Utrackme and exploreoz setup issue
Submitted: Wednesday, Nov 07, 2012 at 22:16
Member - cgmorg
I have been following the exploreoz Utrack me documentation to set up for tracking our travel. So far I have set up my iphone 4 with Utrackme and this seems to be working OK but it keeps having a pop up warning me to "register this device on my profile page".
Checking my profile page and going through to the Map page, under the map there is nowhere showing to register the device. Looking through the forums I have seen others have had similar problems and these have been remedied by the administration intervening.
I am only a newbie here so sorry if this is a "Dumb" query but could I please get some help with this.
Thanks a lot Glenn
Reply By: Sand Man (SA) - Thursday, Nov 08, 2012 at 07:14
Hi Glenn,
This worked for me.
"Once you have a compatible device setup (see further details below), it’s simply a matter of registering it on your Member Profile Page. To do this,
click on your “My Profile” tab, then
click the “View Public Profile” button.
Open the “My Map” tab then
click on the “Register” button that appears below your map."
498113
Follow Up By: Member - cgmorg - Thursday, Nov 08, 2012 at 07:32
Thanks for replying Bill, I have done the the first
3 steps OK but there is nowhere under my map to "Register".
What I get showing under the map is an advert then under this advert is the exploreoz menu system.
I am on a mac computer so I might try my windows computer later today and see if that makes any difference.
Thanks for your input
CU Glenn
774074
Reply By: ExplorOz - David & Michelle - Thursday, Nov 08, 2012 at 12:22
Glenn, (Right user this time)
I have found the problem - the other day I did some work on the members profile page and had commented out the display of the information as I was going to move it into the EOTrackMe tab - I have uncommented this for now and it is working again under the Map tab. So hit your profile at
http://www.exploroz.com/Members/276298.625/MyProfile.aspx and click on Map - you will see the panel and the resister option.
David
498134
