Sunday, Jan 19, 2003 at 18:36
Sean, Ray was not having a go at you, he was commenting on the clatter and interference from the monkeys gallery. Ray is always polite. A little misunderstanding - no bother. The monkeys gallery can never help anybody, they just make a raucous and disturbance as they are clueless on everything.
Sean it is difficult on a van of that size with a single axle to get much below the tyre pressure you are running. Is that a radial tyre or a rag tyre?
180kg is pretty solid tow ball weight as
well for that size.
Not a lot you can do with a single axle with 14" tyres with that sort of load on them.
If you intend keeping the van, and you have enough space in the wheel
well of the caravan, you could go to a 15" wheel and a radial tyre to carry that sort of load, which would not need such high pressures.
On the last 22' caravan I had made, I put on 15"
wheels and radial tyres and lighter springs with Aeon air ride springs and shock absorbers which was a big improvement over standard caravan set-up. I was doing a lot of distance at that time on the black top, but often off the main highways and needed to keep the van together. Now the kids have gone, we are going to a 17' maximum this year. We just take our 4WD which is very
well fitted out to go on the bad unmade roads.
6445
