Cordillo Downs Road
Submitted: Sunday, Oct 09, 2005 at 10:34
Wes L
We are planning a trip from
Broken Hill -
Tibooburra -
Innamincka -
Cordillo Downs -
Birdsville -
Longreach. Can anyone tell me if a camper van could do this trip and if so would a off-road campervan be essential or could a on-road model get through. Thanks.
Reply By: Member - Stan (VIC) - Sunday, Oct 09, 2005 at 10:50
If it is dry, you should be able to get through from
Broken Hill to
Birdsville in on-road model if you take it slowly, but I would not recoomend it. Don't know what is the road like to
Longreach...
133745
Reply By: mattie - Sunday, Oct 09, 2005 at 10:59
Hi Wes
I have not been from Tiboorburra-Brokenhill but the rest of the trip is not rough if you just poke along, lots of rocks from
Innamincka -
Cordillo Downs and part way to Bridsville. Although the road is not rough it would unadvisable to tow a campervan or trailer that is not set up for offroad work as the stones or rocks being flicked up by the tow car will cause damage without the vibration. We have an off campertrailer and would have no hesitation towing it along this route.
Cheers Mattie
133747
Reply By: Member - Crazie (VIC) - Sunday, Oct 09, 2005 at 12:49
road is ok, gets better when you cross the border into qld
133758
Reply By: Steve - Sunday, Oct 09, 2005 at 15:56
Reply By: GREENDOG - Sunday, Oct 09, 2005 at 17:49
We have done
Walkers crossing twice now and have found it to be a nice drive on driver and vechile 6 hrs from
Birdsville to Innamicka with a C/T best of luck have a nice trip cheer's GREENDOG
133774
Reply By: Sand Man (SA) - Monday, Oct 10, 2005 at 11:08
Wes,
What is your definition of a Camper van?
I owned a "Camper van" once. It was a Toyota Highace 2WD Diesel and although it had a higher ground clearance than a standard car, it was not an "Off Road" vehicle. Many of the roads in that area are across gibber plains and you really need the extra protection offered by a true "Off Road" vehicle. Some sections can be either soft, or boggy and the ability of proper 4WD will soon be apparent.
Now, if you mean a Camper Trailer towed behind a 4WD vehicle, then I would suggest again that you consider an 'Off Road" version trailer which not only gives you the extra ground clearance, but more rugged
suspension, etc.
A little trip along the corrugated sections and you would soon agree with the wisdom.
Have a good trip.
133893
Reply By: canpin - Monday, Oct 10, 2005 at 19:23
Wes,As others have said the
Walkers Crossing road is the way to go. However you will need to check the weather as this road was closed when we were there 3 weeks ago. It is only 320 kms compared to 430km for
Cordillo Downs. We had to drive this road as WC was closed, it took us 11 hrs with 3 vehicles (no trailers) the locals said in good weather it should take 7 to 8 hrs. Truckster is right in that the road south of the border is the worst, it goes gibber for 150 k's then sand with corrigations then dirt into Innaminka.
You can do it , but take it real slow or better still go
Walkers Crossing, the view is better as you follow
Cooper creek for some of the way.
cheers 26780
Craig
133993
Reply By: redfive - Monday, Oct 10, 2005 at 19:32
Hi Wes
I just got back last week from a trip across the simpson ayers rock and so on we drove to
birdsville via
walkers crossing and unless its dry up alot theres no way i would take a camper trailer in there we help a english bloke out with his camper as he was bogged to the axles took about 1 hour to get him out when we got to
birdsville we told the nat/parks guys and they shut it that night the 18th sept the
cordillo downs road also was a bit wet and very rough talking to fellow campers in
birdsville and all this depend on how off road is your camper if its a on road model leave it at home or get a off road one on our trip we saw 3 trailers by the side of the road broken in half hope this doesnt put you off but please think about it before you leave home
Glenn...
133996
