Towing c/van with L.E.D lights
Submitted: Saturday, Dec 01, 2007 at 14:19
ThreadID: 52151 Views:4186 Replies:7 FollowUps:7
I have a new disco 3 td6 and have just taken delivery of a new c/van fitted with LED lights. DISCO wont have anything to do with leds.Both turn indicators flash when driving .Anybody had this happen,if so feedback on rectification would be appreciated.
Reply By: Member - 'Lucy' - Saturday, Dec 01, 2007 at 14:34
Norm
The Disco would have no idea what it is attached to it or what its trying to operate.
Your problem will be in the wiring on the new van and its compatibility to what is offered in the Disco outlet.
(1) Check and make sure the Disco outlet is wired correctly including an independent earth.
If you 100% sure all is correct on the vehicle then:
(2) start checking the van by using an independant battery as the power source to establish the the van is wired 100% correctly, in particular the earthing side of things.
AND
Operating correctly (ie no shorts or earth problems)
if so:
(3) It then has to be in the plug/socket/connectors somewhere.
Failing all of the above - tip a bucket of petrol over vehicle and van set on fire and start again (LOL)
Ok! you won't do that but you will feel like it.
I am sure you will find the problem well before that stage.
Happy hunting
AnswerID: 274544
Follow Up By: Member - 'Lucy' - Saturday, Dec 01, 2007 at 15:25
Norm
After reading that link from the Disco specialist Autolec , please disregard the above.
Would seem that the Disco's have all sorts of levels of electronic 'embuggerances' built in to confound anyone who should have the temerity to think anything else other than RR.
I have the latest JEEP which is full of electronic crapola, however it has no problems whatsoever with LED'S on the CT.
Have a good one
FollowupID: 538137
Reply By: Member - John - Saturday, Dec 01, 2007 at 14:35
g'day, your van should have been fitted with resistors to mimic the load of normal globes. Fittiing these to the van lights will make it all work properly. They are available at auto stores or auto lecs.
John and Jan
AnswerID: 274545
Reply By: Redback - Saturday, Dec 01, 2007 at 14:52
Norm there is a device that you can buy to stop this, the guy who makes this is in Sydney, if you ring Tivett in Parramatta they will give you his details, i would but i can't find them.
If i find his details i'll put them up here.
Or go to this website;
D3 Zone
Baz.
AnswerID: 274546
Follow Up By: Redback - Saturday, Dec 01, 2007 at 14:53
Trivett in Parramatta it should read
FollowupID: 538131
Follow Up By: Redback - Saturday, Dec 01, 2007 at 15:00
OK i found his web page, this solves your problems, he developed this for the D3 and RR for Land Rover Australia.
Labtronx, Lee Bourgeois
Baz.
FollowupID: 538133
Reply By: Member - GeeTee (NT) - Saturday, Dec 01, 2007 at 15:08
Hi, Is this a common problem with all vehicles??
I am waiting delivery of a new van that has LED's and will be towing with a Nissan patrol (2007).
AnswerID: 274549
Follow Up By: Sand Man (SA) - Saturday, Dec 01, 2007 at 16:01
GeeTee,
Not common at all.
I upgraded the lights on my Camper Trailer to LED's after continual faulure of the old ones.
The Jack is very happy with them. He says he doesn't have to work as hard as the resistance is lower.
Reckon I'm getting better fuel economy as a result:-))
Well, at least nobody is telling me that one light is not working, or that one is not as bright as the other.
There are no globes to "blow" either.
Bill
FollowupID: 538144
Reply By: Member - Norm H (QLD) - Saturday, Dec 01, 2007 at 15:37
Amazing l/rover havenot done anything to rectify led problem any
how thanks for all who responded.Will check them out.
rRegards Norm H.
AnswerID: 274552
Reply By: Member - Shane D (QLD) - Saturday, Dec 01, 2007 at 16:19
A cheap fix is to wire an incandescent globe/light some where with in the blinker circuit to "load up" the system, I did this when I put LED on the rear of my truck and found the blinker flashed fast indicating a blown globe (because LEDs draw stuff all power) so I wired a repeater blinker (on the side) with the old school globe and fixed the rapid blinking, If I where in the same situation I would at least try using and another trailer with incandescent globes to see if problem still exist.
Shane
If the extra globe fixes the prob you don't HAVE to mount it ON the van,
AnswerID: 274554
Follow Up By: Redback - Saturday, Dec 01, 2007 at 16:59
Doesn't work on the D3/RR
FollowupID: 538155
Follow Up By: Member - Vince B (NSW) - Saturday, Dec 01, 2007 at 17:23
Hi Shane.
The local RTA inspection site at Chinderah had a field day on some trucks fitted with LED blinkers. The lights were blinking"too fast" & the owners were forced to rectify the problem similiar to your situation.
Regards.
Vince
FollowupID: 538159
Follow Up By: Member - Shane D (QLD) - Saturday, Dec 01, 2007 at 20:05
You can get LED dedicated flasher units, for a price, but I'm not sure how they go lighting up globes
FollowupID: 538176
Reply By: Mark Taylor - Saturday, Dec 01, 2007 at 16:58
The Disco 3 tests the trailer blinkers by pulsing them continously to check for an open circuit or blown bulb. This has no effect on a normal incandescent bulb but will cause the led lights to flash.
Check disco3.co.uk forum and you will find a thread on this. You will like you new disco once you have this sorted..they do to well.
Mark T
AnswerID: 274556
