Saturday, Jul 14, 2007 at 19:51
Hi Kev,
I have a Challenge offroad, which is a 7 x 4 trailer and 10 ft tent off the side. There's generally not a problem finding a space to
camp, but it does need to be relatively level without too many rocks etc. There is probably an advantage with a solid floor type off the back as rough terrain is not so critical, but that's all part of the personal choice you need to make. We prefer the extra tent space with the tent off the side, even though it is sometimes more difficult to find a large enough clear, level spot. Having said that, we have always found somewhere eventually to set up.
You also have plenty of choices with kitchens - swing out vs slide out for example - once again, personal choice as to which suits your circumstances best.
I suggest you insist on a good size
water tank and try and ensure that the tailgate and any other openings and boxes have really good dust seals - some of the cheaper trailers have no dust seals at all and believe me, you will regret not having them!
If possible, try and get
wheels that match your car, or are at least interchangeable so that your spares will fit both the trailer or car - saves taking extra spare
wheels. With regard to
suspension, I personally prefer a simple solid axle system rather than some of the fancy independant setups, although there are some good systems around. If it has coils, then make sure it has good shockers as
well and make sure that the
suspension travel is not simply limited by the shockers - it should have limiting straps or chains. I have seen springs fall out when shockers break! If it has leaf springs, then shockers are not as critical, providing it has good rebound springs fitted. I have no shockers on
mine and have had no problems, even over the roughest of corrugations.
I would avoid anything with a huge amount of stuff on a really long drawbar, such as fridges, jerry cans and boxes etc unless it can be demonstrated that the ball weight is not excessive when fully loaded. Ideally, the ball weight should be about 10% of the overall trailer weight. My preference is a good size box on the drawbar to house the battery and other gear, but have the jerry's and even the gas bottle, along the side of the trailer - others may
well disagree - once again, personal preference. Remember though, excessively long drawbars will reduce your ramp over angle on
sand dunes and
creek crossings. Spare
wheels are also often mounted on the drawbar, which is really convenient compared to underslung.
If you can get one with a battery setup for lighting etc., it makes it really convenient for lighting and running other appliances.
Also, be a bit choosy with the canvas as some of the cheaper trailers use some fairly ordinary stuff. There is no substitute for a good quality, heavy canvas tent, especially when you find yourself in the middle of a downpour. Australian canvas seems to be really good in terms of durability and weather protection. The other thing you may want to look for is whether the floor vinyl extends up the sides of the tent for a few inches. This keeps the
water out of the tent during severe weather.
Have a good look around as there are some good second hand bargains around. Buying used can save you heaps, leaving you more money to spend on
fuel and other
camping gear.
Good luck - I hope you find exactly what you want.
Gerry
252404
Follow Up By: Kev. (Cairns) - Sunday, Jul 15, 2007 at 18:58
Hey great info on the
suspension there mate, will keep that in mind along with dust seals etc.
Cheers.
513637
