Wednesday, Nov 07, 2012 at 20:44
Yes Allen I have 600amps of battery capacity, When i fill my
fuel tank I know it holds 290lts of diesel but for some reason I can only use 280Lts..... now my batterys I know if they were flat I would have to refill them with 600amps...... my batteries far much worse than the 10Lts I lose in capacity in my
fuel tank.... I can only run them down to 30% capacity before shortening their lives making my 600amps really only 420amps of usable power....... 360amps capacity in the 4x4 relates to only 252 usable amps..... so I know if I use 1 amp per hour I'll be able to do it for 600 hours, and if I use 2 amps per hour then I'll be able to do it for 300 hours.
The 4 reasons behind having big
battery power is ....
1) Because I can.
2) The area where they are mounted is wasted space.
3) If I have to do a big winch I am not trying to draw 400amps from my starter battery and over
cook the alternator with it trying to keep up.... alternators don't have a 100% duty cycle and it's a good way to destroy a $1000 alternator.
4) If I do destroy an alternator I know I have sufficient power to drive for 5-8 hours in the dark still using all lights and other bits and pieces.
Working on some peoples theories regarding overkill my thoughts are.....
1) Why buy a 19 foot caravan when you only need a 15 footer.
2) Why buy a turbo diesel when a non turbo diesel will still get you there.
3) Why buy a 4x4 up to 10 years old when a 40 year old one will do the same.
4) Why fit 285 wide tyres when you can still drive around on 245's.
5) Why have a fridge in your 4x4 when you don't need to drink cold
water or you can stop at the shops.
6) Why fit M/T tyres when your not going to drive in the mud.
7) Why put
driving lights on your 4x4 when you don't drive at night.
8) Why put a winch on when you're never going to go of the bitumen or use 4wd low.
9) Why put a bull bar on when you only drive around the city or during daylight hours.
10) Why fit a fishing rod holder permanently when you only use it 1 week of the year.
11) Why have a 4x4 as an everyday run around when you only tow your caravan or travel 2 weeks of the year.
12) Why have your
UHF radio's microphone hanging from the rear view mirror.
13) Why buy a dual cab or four seater vehicle when there are only two of you's.
14) ........
15) ........
Why because you can!
And Allen.... when I typed my original post I thought about putting amphours in but I got lazy and thought everyone will know what I mean...... after posting I then thought someone with too much time on their hands and nothing better to winge about will pull me up on it and tell me I'm wrong..... looks like I was right.... :) (:- (((H)))
And Mick congrats to you and Vicky.
774054
