HEMA HN5i NMEA functions/Moving map
I am really struggling to use my HN5i NMEA function with the supplied software.
I have set GPS/PC to COM7 and set the baud to 4800 I have also tried multiple COM ports and baud settings. I even tried the HEMA support centre with no joy...
any help would be greatly appreciated.
Reply By: Sand Man (SA) - Friday, Aug 10, 2012 at 09:04
What are you trying to achieve?
The Hema should operate successfully with the factory default settings.
On my unit:-
NMEA (GPS) settings
Comm Port COM7
Baud 38400
Sentence GPRMC
Select Page - GPS Status
GPS Status Should show GPS On and NMEA Output continually updating at bottom of screen.
Button on right side turns GPS function On/Off
The hema does not output GPS data externally, so if you are trying to input data into a PC to feed another program, you can't do it.
The Hema is a self contained unit and cannot be used as GPS input to another device.
Bill
AnswerID: 492636
Follow Up By: The Explorer - Friday, Aug 10, 2012 at 10:23
Yes the NMEA settings only relate to data transfer from the internal GPS to programs installed on the unit - AFAIK there is no way to send NMEA data to external devices. If you are just trying to transfer waypoints and track data then the NMEA settings are not relevant. You need to install on you PC ActiveSync or Windows Mobile Device Centre (depending on OS on PC) - these programs will allow you to transfer data (but not NMEA) using normal windows cut/paste/copy plus use that cut down version of OziExplorer (Hema Navigator Explorer). All these are available for download here
One solution to the NMEA probem (if that is in fact what you are trying to do) is to purchase a cheap "GPS Mouse".
FollowupID: 768310
