voltage. You cannot add both voltage and current.Smile, you're on ExplorOz
Rohan (Sydney - on the QLD side of the Harbour Bridge)
FollowupID: 305141
Reply By: Dave from Fraser Coast 4WD Club - Tuesday, Jan 13, 2004 at 16:13
I'm with Leroy
AnswerID: 42821
Reply By: paul - Tuesday, Jan 13, 2004 at 16:51
wishful thinking then.
AnswerID: 42828
Reply By: joc45 - Tuesday, Jan 13, 2004 at 21:19
Still 65A. You get to have 12v, not 6v tho.
Gerry
AnswerID: 42860
Reply By: Member - Bear - Friday, Jan 16, 2004 at 21:38
Paul
I have been advised that the best way to go with the camper trailer is two 6V @ 230+ AMP HOURS.
The 6V batts are from fork Lift's that are use to being drained all the time.
Hope this helps.
BearBEAR
AnswerID: 43280
