Bridgestone D694
Submitted: Wednesday, Sep 09, 2009 at 18:20
Member - Fred B (NT)
OK, I now have the tyres 265/65/R17 D694's fitted, what pressure do I run them at?
The old dunlop AT20's I ran at 34psi and got 45k from them (which I am told was exceptional for them). Dealers always seem to chuck 40psi in, no matter what the tyre; they have done that again here.
So if you are running D694's , what pressure are you running them on please?
regards
Reply By: Member - Mick O (VIC) - Wednesday, Sep 09, 2009 at 18:28
Bloody Hell Fred,
I don't know why you didn't buy one of each and give us an acurate report regarding them all in 12 months time LOL ;-) It'd solve the Exploroz tyre debate in one swift blow Ha Ha.
How did you go with the Rema Tip Top stuff?
Cheers Mick
382543
Follow Up By: Sir Kev & Darkie - Wednesday, Sep 09, 2009 at 18:29
Which way is the white writting as
well?? hahahaha
Cheers Kev
| Russell Coight:
650136
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Sep 09, 2009 at 18:43
The tyres always get better milage if the white lettering is on the outside!!! its a fact !! ;) Michael
650138
Follow Up By: Member - Fred B (NT) - Wednesday, Sep 09, 2009 at 19:24
Sorry to disssapoint guys, but I went for the RBT (raised black lettering) so I wouldn't look like you lot of hoons and show off's...! lol...! (:
Mick, I still haven't been to Rema, but I tracked down the R&R beadbreaker dealer... he doesn't hold stock and doesn't want to, as he only sold one in the last 5 years. No money in it for him apparently. So will have to look at another alternative.
cheers,
650146
Follow Up By: Member - Tony Z (NSW) - Wednesday, Sep 09, 2009 at 19:51
Spoke to Adam Plate of the Pink Road House and he advises that they should be run at 36psi on hwy. I told Adam that they were LT but thisdid not matter and was told by the dealer that 40 psi is right. I think Adam may no more of tyre life than the dealers as he see's them go up and down the track all the time. I spoke to him for a while about gravel road press. and hwy heseems to know what he's talking about.
As I will be going uthrough there tomorrow I will trust his opinion.
650155
Reply By: Member - Mark (Tamworth NSW) - Wednesday, Sep 09, 2009 at 19:46
Go to the Bridgestone web site.
It depends on whether they are P or LT, what weight the vehicle will be at, probably what speed and whether it is sealed or unsealed.
I found that outback tyre repair stores recommend lower pressures again, but they assume you are not running at highway speeds.
http://www.bridgestone.com.au/tyres/passenger/care/facts.aspx
382552
Reply By: Ted G - Wednesday, Sep 09, 2009 at 19:46
Hi Fred
Toyota dealers always put 40 psi on any tyres that are on a 4x4 at any service obviously can't read the
plaque on the door.
You wonder if they also read the manuals for any required.
The specs are 28 and 32 psi for 265s I run 34 on the front and 36 on the rear as most of the time I am towing a 18ft 6ins caravan.
The comfort is much better than shaking your teeth out on 40 psi.
Ted
382553
Follow Up By: Off-track - Wednesday, Sep 09, 2009 at 21:20
Maybe they know that it works. The
plaque figures cant be good if you run them higher, and I would agree with you.
Personally I run them at 40 as they wear evenly and arent too rigid.
650177
Reply By: obee1212 - Wednesday, Sep 09, 2009 at 19:49
I am running 45psi. Less heat from flexing and less exposure of the walls. Maybe not as comfortable but on bitumen around town you would not notice. Less flexing means less rolling friction too. Only drawback is less braking efficiency. You might think that critical but the way I drive you would not think I need any help avoiding a prang.
I am convinced at last that changing the
wheels front to rear adds a lot of life.
If you do not get the alignment done when you get new tyres make sure you tamper proof the adjustment threads and find a tyre man who does not mind you watching.
Owen
382554
Follow Up By: Member - Duke (TAS) - Wednesday, Sep 09, 2009 at 20:08
Just travelled from
Longreach,
Windorah,
Birdsville,
Bedourie to Mt Isa towing a 24foot Traveller Van with 45PSI in DunlopLT Tyres towed by a 100series Cruiser with DunlopA22 Grandtrek Tyres at 45PSI.
Had no punctures or problems whatsoever. In my opinuion the biggest problem is that people do not drive to the condition of the road. I learnt that lesson early in my life carting logs down in Tassie on Forestry Commission roads for 20years.Just had to slow down or wreck gear.
