Colorado 2014 Tub leaks water and dust in big volumes!
Submitted: Monday, Nov 03, 2014 at 20:02
Member - Boo Boo (NSW)
G'day all
While out at
Condobolin last week I took a dirt road to look at a few sights then went into
Parkes and got a car wash. Next morning I took the tonneaus off to load the baggage and found a lovely red paste in one third of
the tub.
An inspection revealed a gap of about 10 mm between
the tub and the tail
gate.
Has anyone had this problem and did you fix it?
Holden know of the problem but don't have a fix. They suggested I go to ARB as they have a kit that should fix the problem.
Reply By: BARRY F2 - Monday, Nov 03, 2014 at 20:25
Just Bought A Tail
Gate Kit For Our Bt50 From Auto Rubber In Bayswater , Living On A Dirt Road, It Has certainly stopped In Dust In
The Tub
541268
Follow Up By: hooks - Tuesday, Nov 04, 2014 at 09:52
Hi Barry,
Does this kit just fit around the tail
gate area or does it also go around the top rim of
the tub ?
827360
Reply By: darrell b - Monday, Nov 03, 2014 at 20:37
Hi BooBoo,
I have a 2012 rg colorado, current body shape, had the same problem,went to a large engineering outlet here in
griffith and purchased some rubber, similar to door rubbers, applied contact adhesive to tailgate and stuck it along bottom of tailgate where gap is,when dry close tailgate, hey no more gap.
getting the right thickness off rubber is the secret,
hope this helps,
Darrell
541269
Follow Up By: Con_Qld - Monday, Nov 03, 2014 at 22:36
Hi Darrell, I have a 2013 RG and took it up to the Cape and despite putting air-conditioning rubber to the tail
gate gap, I still had a lot of dust coming in thru the side and also from the gaps between the canopy and tail
gate. I had to run insulating tape on the outside each time I began my daily travels. It helped but ... Something I have to live with. Will try the rubber again like you said. Thanks for the advice....
ps. How are you finding the power & torque of the series 2?
827337
Follow Up By: darrell b - Thursday, Nov 06, 2014 at 22:53
Hi con, My 2012 Colorado is 5 speed manual,towing a jayco silverline, about 2900 tonne loaded, I find it tows the van reasonably easy, as long as I keep the revs in the motors torque band, eg 1800 to 2800 revs. Tow at 90 k per hour in 4 gear no trouble, nice amount of torque. heaps of power and torque without the van behind.
Returning 16 litres per 100 klicks loaded, I,m happy with the collie
Darrell
827486
Reply By: Nomadic Navara - Monday, Nov 03, 2014 at 21:55
All the Jap utes suffer from this. The way I overcome this is with a cheap tarp. I lay one end under the goods at the rear of
the tub. When I finish loading I then lay the rest of the tarp over the load.
When you require something from
the tub I simply just fold the tarp back and the dust comes with it. This may not be as good as going to all the trouble of fitting rubber seals but it is a good quick fix until members get around to applying their rubbers.
541272
Reply By: Member - mechpete - Tuesday, Nov 04, 2014 at 09:20
you could try Brown Davis in Bayswater Victoria they sell a kit to prevent dust entry for most late model utes about $65 .
cheers mechpete
541279
Follow Up By: Member - Boo Boo (NSW) - Tuesday, Nov 04, 2014 at 15:49
Thanks for the help fella's
I went to ARB in
Tamworth this morning and asked them for the kit to seal the tailgate and the thought I was mad. They had never heard of one.
I had thought of a rubber seal like the car doors, but I will give Brown and Davis a ring and see if they can help.
For around $65 it would be worth a try.
Once again thanks for your thoughts.
827385
Follow Up By: Member - Boo Boo (NSW) - Tuesday, Nov 04, 2014 at 15:57
Silly me........ it's a PH in Victoria today.
Will give them a ring tomorrow when they have a hangover. LOL
827387
Follow Up By: ian.g - Tuesday, Nov 04, 2014 at 16:22
I use a length of concrete expansion foam 70mmx10mm, can be bought in 6m rolls for about $5.00 from Bunnings, just cut to length and close into
the gap, works a treat. Throw away after each trip and cut a new length when you are going into dusty conditions again.
Ian
827388
Reply By: get outmore - Wednesday, Nov 05, 2014 at 20:49
leave the tarp off ... it reduces the dust in
the tub immensely
541346
Follow Up By: Member - Boo Boo (NSW) - Sunday, Nov 23, 2014 at 20:26
I finally installed the rubber kit a couple of days ago and will give it a week or so and let you know if the problem as been eliminated or reduced.
828343
