Saunders Gorge Feedback and Questions
Submitted: Sunday, Sep 07, 2008 at 10:55
ThreadID: 61462 Views:3786 Replies:3 FollowUps:0
I just have a few questions
how many kms is it (it said it takes 3 hrs)
its says booking are REQUIRED so do u just email then with your number plate and the type of 4x4 and how many are going ???
is it open all year around
would a stock 4x4 do it with no trubble
BTW Saunders Gorge is in SA and is thre any other parks like this is SA as I have not found any more on the big wide web
Thankyou
Reply By: Member - Olcoolone (S.A) The O - Sunday, Sep 07, 2008 at 12:01
It's about 20 kilometers around.
You will do it in a standard 4x4, the only two places you will need 4wd low is once you leave the homestead as there is a big dip to climb out of and the other place is if you want to go to the lookout.
We used 4wd low for the hole trip due to the fact it was a better traveling pace and easier on the clutch.
Seriously you could do it in a hour with not much problems but why would you.....your there to enjoy it.
They have a couple of good lunch spots along the way.
I think it is closed on total fire ban days.
There are many others places like this but not as close to Adelaide as Saunders Gorge is, plenty around the Flinders Rangers, Morgan, Deep Creek ????.
Depends what you are looking for and if you only want one day trips or longer
AnswerID: 324241
Reply By: RobAck - Sunday, Sep 07, 2008 at 14:19
Saunders Gorge will take around three hours to do the tracks and allow half an hour for a break at the lookout. Distance is not the issue and never is. It is more the time you take to safely and comfortably cover the tracks and enjoy the views as well. You can book by phone which is their preferred approach so the can coordinate traffic on the tracks and allow some separation for safety etc. Tracks are closed during days of total fire ban. It is part of the Hills face zone and a sanctuary so there should be no issues with that policy. A stock 4WD will do the tracks although coming down from the lookout definitely required low range and first gear as it is getting very rough as folk are not using the correct gear and range, hitting the brakes and scalloping out the track making it more challenging for everyone else and not good for the environment. Low range is recommended for the descents to reduce the risk of damage to the tracks by over braking.
Saunders Gorge is the only set up of its type close to Adelaide but there are plenty of options such as the Loveday set up in the Riverland and quite a few tracks in the Southern Flinders which are all great weekends away
RobA
AnswerID: 324251
Reply By: chardthechippy - Sunday, Sep 07, 2008 at 23:35
We train driver training at Saunders Gorge and it is excellent for us because of the different grades of accents and descents. Does get very windy at the top so pick your day. You can see for miles and there are a few resident wedgies flying around too.
Another top spot a bit more challenging is Spear Creek Caravan Park, which is just before Pt. Augusta. You might have to watch your approach and departure angles if your rig isn't lifted and in the summer months petrol cars are a bit risky with their cat converters and the chance of bushfires.
AnswerID: 324320
