Thursday, Nov 05, 2015 at 18:42
G'day again Lenn . . . I would allow 4 days / 3 nights in
the desert first trip in the cooler months.
Day 1 leave
Birdsville, not rushed (in fact none of this would be rushed), Big Red play,
camp QAA Line past Eyre Ck (though it's still Adria Downs property, if you are good campers, no trace, lots of people do this), or just into QLD
Simpson Desert Nat Pk (small fees to
camp).
Day 2 Peoppels Cnr visit, side trip to the Knolls,
camp near top of Knolls Tk or just west.
Day 3
camp somewhere just before the Witjira Nat Pk, so you can ave a last campfire in
the desert.
Day 4 drive out, swim Dalhousie, drive via Bloods to Mt Dare.
That's say 550km with a little corridor driving looking to
camp etc.
Take it really easy on the fast pedal, with low pressures (18psi or so) you should do dunes pretty easy one go.
If not, a simple back down and another shot with a little more momentum.
I would take 70lt main
tank and 4 x 20lt jerries minimum Lenn, you'll be surprised how much you might use, and you need a buffer in case of detours / hold ups at dunes (traffic !).
50 to 60 lt of
water should be ok, 5 or 6 10lt casks spread on the floor of the cab usually easy to fit in.
Do you have a roof rack ?
If so, a couple of full jerries and then the empties can go on the roof and stay there for the remainder of the trip.
Camp light, take only what you'll really use / need (plus some things you don't want to need like
first aid, fire ext, etc).
As for the rest of the trip, depends on you and the missus I guess.
Do you like driving longer days, or short days and explore a lot ?
After
the desert, a run down the
Oodnadatta Tk to
Marree is very worthwhile to form a loop home.
This could be done even with your red centre trip after . . .
Maybe up through NSW Qld (Dubbo,
Bourke,
Wanaaring) to Cam Cnr and
Birdsville as described, down the Ood Tk, Northern Flinders, out to
Yunta on the Barrier Hwy then home via
Broken Hill to join up loop at
Nyngan ?
You could do
Newcastle to BV in 4 days relatively unrushed, 4 days desert, 3 days to Alice, West Macs /
Palm valley 4 days, Kings Canyon 3 days, 3 days for Uluru /
Kata Tjuta (West Macs / Kings /
the rock inc travel), down to
Kulgera, down to
Kulgera, across to Finke (Lamberts centre detour ?), and back to Mt Dare, say 3 days, 3 days to
Marree, another few days in the Flinders, 3 days home = ~ 4 weeks.
Some more time in the Flinders might be nice, maybe a week if ou feel like really getting into it and seeing it
Stockton when soft will give you some sand practice, and maybe a very small idea of
fuel use pushing through sand at low psi tyre pressures.
I drove it November last year, it was hot, couldn't walk on sand barefoot without burning.
The locals I was with said they'd never seen it so soft, and it was :)
If you filled
tank, drove it soft one end to the top and back, filled up again and worked out lt/100km from that, it would give you a slight idea of how much you're using.
Not scientific, and the dunes (1100 of them) of the Simmo will use quite a bit more, it will perhaps help envisage the needs.
Anyway, happy planning.
860566
