Liquid Filled 6000psi Water Pressure Guage
Submitted: Sunday, Nov 18, 2012 at 20:52
Member - kwk56pt
I would like to buy a " Liquid Filled 6000psi
Water Pressure Guage " Its for a bertolini 3000psi high pressure cleaner pump but rather than buy it as a spare part I thought someone might know where best to source one/ If you know other than the manufacturer where I can source the unloader valve that would be great. I am in
Perth WA,
Thanks Peter
Reply By: Gobumpy - Sunday, Nov 18, 2012 at 21:04
Hi Peter
I would be giving purple pig on kewdale road a try I have bought liquid filled gauges from them on numerous occasions before
Scott
498736
Follow Up By: Member - kwk56pt - Sunday, Nov 18, 2012 at 22:40
Thanks Scott, I had not heard of the purple pig before but its in the phone book. I see it does a lot of interesting products. I bought the pressure cleaner mainly to do the 4x4 and domestic cleaning. Seemed like a good idea at the time but the second time I used it I cleaned the inlet filter which was dirty. Checked the pressure guage to see what a difference it had made and noticed pressure was reading 100 bar instead of 200. Cleaning the filter has improved the flow.
It seems to still work ok but my experience is limited. Maybe the guage is faulty. I inspected the inlet and outlet valves and these seem ok. Maybe the unloader is partically recycling which it has to do when the trigger is released.
My web research, the stuff I should have done before buying reveals a lot can go wrong with these things and parts are not cheap. I will try another guage first, cheapest option and then tackle the unloader valve which is $250 for a new one but I will pull it to bits to see if it is sticking and can be fixed with some rubber grease.
I appreciate the pink pig tip Scott.
Cheers Peter
774739
Follow Up By: Gobumpy - Sunday, Nov 18, 2012 at 22:49
From my experience they not too bad on their pricing and good quality also another place to try for repairs is Eden in bassendeen I think it's on May Holman drive they do fabrication work and pressure cleaners i also have used them for service and repairs on lots of abused cleaners from a construction co. if ya need any more info feel free to ask.
Scott
774740
Reply By: Member - Rob Mac (QLD) - Monday, Nov 19, 2012 at 00:50
Hello Peter, try this company, I deal with the a lot here in
Brisbane through my work with Detroit Diesel lokng after workshop parts.
http://www.ifsaus.com.au/contactus.html
I have one of their liquid filled guages on my air
tank on my ute. They make a lot of fittings.
Rob Mac
498745
Reply By: burnsy - Monday, Nov 19, 2012 at 06:52
Just Google for Hydraulic workshops in your area and they will help you out.
498747
Follow Up By: Member - kwk56pt - Monday, Nov 19, 2012 at 22:22
Hydraulic Shops un my area was excellent advice, I wasnt sure whether they would do
water pressure guages or whether they are the same.
Thanks for all the suggestions.
Cheers Peter
774812
Reply By: Mogul - Monday, Nov 19, 2012 at 21:13
Try either:
JA Floyd in
Melbourne or Wika Gauges in
Sydney both are manufacture's and will make whatever you want.
498839
