Thursday, Sep 20, 2012 at 11:24
Yagon,
Don't have any digital images that I could show you.
We used to mount them on the passenger side of bullbar, where you could "monitor" where
the tip was, in relation to trees, overhead wires or
gate caps. And they weren't in the driver's direct vision either.
Have seen them mounted on head rail, up behind the cab, or even on rear spare wheel carrier. The latter position might be a bit close to body work, unless it was on a raised mount. The standard heavy-duty spring mount is very robust, and haven't seen many break. Some do lose the tension in the spring, and tend to "flop" about, even coming back to wack the cab, in really rough conditions.
We used the 4' whips, because we had areas of low gidgea scrub, and were often off road. Otherwise the 6' whips might give slightly better performance. Terlin makes one that is in 2 pieces, though i don't know what they are like.
We used RFI aerials, but didn't notice them on their website now. Check out TERLIN, from WA, for a good variety.
Just on radios again. We have a Codan 8525 that my wife won in a RFDS raffle, and it has been a really good unit. However, at over 25 years old, it mightn't be the one you need, if you could afford something newer.
Bob.
770968
