Deua NP
Submitted: Monday, Feb 28, 2005 at 14:56
Member - Landie
Is it doeable from
Sydney on a weekend, assuming early start Saturday, late finish Sunday? Or is it pushing it too much.
Thanks in advance.
Reply By: Well 55 - Monday, Feb 28, 2005 at 15:00
Depends on which way you go in , but yes doeable.
100502
Follow Up By: flappa - Monday, Feb 28, 2005 at 15:03
Which way do you think would be better ?
I have been in from the West side (from
Canberra) , and been out via
Moruya. Never been in via Arulyen ?
Moruya would probably be the easiest way in , but , the extra distance ??
358656
Reply By: flappa - Monday, Feb 28, 2005 at 15:00
Yes.
I'm not sure which way would be the best way to go in , but , Yes , its possible for a weekend. (long weekend would be better obviously).
100503
Follow Up By: Well 55 - Tuesday, Mar 01, 2005 at 06:59
The track in from the north is ok with clearence and good tyres, it takes a lot longer as it can be slow going at times. A good drive if you have the time.
358765
Reply By: Baz (NSW) - Monday, Feb 28, 2005 at 15:01
Hey Barry it takes 3 hrs from
Sydney to
Moruya then depending on where you are going in Deau NP, if Bendethra about 30 to 45 min into the
park, it is worth it though.
Baz.
100504
Reply By: Member - Willie , Epping .Syd. - Monday, Feb 28, 2005 at 15:02
If you are talking about Bendetherra it is certainly doable , but not too relaxing .
It would be tough if you came in or out from the west because it takes twice as long . From
Moruya it is about an hour to the
camp site .
Willie .
100505
Reply By: Wayne (NSW) - Monday, Feb 28, 2005 at 15:37
Baz,
Look in Trip Planning under
Bendethera Valley.
If it gets wet go out via
Moruya and the camper trailer wll have to stay at home.
Wayne
100513
Follow Up By: Baz (NSW) - Monday, Feb 28, 2005 at 15:43
Yeah Barry, Wayne is right not campertrailer friendly when wet because of how steep it is can be a bit hit and miss sometimes.
Baz.
358665
Follow Up By: Baz (NSW) - Monday, Feb 28, 2005 at 15:45
Thats Bendethra only, other parts of the
park are OK, NPWS normally close the road into Bendethra after rain.
358666
Follow Up By: Moggs - Monday, Feb 28, 2005 at 23:31
Th Pathfinder Club were down there in January and it isn't too bad a trip if you are coming in via
Moruya.
As for taking trailers - not a problem wet or dry via the
Moruya route - that is if you have a decent set of tyres on. 3 of us left after 2 days of rain, all towing trailers and got out fine - 1 of the trailers was 1,200kgs, being pulled by a Pathy with Cooper St's. The Pathy towing with HT tyres on slipped a bit, but after lowering pressures got out no problem. All too easy! I reckon if you are towing a trailer it is about 1 hour 20 minutes to the
campsite. Those in the Pathy club who left
Sydney early arrived about 3.00pm at the
campsite.
358754
Follow Up By: brett - Tuesday, Mar 01, 2005 at 00:22
Towed my trak shak out via
Moruya after rain night before and a bit in the morning, wasn't too wet, ground seemed to soak up most of it. NP pajero with Cooper ST's.
358758
Follow Up By: Penguin (NSW) - Tuesday, Mar 01, 2005 at 12:32
Hey Baz,
It's not really that bad if you have 4wd. :-)
358803
Reply By: snailbate - Monday, Feb 28, 2005 at 21:28
HI LANDIE
Go to www.lroc.au.com and have a look there you will be out of the wilderness
LAND ROVER OWNERS CLUB will see you through with all thaose odd quectiones
SNAILBAIT
100576
