Tuesday, Jul 29, 2008 at 20:19
Trish,
I'm not a "doomsdayer" and should you decide to travel the
Bore Track, you may decide it was worthwhile.
Only you know your Van and how it will travel over corrugated roads.
It's not the
suspension you need to concern yourself with, but the contents of the cupboards in your van. If they are secure when the top is closed and built for the rough stuff, then you should be OK, but I have also heard of vanners who have experienced cupboards literally falling to pieces on corrugated roads.
As I have stated, the southern section of the Track on Bollards
Lagoon Station can lure you into a false sense of complacency, then you reach the Regional Reserve section, where the Track is rarely (if ever) graded and things can be somewhat different.
Others have mentioned a few
washouts, where the road has been eroded consinderably and care must be taken to travel at a speed where you can adjust and change direction, or your approach angle to suit the circumstances.
If you have confidence in the build quality of your van, then you should be OK, but I would recommend you give yourselves plenty of daylight time to travel the Track.
Bill.
584358
