Deodorant For `Home Brand` Nappy San?
Submitted: Thursday, Jul 11, 2013 at 17:14
Member - G.T.
I am using a `home brand ` nappy san in the Thetford in my caravan. This does quieten down the `long drop` smell that would be present if I didn't use it , but there is still a odour that is present , better than the long drop smell, but not all that acceptable. Does anyone know of a deodorant that can be added without upsetting the nappy san properties? As the home brand nappy san is cheap, $4.00 a container, I require something that is cheap as
well, prepared to pay something similar for a product that lasts approx. the same time as the nappy san, any ideas anyone?
Regards G.T.
Reply By: Member - bungarra (WA) - Thursday, Jul 11, 2013 at 19:39
we add to the above ......a couple of drops of eucalyptus oil and 1/2 teaspoon of citric acid......a better auroma
514639
Reply By: Sand Man (SA) - Thursday, Jul 11, 2013 at 20:53
Why not try a spray of nilodor as and when required.
We use it at home and have a bottle in the camper when out and about.
Nilodor eliminates odor, not just disguises it.
514642
Reply By: Motherhen - Thursday, Jul 11, 2013 at 21:36
Best action is to empty more frequently if odour occurs. You can add the powder every day if you feel the need to. We found a musty odour when we started out using BioMagic, but changing to the sodium percarbonate based nappy soaker powders stopped it. We usually empty after three days.
514648
Reply By: Notso - Thursday, Jul 11, 2013 at 23:10
Those "Nappy San"products will only work whilst there is available Oxygen in the mix. Organic matter uses it up very quickly. So I suspect that it would need to be added fairly regularly to achieve a good result.
514651
Reply By: Member - evaredy - Friday, Jul 12, 2013 at 09:44
We also use Nappysan but don't have any issue with smell. Are you using the correct mixture and how long are you leaving it before emptying?
514665
Follow Up By: Member - G.T. - Friday, Jul 12, 2013 at 16:07
I am using two capfuls after empting, and empty after two days, usually full by then. Odour is not diabolical, it is different and better than no nappy san, but could be improved on. May be I should empty daily, I am getting lazy since retiring! Regards G.T.
793763
793764
793765
Follow Up By: landseka - Saturday, Jul 13, 2013 at 13:31
If you Crap as often as you Post - no wonder you fill it in 2 days...
I just put 2 capfulls in after emptying then 1 capful for each #2.
It usually gets emptied about 4 days but can go a week if used lightly. By then it is getting a bit whiffy so it is emptied whether it needs it or not.
Cheers Neil
793836
Reply By: Tjukayirla Roadhouse - Friday, Jul 12, 2013 at 15:39
we don't muck around with that, we just use the chemical.
It does the job we pay for :-)
514680
Reply By: Member - evaredy - Friday, Jul 12, 2013 at 17:19
I would suggest that if it's full in two days, that you empty it daily.
514693
Reply By: Member - John and Lynne - Friday, Jul 12, 2013 at 17:20
You should not have any unpleasant odour if using Nappy Soaker correctly. If you check on Caravaners
Forum you will see more threads on this topic than you thought possible!
Firstly you need to buy a product with the highest percentage of sodium percarbonate - the active ingredient. Most No Brand products are good but read the label.
Then you need to always thoroughly rinse the cassette after emptying it.
You must pour one litre of warm
water into the clean cassette with two good capfuls of soaker to activate the product before using the
toilet.
You need to empty cassette every fourth day.
You can add a little extra nappy soaker each day but this should not be really necessary.
A very little eucalyptus oil will not hurt but do not add any detergents etc.
The chemicals sold at a vast profit by the
toilet manufacturers make the van smell like an old style
public toilet and are an environmental disaster. Sodium percarbonate will not harm a septic system and can also be safely disposed of in an old drop
toilet or a hole dug
well away from creeks and
camp grounds.
Good luck! Lynne
514694
Follow Up By: Fred G NSW - Saturday, Jul 13, 2013 at 09:30
Spot on Lynne. Most of the smell if there is any, will come from the bowl and the nooks and crannies in it so it is important to give it a good clean, as
well as the area between the two tanks at every empty out. The nappisan will only look after the bottom
tank. Try putting one capful in the top
tank when filling it.
Full every two days GT. Wow :-)))
Good luck with it.
793816
