Chemical toilet chemicals
Submitted: Thursday, Feb 26, 2009 at 11:26
ThreadID: 66307 Views:13401 Replies:10 FollowUps:9
Hi, Getting into this caravaning now,whole 1st week of it,we bought this caravan back in Sept and had it stored before we came over.Working through all the bits and pieces and got around to the toilet,Would you belive that the previous owner had not emptied it.....what a pong !!! Anyway,we have now cleaned it out and put in the thetford chemicals,I read here something about Nappysan but cant find the thread now,not that keen on thetford chemical smell,any suggestions appreciated.
Reply By: Rolly - Thursday, Feb 26, 2009 at 12:05
The chat on the "napisan" type of chemicals came down heavily in favour of the cheaper generic brands as they contain a higher percentage of the principle ingredient, sodium perchlorate.
This chemical is benign in the natural environment and in septic tanks etc. as it breaks down to hydrogen peroxide as the main disinfecting agent which works by releasing oxygen into the solution which kills the bacteria.
A huge number of RV users are changing over to this low impact and low cost product with considerable success.
AnswerID: 351128
Follow Up By: oldtrack123 - Thursday, Feb 26, 2009 at 12:47
HI
Rolly replied:
The chat on the "napisan" type of chemicals came down heavily in favour of the cheaper generic brands as they contain a higher percentage of the principle ingredient, sodium perchlorate"
A slight correction Rolly, the active ingredient is : sodium percarbonate.
FollowupID: 619411
Follow Up By: Rolly - Thursday, Feb 26, 2009 at 13:17
OOps!
Spot on , oldtrack.
I had another, totally different though train going on at the same time as posting that.
I'm not so hot at multi-tasking 8D
FollowupID: 619417
Follow Up By: oldtrack123 - Thursday, Feb 26, 2009 at 22:34
Hi Rolly
No problem, I'm 81, suffer a few senior moments in some of my posts.[ that's why I like the ones I can edit, often read them then after posting realize the boo boo]
FollowupID: 619525
Reply By: Sand Man (SA) - Thursday, Feb 26, 2009 at 12:39
Hi Ross & Cushla,
Many people are changing over to "safer" chemicals for portable toilet systems.
One of the potential health problems I read about was that the Thetford (green) product contains formaldehyde which is not too good for humans if you absorb it. I am unsure of the Thetford (blue) product that is also for the waste tanks in portable toilets.
Anyway, the product I now use is called BioMagic and if you click on the name, you will be taken to their website where you can read more about it.
Just one of the uses is for Portable Toilets. Check the website under Uses for other applications.
If you want reference information on the product, look under Info for both Technical & Layman's versions of the product.
You can also search for retailers in each state where you can buy the product.
For Portable toilets:
Add 50mls of Biomagic Regular to the flush tank and 50mls of the same to the holding tank with 2 litres of water.
For Cassette toilets:
Add 50mls of Biomagic Regular to the flush tank if you have one and 50mls of the same to the base tank with 2 litres of water (less if its less than 20 litres capacity). Put some BioMagic Regular in a spray pack and use it to clean the bowl and all surfaces on the toilet.
For Large Holding Tanks:
Add 100mls of Biomagic Heavy duty for Large waste tanks per 100 litres of waste with enough water to cover the base 1” This can be added in stages as the tank fills.
I have no affiliation of any kind with the manufacturer. I am purely a satisfied user of this environmentally safe and odourless product.
Bill
Bill
AnswerID: 351134
Follow Up By: oldtrack123 - Thursday, Feb 26, 2009 at 12:51
The active ingrediant in Biomagic is sodium percarbonate, the same as in Napisan & other similar home brand products.
Much cheaper way to buy & equally as effective
FollowupID: 619413
Reply By: Member - Rod N (QLD) - Thursday, Feb 26, 2009 at 12:49
There was copious discussion on the Caravaners forum about what to use here Nappysan in toilets
AnswerID: 351137
Reply By: Member - Matt & Caz H (QLD) - Thursday, Feb 26, 2009 at 13:47
Hi Guy's
Sorry to hear your van came with "extras" how gross some people are.............. we live in our van and have been on the road since November 08 - there are 4 of us, we use the odour b gone tablets - they work really well and really simple to use.
We used the small sample thetford bottles once and never again - the smell of the chemicals was just fowl.
Caroline
AnswerID: 351147
Reply By: Motherhen - Thursday, Feb 26, 2009 at 15:39
Hi Ross and Cushla
Choose and environmentally friendly product - be it Bio Magic or the generic nappy plus treatments. You have much more choice about where you can safely empty your cassette, particularly in outback areas where dump points are few and far between.
