tyre bead breakers
Submitted: Thursday, Aug 28, 2008 at 18:00
ThreadID: 61163 Views:3600 Replies:5 FollowUps:11
G'day again question for current or former military transport types in EO land what type tyre breaking equipment/tools are used on split rims.
Reply By: Sand Man (SA) - Thursday, Aug 28, 2008 at 18:24
Why the military transport prerequisite?
I have split rims on the camper trailer.
No special tools required at all for disassembly or reassembly.
Bill.
Bill
AnswerID: 322680
Follow Up By: cooperdog - Thursday, Aug 28, 2008 at 19:54
Hey Sand Man,
Military, use Keep It Simple Stupid reasoning for most things.Yes I agree usually only screwdriver hammer and tyre lever needed but after i spent 3 hours trying to break a bead on a split rim even with jack under tow bar of cruiser I thought must be a easier way. Never had that much difficulty before then found out tire was pumped up on tube for at least 10 years and was welded to rim.
FollowupID: 589736
Reply By: Sir Kev & Darkie - Thursday, Aug 28, 2008 at 18:48
The Military system is now supplying Tyrepliers as bead breakers.
It is the 13" - 25" rim bead breaker that is in the kit.
Cheers Kev
Russell Coight:
AnswerID: 322684
Follow Up By: pjd - Friday, Aug 29, 2008 at 13:22
thats right the army will only use tyrepliers
& the nato no for them is 5210/66, 128,8,500
if your in the defence force just order that number
FollowupID: 589865
Reply By: MrBitchi (QLD) - Thursday, Aug 28, 2008 at 19:58
In my day it was a 5 ton truck :-))
Lay the tire on the ground and drive over it...
AnswerID: 322702
Follow Up By: MrBitchi (QLD) - Thursday, Aug 28, 2008 at 19:59
Tire??? Should read "tyre" :-/
FollowupID: 589737
Follow Up By: cooperdog - Thursday, Aug 28, 2008 at 20:14
G'day John yes driving over it would have been done if it was urgent but was just taking casing off to use as a 2nd back up. I cant spell but can lift heavy objects.
CD
FollowupID: 589744
Follow Up By: 2TommyGuns - Thursday, Aug 28, 2008 at 21:56
CD.
I've seen det cord used for the problem you had, admittedly it was a tyre off an earth moving scraper, but non the less the end result would have been the same... Jest never know when ya wanna blow sumpin up aye!! Don't leave home without it.
Cheers 2TGs
FollowupID: 589794
Reply By: Member - Phil G (SA) - Friday, Aug 29, 2008 at 00:12
Like you say, they get stuck on after many years.
When like that, I run around the whole of the bead with a high lift to try to get the bead to move down, but if it won't move down, I have some pieces of 19mm thick wood that I slip in to hold the bead down, so I can lever out the split.
I'm sure there are other tricks, but fewer people using splits these days.
AnswerID: 322749
Follow Up By: tommytom13703 - Friday, Aug 29, 2008 at 01:05
Phil has a good point there as i have seen use his method in the past with the old hi lift. im not sure i R7R beadbreakers will do the job, but contact Adrian, who can be found at the Terowie road house SA for another point of view.
Ricky
Follow Me 4wd
FollowupID: 589813
Follow Up By: Member - Phil G (SA) - Friday, Aug 29, 2008 at 10:07
Gday Ricky,
I've never seen the R&R man demonstrate his beadbreaker on a splittie. You'd be wielding that ring spanner a heap I would expect.
Hope your business is growing well. You should join Exploroz as a corporate member.
FollowupID: 589845
Reply By: brushmarx - Friday, Aug 29, 2008 at 08:59
I saw a chainsaw used on a truck tyre at 21 Construction at Pucka.
New tyres (and chainsaw chains) didn't cost anything in the Army, they just turned up whenever they were needed. Some sort of green fairy magic.
AnswerID: 322778
Follow Up By: Mike - Friday, Aug 29, 2008 at 10:31
I have to say this...... "up the old red rooster"
Apologies to All, but Brushmarx will know what I mean if he's ex 21 Const Sqn.
Happy trails, Mike.
FollowupID: 589847
Follow Up By: brushmarx - Friday, Aug 29, 2008 at 10:44
"and more peace" (or close to that)
Heh Mike, 8 years there '72 to '79.
FollowupID: 589849
Follow Up By: Mike - Friday, Aug 29, 2008 at 10:49
Well there's a coincidence. I was there from late 72 till 75. Did Licola and Holdsworthy airstrip, in between detatchments to Canberra. Was known as Tex then, chippy with rescources troop
Happy trails, Mike.
FollowupID: 589850
Follow Up By: brushmarx - Friday, Aug 29, 2008 at 10:59
Been known as Wombat in Construction troop.
Only Tex I remember was a plantie, but in your time I was in New Guinea, Sydney (foreman Clerk of Works course) and other locations not including Lacola or Holdsworthy much of the time .
FollowupID: 589851
