ABR flyer battery box
Submitted: Friday, Aug 31, 2012 at 11:38
ThreadID: 97760 Views:3182 Replies:3 FollowUps:2
Hello all. I purchased an ABR flyer not long ago for my old hilux ute, solely to power a fridge. To give myself flexibility I have wired the ute so i can have the flyer in the ute tray or on the floor behind the drivers seat. Same goes for the fridge.
I would like the know the best way to strap the flyer to the floor. I am assuming i need some kind of bolt with an atttached loop which I can feed a strap through. Same goes for the fridge, what is the best way to strap it to the tray?.
Reply By: Bob Y. - Qld - Friday, Aug 31, 2012 at 13:19
Check out ovesco.com.au or Whitworths.
They both sell eye bolts, and other parts that would useful to make a battery box secure.
Would suggest that you use some "mudguard" washers under the bolts used for the in-cab mounting position. Would reduce any risk of the flyer becoming loose, from mounting bolts pulling through the thin body panels.
Bob.
AnswerID: 493995
Follow Up By: grunta1970 - Friday, Aug 31, 2012 at 19:13
Thanks bob
FollowupID: 769675
Reply By: Member - Peter R (QLD) - Friday, Aug 31, 2012 at 14:58
This is how mine is attached.
Pedro
AnswerID: 494003
Follow Up By: grunta1970 - Friday, Aug 31, 2012 at 19:15
Mines going to be a little more primitive that yours Pedro :-)
FollowupID: 769676
Reply By: Sand Man (SA) - Friday, Aug 31, 2012 at 18:48
Grunta,
If you look on the Sidewinder web site you will see a Flyer universal mounting bracket.
The configuration I used was the "L shaped" one which I bolted to the back of my drawer system, then a strap holds the Flyer securely to the bracket.
Scroll down the page to get an idea of what Derek has available.
P.S. The Flyer is a very good solution and I'm sure you'll find it most practical.
Flyer Accessories
Bill
AnswerID: 494020