DUKE
650162
Reply By: Member - Duke (TAS) - Wednesday, Sep 09, 2009 at 20:13
By the way Fred B (NT) i like your choice of Tyre. Thats what i will be shoeing the horse with when i wear out the Banglops. (Thats the name we gave them when carting logs)
DUKE
382556
Reply By: Holden4th - Wednesday, Sep 09, 2009 at 20:16
I've got 694s and the dealer who fitted them last month pumped them up to 40 psi - cold. After running them for a while the heat build up in the tyre will take this up to about 42 which I consider ideal for my NP Pajero with no load. I ran the last lot at about 40-41 and got some very even tread wear for 60k. At the moment the sidewalls look in very good shape but I know that once I let the pressures down to half of that, there will be a bit of a sidewall bulge but that's OK.
382557
Reply By: Rick (S.A.) - Wednesday, Sep 09, 2009 at 21:03
Criteria: Fully loaded to GVM (if you promise not to tell anyone, I can tell you my GU Patrol is over GVM). Test bed: 20,000 km of rough track /dirt, every season, incorporating about 33 % bitumen to get "there"
Scenario + pressures I run:
Bitumen at 100 kph - 45psi
fast
well maintained dirt roads at speeds of up to 100 kph - 28 psi
Poor dirt roads up to 80 kph - 22 to 28 psi
sand roads - e .g. desert tracks & corrugations, up to 60 to 70 kph - 20 psi
beach sand - 18 psi
deep loose beach or
creek bed or desert sand - 12 to 15 psi.
Hope this helps.
Cheers.
382564
Reply By: Sand Man (SA) - Wednesday, Sep 09, 2009 at 21:49
Fred,
It doesn't matter what brand of tyre you have on your vehicle.
Start with the Manufacturer's recommended pressure and add a couple of psi.
Drive the vehicle for a few kilometres to warm the tyres up, then check the pressure again.
Using the 4 psi rule, if the tyre pressure has increased by more than 4 psi, the tyres are running too hot and therefore increase the pressure by a couple of psi and repeat the process.
If the pressures haven't increased at all, the tyres are running too cold and you should reduce the pressure a bit until the pressure when the tyres are hot are about 4 psi higher than when cold.
45,000 kilometres from a set of tyres is not very good at all.
I have run both D694's and D693's and returned about 70,000 k's before they needed replacing. I prefer the more aggressive pattern on the 693's but they seem to be getting harder to source, depending on your size requirements.
My Colorado came with factory fitted D693's made in Thailand and I am interested in how they last, compared with the Japanese produced 693's, or the Australian produced 694's in my size of 245/70/R16.
Bill.
382571
Follow Up By: Member - Fred B (NT) - Wednesday, Sep 09, 2009 at 22:22
Hi Bill,
well aware that 45k isn't much chop for a set of tyres. Even the tyre dealers admitted that most people were only getting 25-30k out of the dunlop AT20's. I know that has a lot to do with the driver, road conditions etc; I really looked after
mine, and still only got 45K.
With the new ones, I want to take good care of them as best I can; hence the question on pressures. But, like everything else, such as "how long is a piece of string?" you will several different answers to that question, as I will to what tyre pressure to run.
I do appreciate all input; and thanks to all who have responded. Sorry Mick, can't run 6 different tyres and rotate every 5K just to please you! LOL..!
650182
Reply By: Member - ross m (WA) - Wednesday, Sep 09, 2009 at 21:52
I have the D694 LT on my 75 series and have about 45 psi all round
382572
Reply By: Member - Stephen L (Clare SA) - Wednesday, Sep 09, 2009 at 22:10
Hi Fred
I have had the same tyres now for a couple of years and very happy with them.
I ruined on my last trip with
well over 3/4 of tyre life left, and I was not happy. That's the only problem when you go to out of the way
places. I have just replaced the damaged one with two new D694LT and will see how they compare. I was running 28 front and 30 rear. I have checked the book when they gave me the new tyres and they had a recommended pressure of 34 front and rear.
The Dunlops that were standard on my Prado were shot by 40,000 kms. The best thing that I have been very happy with the Bridgestone is that they have not chipped at all, and I can tell you that they have seen some very rocky tracks in their travels. On the dirt I run 24psi front and 26 psi rear. In the real corrugated stuff, I was running 22 and 24 with no problems.
Image Could Not Be Found
382576
Reply By: Member - Fred B (NT) - Wednesday, Sep 09, 2009 at 22:29
Thanks everyone.
