Tuesday, Aug 04, 2015 at 08:25
Hi Ania
The Pajero will be fine for your trip. The vehicle should be normally equipped with a spare and a jack but check when you hire it
1) The most important thing is that Britz know the roads you will be travelling on with that vehicle...some hire vehicles are not equipped or allowed to travel the GRR or the Bungles
2) Some hire companies do supply some of the recovery equipment that you have listed...you need to check so you don't waste money purchasing items you don't need
3) As for spares the minimum I suggest you carry is at least 2 spares of which perhaps only one needs to be fitted on a rim and that would be normally supplied with the vehicle.... Perhaps try and purchase a 2nd hand casing from a tyre company if the hire company wont supply a second one for you
4) I am assuming you will be only staying on or near the GRR and in/out the Bungles and so considering you will be flying in and out I would keep the expenditure to the basics as the chances of you requiring the serious recovery equipment is very unlikely (straps, winch snatch strap shackles etc)...so to avoid wasting money on items you cant take home or recover your costs on I would take with me the following
* spare 2nd tyre ...on a rim if possible but at least a 2nd casing and a fellow traveller may have the tyre levers to help you change onto a rim if needed
* a tubeless plug repair kit...assuming the tyres are tubeless.... ( get a decent one ARB or similar that is not a cheap plastic handle that wont have the strength to insert the plug into a 4WD tyre
* a compressor...don't spend too much on this you may not use it or if you do you don't need one that is very fast....just one that pumps air
* a long handled shovel/spade
*Jerry cans.. number for you to decide once you know the
fuel tank size and the longest distance between fill ups....(not a lot of options on the GRR)...also never use your last one if you can help it....a hole in the
fuel tank from a rock can happen...if it does make a paste from soap and fine dust and plug the hole and let it harden.
water...make certain you have plenty of
drinking water per person
* sunscreen and hats and personal drinking bottles...some of the hikes into the features are longish and you can dehydrate easily
* a handheld UHF would be handy but not essential
* If you are not careful you will spend a lot of money on recovery gear you may never need and have to leave behind when you fly home
* take plenty of common-sense...a good sense of humour...
fuel,
water, spare food ...interact with fellow travellers...don't be afraid of asking advice and help if you need it....as long as you were
well prepared and didn't bring any misfortune on yourself by being under prepared and take silly risks then any fellow traveller will stop and help
Ania... your proposed journey is not really into isolated country...there will be other vehicles travelling the same time and often each day..........apart from running out of
fuel your most likely trouble will be rock/stone damage on your tyres......so keep your tyre pressures lower on the rocky country so the vehicle doesn't shake itself to pieces...slow down and drive according to the conditions and don't spend a fortune on recovery gear that you most likely wont need....I carry all the spares and recovery you can think of and have travelled the roads you are talking about several times and never even had a puncture or a tyre issue...but others are not so fortunate
enjoy......
PS.... if you intend crossing the
King Edward River and travelling to the
Mitchell Falls...then those of us on this site may add a few more comments to what we have advised so far
856626
