Thetford toilet
Submitted: Sunday, Mar 29, 2015 at 11:59
ThreadID: 117269 Views:3291 Replies:4 FollowUps:5
Hi we have in our van a thetford toilet with a pull out cassette which we take to dump point to empty and have only ever used it for numbers ones can you use them for number twos and if so is there any special solutions to use to break it down to stop any odours
Thanks Greg
Reply By: Sand Man (SA) - Sunday, Mar 29, 2015 at 12:49
Hell yes Greg, definitely number twos. (Aren't they what they are really for?)
As far as solutions go, there are commercial Thetford products available, but the older Green solution is frowned upon because it contains formaldehyde, a quite nasty product both for ourselves and the environment. Thetford also produce a Blue solution which is supposedly more environmentally friendly.
But the cheapest and most effective product plain old Nappisan.
about a lid full in the bottom tank is all that is required. The prime ingredient in this product is Sodium Percarbonate which actively oxygenates the tank contents to quickly break down solids. A product with around 34% SP is best. Home brand Nappisan used to be the recommended one but recent changes to the SP percentage have now superseded this one in favor of others.
I now use Coles Ultra Booster Advanced Oxy.
A drop or two of euclyptus oil can be added to help eliminate any odors if you wish.
Member Motherhen has created a blog giving up to date information on different products.
Toilet Chemicals Blog
Bill
AnswerID: 551742
Reply By: Member - Chooky and Wobble - Sunday, Mar 29, 2015 at 12:57
Yes you can use it for number2's. We use the green Thetford product as it is supposed to be septic safe. We also usethe pink product in the flush tank. (Ours has a seperate flushing water tank) A lot of people make up there own using things like napisan with sweet smelling aditives like eucalyptis. We use the thetford product as we only do a small number of trips in the van. If you travel a lot then making your ownwould make sense. There are lots of things in forums just search here or google caravan toilet chemicals. I am surprised that the instruction book from thetford didnt explain it all.
AnswerID: 551743
Follow Up By: Member - Chooky and Wobble - Sunday, Mar 29, 2015 at 12:59
I ment the blue one
FollowupID: 837254
Follow Up By: Tom D - Wednesday, Apr 01, 2015 at 14:48
I don't think these ppl are ignorant of the usage of the toilet. I just think everyone is trying to make ends meets and saving a dollar here and there helps in the long run.:)
FollowupID: 837437
Reply By: MEMBER - Darian, SA - Sunday, Mar 29, 2015 at 14:08
We have used Thetford blue but are about to trial the BioMagic granules shortly - the attractive thing about the granules is that the pack is so small (compact for camping)....a little bit is supposed to go a long way. As for the Thetford pink flush addidtive - we had to stop using it because it promoted the growth of black algae in our flush tank.....I now add cheap supermarket disinfectant (generic Dettol types) to the flush water....just a cap full / litre works a treat.
AnswerID: 551750
Follow Up By: Member - Chooky and Wobble - Sunday, Mar 29, 2015 at 17:44
You have answered an issue we have been having with black alge in the flush tank. I thought it might have been the water. I just flushed it through with weak domestos solution.
FollowupID: 837268
Follow Up By: MEMBER - Darian, SA - Sunday, Mar 29, 2015 at 22:04
It appears that warm weather is the problem with the pink flush...ok in a cold climate...I tried a bit of disinfectant with it but that created a claggy sort of by-product (chemistry !....what pain). Anyway......plenty of users have dumped the pink flush and are quite happy with plain water...it was probably all marketing in the first place.
FollowupID: 837275
Follow Up By: Member - Chooky and Wobble - Sunday, Mar 29, 2015 at 22:09
Thanks for the info will follow it up
FollowupID: 837276
Reply By: Motherhen - Sunday, Mar 29, 2015 at 20:23
Hi Greg
Please read My Blog on Toilets and consider the environment. If only for #1's, you can empty it every day or two such as in public toilets if no dump point easily available with no use of additives.
AnswerID: 551761
