GU 3Litre
Submitted: Tuesday, Jul 08, 2008 at 20:39
stephen85
I have a 2001 model GU 3L with 201000km on the clock. In the last month I have started to notice a significant decrease in
fuel economy. Also the intercooler hose has developed a weep. Can anyone give me feedback on this
Reply By: guzzi - Tuesday, Jul 08, 2008 at 21:04
The guru's reside here;
http://www.patrol4x4.com/forum/index.php
The 3 ltrs dont have a very good rep, that being said you have over 200,000 km, injectors,
fuel pump, maf sensor, valve clearences and any other items of the electronic
fuel injection may all need checking.
Good luck with it.
314462
Reply By: Member - Madfisher - Tuesday, Jul 08, 2008 at 21:17
Stephen while you are waiting for a 3lt expert may I suggest you do a search though the archives on this site for 3lt problems. Also their is a dedicated Patrol
forum.
I would suggest that you do not drive it till you get some expert advice.
goodluck Pete
314465
Reply By: Member - Matthew C - Tuesday, Jul 08, 2008 at 21:39
What state are you in??????
Matt
314470
Reply By: Member - AJB (VIC) - Tuesday, Jul 08, 2008 at 21:53
Dirty
Fuel Filter. Split hose/Loose Clamp. Hope it is that easy!
314477
Follow Up By: Member - AJB (VIC) - Tuesday, Jul 08, 2008 at 21:54
Or air Filter
580490
Reply By: Member - Bentaxle - Wednesday, Jul 09, 2008 at 10:52
Stephen where is the intercooler hose leaking from? If it is where the rubber hose joins onto the metal pipe on the intercooler, and the intercooler has been removed recently then you will need to separate the two parts and wipe the inside portion of the rubber hose and the outer portion of the metal pipe with acetone to to ensure that they are both completely dry and free of any oil residue or mist and rejoin and clamp the hose. The reason I said use acetione to clean is that it will remove any oily residue an leave both parts completely dry and when they are rejoined they will not weep oil. Power loss, when did you last replace your MAF Sensor above the aircleaner unit? I replace
mine at regular intervals (cost approx. $320), despite what is said you cannot succesfully clean them. MAF's can be the cause of power loss because it is sending the wrong signal back to your ECU.
Mike
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
314513
Reply By: Member - 120scruiser (NSW) - Wednesday, Jul 09, 2008 at 13:50
A mob I get my MAF sensors from is in
Sydney called AFI,
Good price and they know what they are talking about,
AFI (Australian
Fuel Injection)
(02) 9897 992220
wentworth St
Granville NSW 2142
No affiliation just a customer of all efi components
314537
Reply By: Louie the fly - Wednesday, Jul 09, 2008 at 18:06
Why would you get oil in your intercooler? Isn't it only the air from the air filter, after its been through the turbo, that goes through the intercooler. I would have thought oil in your intercooler suggests a problem. Where is the crankcase breather plumbed into on these engines?
I read a post about someone making an oil catch can for one of these. Just did a quick search but couldn't find it.
314573
Follow Up By: guzzi - Wednesday, Jul 09, 2008 at 20:22
The oil is generally from the crank case ventilation system.
An air oil separator and catch can is apparently a good idea.
Occasionally though its the turbo leaking oil, but not very often.
These also get a large build up of carbon, oil and mank around the throttle body which can also effect performance and economy.
580621
Follow Up By: Member - Bentaxle - Thursday, Jul 10, 2008 at 11:59
The crankcase breather hooks into airfilter housing.
580693