To change over to environmentally friendly stuff, you will need to cleanse and prepare the tank as they work in very different ways than chemicals. After thoroughly rinse out, mix up a double strength solution of your chosen product and add to cassette, fill with water and soak at least overnight, the longer the better. Do similar to the flushing tank if chemical has been used in it. There is no need to add anything to the flushing tank for normal use.
Coles Napicare Plus and Woolworths Nappy Treatment Plus are the recommended products.
Hope you get the cassette sweet smelling!
AnswerID: 351155
Follow Up By: Member - Malcolm (Townsville) - Thursday, Feb 26, 2009 at 17:58
We used to use a dark blue stuff - from 2005 until the 4 litres recently ran out. I bought some green stuff last year and its horrible. Just checked the laundry and found some Woolworths Nappy Treatment Plus (1kg). Granules.
What are the recommended directions for a Thetford (inbuilt) Cassette Toilet ?
TIA
Malcolm
living the 'good life'
FollowupID: 619449
Follow Up By: Motherhen - Saturday, Feb 28, 2009 at 00:14
Hi Malcolm
Simon has given the amounts. This is what was talked about on the Caravanners Forum - links given. We are using Bio Magic, but after the discussion on CF are willing to move to Sodium Percarbonate rather than buying a second bottle of the expensive Bio Magic. I had never heard of putting detergent in the top tank - and cannot see any reason for doing so. I use plain water to flush at home and in the van. Fortunately so had the previous owners so chemical residue to remove from it at change over.
FollowupID: 619701
Follow Up By: Member - Malcolm (Townsville) - Saturday, Feb 28, 2009 at 01:05
Thanks Motherhen and Simon
The van has been out of operation since leaving Camooweal last October. Cleaned toilet when I got home and had not been used since.
Today I again cleaned it and loaded it up with the Napisan. Mrs bought a 3kg pack from Woolworths today especially to carry in the van.
Malcolm
FollowupID: 619703
Reply By: Simon C - Thursday, Feb 26, 2009 at 20:37
I saw the original post on here, and have a printed copy in the glove box. Basically it was a capful of the home brand nappy treatment, and 1/2 to 1 litre of water in the botom tank. In the top tank (flushing water) you added a squirt or 2 of dishwashing liquid. Used this method on Straddie for a week at Christmas, and worked a treat, and CHEAP.
AnswerID: 351219
Follow Up By: Motherhen - Saturday, Feb 28, 2009 at 00:08
I hadn't heard of d/w liquid in the top tank and wondered why? Also unless it is an environmentally safe detergent, you would be negating the enviro-friendly 'safe to dump anywhere' aspects. I only use plain water in my flushing tank at home.
Just curious.
FollowupID: 619699
Follow Up By: Simon C - Saturday, Feb 28, 2009 at 11:59
Motherhen.
The orignal post 63999 had a lot of info (including info from yourself) One of the replys mentioned adding a squirt of Morning Fresh to the top tank to help keep "things"clean and lub the top seals. I used this method and it worked a treat for me, but it was
was my first trip with the porta potti. So it may not be needed. Agree on the evioro safe concerns....so maybe next time I will not use the d/w liquid.
Simon C
FollowupID: 619739
Reply By: Member - John & Sally W (NSW) - Thursday, Feb 26, 2009 at 22:06
Hi everyone,
Just in case I get some nappy soaker in a bulk container does the capful equate to approx half a cup? Can we put nappysoak in top tank too or just dishwashing detergent? Thanks for advice in advance.
Sally.
AnswerID: 351244
Reply By: Member - Cookie & Di - Thursday, Feb 26, 2009 at 22:36
Just remember no matter what chemical you use, that hose you pickup at the Dump Points has been down the throat of someone elses Cassette nozzle (Don't forget the gloves next time)
AnswerID: 351250
Reply By: GypsyOne - Friday, Feb 27, 2009 at 10:47
I too have converted to the generic nappy soaker & am 100% pleased with the performance at this time.
I inherited a toilet cassette that had a residual odour...treated it with the Coles variety of nappy soaker & soaked it over 24 hours giving it a good shake every time I walked past it.
I also gave the rubber rings at the top a really good clean & left it open for a couple of days to dry out. I then re oiled the rings with olive oil as per the recommendation
It is brilliant now, one would almost confuse it for a new cassette.
I have since purchased the woolies brand of nappy soaker, 3kg for $5.99
I think the trick is to dissolve the nappy soaker in warm water first before adding it to the cassette.
AnswerID: 351295
Reply By: Kiwis Ross & Cushla- Sunday, Mar 01, 2009 at 09:24
HI al, Usual great responce,thanks for all those.Its a bit like cough syrup ,why do they make it so bad.!!!
Incidently,I did try to search for that original post ,which I had read but it would not come up,dont know why?
Thanks again for the help.
Rosco
AnswerID: 351608