Looks like I'll run them at 40psi for a few days and take the "anal" thermometer with me and check the tyre temp and pressure every 10 km... Just kidding.... lol..!
Seriously, will keep an eye on them and see how they go. Will leave them at 40psi for now. Won't be going bush or tracks soon, so won't get the chance to drop pressures and check them out at that level for a little while.
all the best
382580
Reply By: PradOz - Wednesday, Sep 09, 2009 at 22:45
i was under the impression with the 4 psi rule you checked the psi change after driving about 100kms. maybe that is wrong or too long i am not sure, but it worked out ok on my van and prado too.
i run my prado on 40 and have over 70000 on them. i am coming up for a new set soon and was thinking of changing over to the bridgestone d694lt. what sort of price did you get them for?
also i remember a guy a few years back who worked at eastern
creek raceway telling me to run on 40 for increased tyre life and better braking too. the ride can be harsher, as noted by my brother who runs his at 35 and he always gets less mileage out of his. he reckons the comfort is worth it - i just cant afford the extra $. i think i need to borrow his money tree :))
382582
Follow Up By: Member - Fred B (NT) - Wednesday, Sep 09, 2009 at 23:26
Bob Jane T Mart (Casuarina)
Darwin 6x $305.00 each... with balancing and fitting (after some arm wrestling). Initial price $318 + fit and balance + $8 per tyre to get rid of old ones. Couldn't get any one to supply cheaper.
650188
Follow Up By: Member - Stephen L (Clare SA) - Thursday, Sep 10, 2009 at 07:48
Hi PradOz
I paid $317.00 for the D694LT for each tyre fitted and balanced here in
Clare SA
650198
Follow Up By: PradOz - Thursday, Sep 10, 2009 at 12:34
I just opened up the NRMA Open Road magazine and there is an advert inside the front cover for
D694LT $284 for 265/70R16 or 265/75R16
D694 $259 for 265/70R16 112S
Both available from 24 August until 3 October at that price if you mention the advert and at Bridgestone service centres, tyre centres and B Select. I also seen them at the same price in Kmart brochure too
Anyone in
Sydney seen cheaper?
TO Stephen/Fred:
what is your opinion of the new tyres after driving on them in your own vehicles? How is the road noise, handling on and off road in both wet and dry? What air pressures did you end up putting in yours?
cheers mick
650226
Follow Up By: Member - Stephen L (Clare SA) - Thursday, Sep 10, 2009 at 13:31
Hi Mick
The only difference is that our 120 series run 265/65x17", which are the correct and legal size for the 120 series.
16" tyres are usually cheaper.
As to your second question, they are brilliant. No road noise at all, handle
well in all conditions and that is why I replaced the damaged one with the same, but in the "LT"
650230
Follow Up By: Member - Fred B (NT) - Thursday, Sep 10, 2009 at 16:20
The KMart promotion finnished on 31st August... I didn't find out about it till 1st Sept.
That could have saved me a few extra $$$
Unfortunately the NRMA promo only applies in NSW at participating dealers.
650251
Reply By: RobAck - Thursday, Sep 10, 2009 at 18:56
Judging from the size they are on a 120 Prado?
Having been using these tyres for several years now our recommended pressures are
Bitumen and under normal driving conditions 34
Dirt 26
Bitumen and loaded. We run at 2900kg for tours, 36 front and 38 rears
Dirt fully loaded, add 2 to the rears and monitor
Sand 16
RobA
382667
Reply By: Outbacktourer - Thursday, Sep 10, 2009 at 19:27
Tyre pressure is a variable similar to weight, weight distribution and tyre construction. The 4psi rule is a good guide but fiddly.
Contact patch method is instant and the best.
Check Jol Flemings site for details.
Tyre Pressures
OT
382671
Reply By: Member - Jack & Lorraine B (QL - Wednesday, Oct 07, 2009 at 07:41
I will be putting the d694LT on at the end of this month.
My current tyres have been running at 40psi for the last 5 years and have no uneven wear, they are the Kumho roadventure 275-70r16. I have not been using the tug on long trips with these tyres, mainly just local south east QLD and down to
sydney and on fraser island. worked
well, but now at 8 years of age and with only 3mm of thread left it is time to replace for the big round
the block trip. these tyres have now done about 70000km and no punctures!!!
I will try the pressure at about 38psi with the new tyre. see how the shape looks and how it feels. with a full load and a caravan I probably pump it to 40 again. Normal highway speed for me is around 85 to 90 km/hr(take all that into consideration when setting the pressure)
down to 28 on corrugated dirt road and reduced speed..
386088
