Water tank for a 1994 Troopy
After a water tank for my 1994 bushcamper troopy.
were can I get one.
Also like to know where is the best place to install it.
The troopy has 2 90 ltr fuel tanks.
Reply By: Life Member - Phil B (WA) - Sunday, Oct 28, 2012 at 23:09
You're a bit vague there Scott.
Where are you going to fit the tanks?
Do you want metal or plastic?
what size are you looking for?
etc.
With that sort of info you'll get better ideas and opinions
AnswerID: 497543
Follow Up By: Scott T4 - Sunday, Oct 28, 2012 at 23:20
Sorry Phil B
Under the body.
Plastic or metal.
40 to 60 ltrs
FollowupID: 773395
Follow Up By: Life Member - Phil B (WA) - Sunday, Oct 28, 2012 at 23:30
Scott
You might find something here
http://www.dolium.com.au/view?command=cman_view_webpage&action=view&webpage_id=82&pkey=dolium
FollowupID: 773397
Reply By: Member - kwk56pt - Monday, Oct 29, 2012 at 00:28
Atlas tanks in QLD does a huge range to suit vehicles and you can have the fill and outlet put where it suits you. Sorry I cant make any suggestions on where to fit one under a troopy but there are lots of users of these vehicles so i am sure someone of more knowledge will give you some ideas.
AnswerID: 497545
Reply By: Member - Wamuranman - Monday, Oct 29, 2012 at 08:06
HI Scott,
Also have a look at Abbertanks in Queensland. They will make any particular shape you require to use up a space that otherwise may not be useful;
http://www.abbertanks.com.au/products.html
AnswerID: 497549
Reply By: Danna - Monday, Oct 29, 2012 at 11:55
Hi Scott T4
We have 2009 Troopy and ARB fitted under-body S/Steel 55L water tank that was fitted together with 180L auxiliary fuel tank. We are very happy with that set-up.
Only problem at the time was to fit the Sterling 3" exhaust. There was non...yet ... for this combination. So Jeremy from Sterling borrowed our rig for one week to make it and we get a free prototype.
It wasn't bad deal, even we have to drive with 2 cars from Sydney to Singleton.
Good luck Dana
AnswerID: 497565
Reply By: Member - Walter H (WA) - Monday, Oct 29, 2012 at 22:46
G'day Scott i fitted a 60ltr S/Steel tank to my 2000 Troopy that came from Opposite Lock and that it fits in the middle between the front factory tank and the rear long ranger ,i also so fitted a 50ltr Poly tank that's bolted to the cargo barrier as its only 50mm wide and both run via a Pressure pump........but i did have to get the exhaust modified to clear the S/Steel Tank .....Cheers
AnswerID: 497604
Follow Up By: Danna - Tuesday, Oct 30, 2012 at 10:54
Hi Walter
We wanted to modify the exhaust, not we have to. We have DP chip and Troopy have lot, lot, more power and use less fuel.
Something to consider ....
Cheers Dana
FollowupID: 773450
Follow Up By: Member - Walter H (WA) - Tuesday, Oct 30, 2012 at 18:49
Hi Dana,i have a older Troopy which has the old Mechanical bull motor [1HZ] and isn't a electronic motor like your later Troopy and it wont except a Chip so i fitted a aftermarket Turbo and intercooler to get more grunt from the old girl,but thanks anyway.
FollowupID: 773462
Follow Up By: Danna - Tuesday, Oct 30, 2012 at 21:24
Hi Walter
I like your type of Troopy very much. As it is all mechanical, that even Yuendumu bush mechanics can repair....sort off.....
You know, at least our still doesn't have in-dash bags that may blow in face. Cheers Dana
FollowupID: 773469
Reply By: Twintrail(W.A.) - Monday, Oct 29, 2012 at 23:18
hi scott i have 2007 troopie with outback drawers .behind my seats i have a 100 litrepoly tank with hose and tap which i use for my requirement twintrail
AnswerID: 497606
Reply By: Scott T4 - Tuesday, Oct 30, 2012 at 06:45
Thanks for all the info guys.
AnswerID: 497613
