Sunday, Oct 21, 2012 at 08:56
Hi Graham
Welcome to the best site for the questions and answers about our great country.
The
Simpson Desert is a great drive and attracts drivers from all over Australia and the world to experience the vast open spaces and true four wheel driving at its best. Like any trip, it will be as easy or hard on how prepared you are and if you are generally going to take advise on how to drive it.
The key to a successful crossing is tyre pressure and get this wrong and you will have trouble
well fore you enter
the desert proper. High tyre pressures and you will get bogged on every dune and cut the track up, so start at 14 psi and go lower if you are still having problems. A sand safety flag is a must, as
well as a
UHF Radio on channel 10 for a crossing.
From
Birdsville you have only 1 track to follow, the QAA all the way out west until it is time to head south on the K1 Line. After traveling the K1 for around 20 kilometres, you will then have 2 options, firstly to continue south on the KI for some distance until you get to the
intersection on the
Rig Road, or take the fun track and head further west again on the French Line. Either way you will want to visit
Poeppel Corner, the meeting point of 2 Australian State and 1 Territory, Queesnland, South Australia and the Northern Territory.
Poeppel Corner is a must visit spot to see
If you want to continue on the French Line, your next choice of track will them be around another 40 kilometres west, where you should visit the Knolls. From here you can head further south to take either the WAA on further south out on the
Rig Road. It will be all great fun but another must visit site should be the Lone Gum. As you
zig zag you way through
the desert, you will finally come out at Wonga
Junction and the end of the true
sand dunes, even though you will still be passing over a few as you are heading to Purnie
Bore, but these are no problems at all after crossing the 1100 dunes to get to this point. It is at this point where you will inflate your tyres again as you make you way over the gibber planes and arrive at Dalhousie for your most welcome warm swim in the 37 degrees hot springs. Here you will spend hours just relaxing in a true desert
oasis.
The soothing waters of Dalhousie
Either way, do your homework, listen to others that have driven the Simpson and it is an easy drive proving that it is not wet, then it is a completely different story......
When it's wet it will test you to the limits
Enjoy your trip and you will see why Australia is the best country in the world.
497056
Follow Up By: Danna - Sunday, Oct 21, 2012 at 16:32
G’day Stephen
I wouldn’t send any one in hired vehicle to drive
Rig Road especially not from East to West (
Birdsville to Mt. Dare). From West to east road is little bit less demanding, but still not for novices.
We driven
Rig Road from East to West this year and we didn’t met anyone for almost one week, and I mean even no one calling on 80 channel radio and having all the time full scanner on. I was calling out of high dunes and on body there.
Going
Rig Road you must have highly modified very strong vehicle,
plenty of spare tyres,
water and food and real good experience 4WDriving. If you do not have one of those, it may cost you lots and lots of money to be recovered.
Rig Road is these days actually in such condition, that people from Mt. Dare don’t advice travellers to drive that way.
Cheers Dana
772824
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Oct 21, 2012 at 21:09
Hi Dana
We have driven the
Simpson Desert countless times over the years and not hearing other people talking on the radio can be quite common, when in fact there could be other groups only a couple of hours either in front or behind you. As for the 80 channels, not every one has the new radios yet, so there will be a very high chance that you will hear only the 40 main channels, while channel 10 is the requested channel for a Simpson crossing.
As for saying that your vehicle must be highly modified, that is not correct and false information. I will all come down to driver experience and how you drive that vehicle, and if you give me any standard four wheel drive that the hire companies use, I could get from one side to the other without any problems, with the exception of mechanical which can happen to any vehicle. You will find that your best friend every time is low tyre pressure, and not speed.
772836
Follow Up By: Danna - Sunday, Oct 21, 2012 at 23:53
Hi Stephen,
have you been very recently on the
Rig Road? I wouldn't thing so, that's why you can make all these claims about vehicles, preparations and traffic. There are not only a sand ridges higher than the Big Red, but broken clay base that is virtual not drivable, so you have to bush-bash up to dunes with high sand blown tops.
As I mentioned, there is a reason why people in Mt. Dare don't recommend people to go that way!
Dana
772844
Follow Up By: Member - Stephen L (Clare SA) - Monday, Oct 22, 2012 at 08:36
Hi Dana
No to be honest, we have not driven the full length of the
rig Road for a few years, but still stick with my claims, it all comes down to driver experience.
Any of the Simpson tracks are all very easy to drive in a standard vehicle, so it sounds like this was your first ever Simpson trip.
If you would have read any of my
blogs, I am no stranger to remote travel and in 2006 did a complete off road venture.....no tracks what so ever to follow for nearly 400 kilometres through the very heart of the
Simpson Desert in a stock standard 1998 Mitsubish Pajero,
well not stock standard, I had new Shock absorberts and Black Widow Draws fitted, not the highly modified vehicle that you make out is required for the easy Simpson tracks........
No tracks to follow out there
So you thought that the Rig Road Dunes were high
The Mogals were the biggest problem
Mogal covered swales, 1st & 2nd low to make your slow way through to the next side
Yes any Simpson track can be a challenge very early in the season, but still easy compared to a true trackless challenge.
772857
Follow Up By: Danna - Monday, Oct 22, 2012 at 10:05
Since few trips to
Simpson Desert before 2009, that area changed especially after rain we had as you may know. I wouldn't enter this reply, if I wouldn't know for sure what I'm talking about. We bush-bash and remote drive for last 11years, and I'm not claiming we have seen it and done it all, but I stand behind advice of Mt. Dare people.
Dana
772869
Follow Up By: Grizzle - Tuesday, Oct 23, 2012 at 08:33
I think you're right Stephen. Tyre pressures and speed are paramount. You don't need a highly modified vehicle.
Fuel,
water and food are obvious essentials. Preparation also is important.
772965
