Question re Wiluna Shire road map
Submitted: Monday, Aug 20, 2012 at 11:59
ThreadID: 97536 Views:2753 Replies:5 FollowUps:2
Looking at the map found here:Wiluna Shire Road Map
It shows a "Proposed Drive Trail - possible completion 2012/2013" between the CSR and the Wiluna Granite Peak Road. Does this mean they're building a new east-west road to connect those two? Or something else?
I won't be in the area anytime soon, but I'm still curious what that is.
I'm trying to avoid calling Wiluna from the States, I'm hoping someone here knows what this is about!
Reply By: member - mazcan - Monday, Aug 20, 2012 at 12:11
hi candace
perhaps its a new minesite access rd this would not surprise me
do you mean your calling from states of america or the eastern states of australia
AnswerID: 493244
Follow Up By: Candace S. - Tuesday, Aug 21, 2012 at 13:17
Sorry, I meant USA! LOL, didn't even think about how that could be misinterpreted.
FollowupID: 768908
Reply By: The Explorer - Monday, Aug 20, 2012 at 13:34
Nothing definitive for you but the track appears to already exist (250K map shows several "station tracks" across here - assume they are referring to one of these).
So suspect they may just be upgrading it or adding signs etc as apposed to actually putting a new road in.
AnswerID: 493251
Reply By: Member - Scott M (NSW) - Monday, Aug 20, 2012 at 13:49
HEMA Desert Tracks Southwest already shows these roads in place - including the run through Granite Peak, which is the alternate route for vehicles towing trailers....
Interesting though .... If the Wiluna Shire is advertising this round route as "Tourist Attraction", does this mean they are going to maintain the CSR between Wiluna to Well 5? and if so, does this remove the restriction on trailers?
AnswerID: 493253
Follow Up By: Member - Scott M (NSW) - Monday, Aug 20, 2012 at 13:53
Actually, re-looking at the map - it's a 'Proposed Drive Trail' and Cunya Station section is still no trailers
FollowupID: 768823
Reply By: Bob Y. - Qld - Monday, Aug 20, 2012 at 13:51
Candace,
Just looking at the map, I'd suggest it's one of those tourist loop, or ring road, that they could do in a day.
For the less intrepid, they could do this, and say, on their return, that they've done the CSR, & Gunbarrel in one day.
Have a few similar loop roads around Winton too. They are just normal roads, but given a tourist flair, with a few extra signs, as previously suggested.
Bob.
AnswerID: 493254
Reply By: Member - John - Monday, Aug 20, 2012 at 19:57
G'day, looks to me to be a tourist drive loop, using existing tracks and roads. The track already exists thru Granite Peak to Well 5, costs $20 a vehicle. Cheers.
John and Jan
AnswerID: 493284
