D_MAX Canopy kits
Submitted: Wednesday, Nov 16, 2016 at 06:48
Member - TonyL2450
I have heard that Sealing kits for Dmax utes making it dust proof when a after market canopy (ARB) is fitted.
Have tried Clarke Rubber bits and pieces short lived.
Any thoughts please?
Reply By: raincloud - Wednesday, Nov 16, 2016 at 08:04
Brown-Davis produce seal kits for ute tailgates about $70 just google brown davis tailgate seals. Don't know how effective they are but will order one for my Hi lux
605922
Follow Up By: Kazza055 - Wednesday, Nov 16, 2016 at 10:05
I have used Clark Rubber with success, 25x25mm black rubber did the trick.
Need to run it down the sides and across the bottom.
You will still get some dust come in, probably using a roof vent to pressurise the canopy would help as
875712
Reply By: Sand Man (SA) - Thursday, Nov 17, 2016 at 14:23
Tony,
Rather than trying to seal the canopy, think about pressurising it to restrict dust entry.
ARB supply a vent for their canopy for just this reason and it works.
Airflow into the vent creates a positive pressure inside the canopy and thus restricts the entry of dust.
The only thing I get is a minor layer of dust along the bottom of the tailgate and this is easily brushed out.
605967
Reply By: Member - Gary R M (VIC) - Friday, Nov 18, 2016 at 15:23
Hi Tony, if you have a sliding window on your canopy slide it open one notch, this pressurises the canopy sufficiently so you'll eliminate most of the dust problems.
Used this method for years on my old BT50 and it works fine on my new D Max as
Regards, Gary M.
605992
