New UHF radio
Submitted: Monday, Jul 20, 2009 at 22:09
Drew Peacock (W.A)
It's time to buy a new UHF CB radio for the bus.
The Uniden UHF 011 has died finally and I am looking at a new Uniden or a GME.
What is the better choice and why.
Any advice on antennas would also be helpful.
cheers Drew
Reply By: Flywest - Monday, Jul 20, 2009 at 22:42
Drew
I have no idea......is the short answer.
I just wanted to post this for you.
I have a copy of this old article because?....
My bro in law is named anDrew peacock!
375468
Follow Up By: Drew Peacock (W.A) - Monday, Jul 20, 2009 at 23:02
I use to get stirred up at Uni about my name I nearly became a Vet instead of a human Practician.
In my professional life I use Andrew, could you imagine if a patient came in with a impotence problem.
I might be able to specialise in mens health.
You may be my brother-in-law, wouldn't that be funny.
Maybe I should go back to Andrew, but I get a kick out of people when they see what my name is.
You can see this smile starting and I just look at them with a straight face, don't know who gets the bigger laugh.
642763
Follow Up By: Flywest - Tuesday, Jul 21, 2009 at 01:07
[quote]"You may be my brother-in-law, wouldn't that be funny".[/quote]
I can assure you I'm not - my B.I.L. DOES live in
Perth WA tho - but works for Bunnings at the moment (aged 51).
Of course there is ALSO the OTHER "Andrew Peacock" in
Canberra who was a
well known Lib Politician...
Just how many of these "droopys" are their in Oz - one wonders! ;o)
My missus assures me that your not a relative of her "Peacock" family/clan roots, that she knows of.
How many different / separate Peacock families are their in WA?
Interesting whichever way you look at it.
642778
Reply By: muzzgit - Monday, Jul 20, 2009 at 23:19
Erm, yes
well, getting back to the question!
I just bought a GME as I beleive they are an Aussie company and the radios are MADE IN AUSTRALIA and that's good enough reason for me!
Muzz
375472
Reply By: Member - Andrew L (QLD) - Tuesday, Jul 21, 2009 at 05:06
Drew, google up prestige communications, they are in W.A. and have a beaut website and some pretty good pricing on UHF stuff.
Value for money I believe is GME equipment.
375480
Reply By: Sand Man (SA) - Tuesday, Jul 21, 2009 at 07:35
Drew,
I am yet to be convinced there is a lot of difference between the brands, but I am about to find out.
Have a Uniden UH100 in the Jack which has performed faultlessly for some 8 years or so.
I have recently purchased a new vehicle and one of the criteria I needed was a remote head unit. (There is no space to install the radio adjacent to the car radio as both din sockets are in use with the double din radio and display screen.)
I had the choice of another Uniden (UH015SX) or the GME 3420 both of which feature a remote (removable) head and with the GME being smaller overall.
I checked out both at
Prestige Communications and chose the GME as it is an Australian product. (about $40 dearer than the Uniden)
I have yet to install the new set and will have to wait before I can give an answer on its performance, functionality and ease of use.
As far as antennas go it probably depends on where you intend mounting it.
(What is wrong with your existing one by the way?)
To start with, I intend mounting the antenna for the Colorado on the edge of the bonnet/mudguard area adjacent to the windscreen and for this reason I chose an RFI CD63-71-50 which is a black stainless steel 800mm sprung antenna giving as good performance as any antenna on the market, subject to where you mount it.
The best place is up on the roof gutter area but I am reluctant to remove the cover along the front windscreen column on my brand new vehicle so the location is a bit of a compromise.
I hate the idea of a big white "wank pole" mounted on the front bull bar. In fact I don't yet have a bull bar, so that isn't even an option.
The RFI antenna can also be fitted with a quarter wave "rubber ducky" aerial which is more than adequate in the metropolitan and near country areas and is onlt 100mm high.
Bill.
375482
Reply By: Member - Stephen L (Clare SA) - Tuesday, Jul 21, 2009 at 07:58
Hi Drew
Keep your hard earned dollars employing Aussies. Uniden are ALL 100% made and imported into Australia from China. All GME vehicle mounted UHF radios are 100% made and manufactured right here in
Sydney Australia. GME have just raised the bar level with a couple of new models, making the smallest headset of all radios, no bigger than the microphone. All GME vehicle come with a full 3 year warranty.
From their range, you will find a radio in size and specifications to suit your needs, and yes the answer is I do have and own a GME TX 3440 Radio, the now smaller model is the TX 3340.
375487
Follow Up By: marcus - Tuesday, Jul 21, 2009 at 08:36
Have just installed my TX 3340 and it works fine till you start the engine then the volume drops down too low and won't volume up.Turn off radio and then back on volume is good till next start up.GME have the radio at the moment.
Mark
642800
Follow Up By: Member - Stephen L (Clare SA) - Tuesday, Jul 21, 2009 at 09:02
Hi Mark
All I can say is that is very bad luck. Rest assured that there will be a good outcome. I am very surprised that you were not given a new replacement radio from the store that you purchased the radio from. The company that makes the GME Radios, Standard Communications are a very first rate company to deal with as a retailer point of view. When ever I have had any issues with customers, their reply is replace the unit with a new unit and send the radio back to them, if it is a new radio, otherwise their warranty repairs are very quick turn around times, less than 1 week in most cases.
I would speak to the
shop where you purchased the radio from.
All the best and I hope that it is a very simple issue. We had to send a few TX3440's back when they were first released. It turned out not to be a radio fault, but operator. You have to hold the power button down for a few seconds before the radio turns on, a means so that you can not accidentally turn the radio off if you hit the power button in error when using the radios. At that time, Standard Communications said just replace the units, and explained the correct procedure on turning the radio on. The radios that we sent to them, were all returned, with no faulty at all.
642807
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Jul 21, 2009 at 12:53
I just bought a remote head model 3420 i think,, its a bit complicated for what most people need, it has a lot of usless features but it is made here in OZ,, so thats important.. Michael
642832
Reply By: warfer69 - Tuesday, Jul 21, 2009 at 16:49
Hiya Drew
Look at the ICOM- 440 Pro It has a speaker in the mike plus a first class radio...
Here
375544
Reply By: BenDiD - Wednesday, Jul 22, 2009 at 22:57
I hav a GME TX3440. It get s a lot of work and in severe conditions - thick dust, heat, cold, severe corrugations etc etc.
I like the GMEs because I have never had a problem with them the work
well and as an added bonus they are made here in Aus. Having said that I have never known or heard of anyone having any more or less problems than a GME with Uniden (a bit cheaper) or Icom (a bit more expensive).
Given all of that go for the one that seems the easiest to use / install and suits your budget. PS a lot of "features" are BS - e.g., I have never used and don't know of anyone who as ever used selcall on their UHF, one brand advertisers a "repeater sniffer" to find working repeaters in your area. Weil you quickly get to know these, can look them up (google tropinet repeater list) or check the channels - if someones talking theres a repeater, if not key your mike and listen for the "tail" (a short bit of static) which indicates a repeater is in range.
Good Luck!
375764
Follow Up By: BenDiD - Wednesday, Jul 22, 2009 at 22:59
re antennas - like most here a small rubber duckie (nil gain) mounted on your roof gutter or rails is the go.
643089
Reply By: walwffoeg - Wednesday, Jul 29, 2009 at 18:02
What about the hand held 5watt type?
Do they give similar perfromance to the under dash models?
I would like also to get a
uhf radio but as i travel in either of two vehicles I don't want to instal it. I will be wanting to move it from one vehicle to the other .
Geoff
376697
