Saturday, Oct 09, 2010 at 17:21
Hi Ma,
we bought our Trakmaster
Kimberley poptop new in 1997. When we faced the inevitable of having to change from tent
camping (the Driver's hip replacement), for our intended several-year trip, we intended to buy a Supreme Getaway, because they were the only "real" off road van we knew of then. But at the caravan show, came across Trakmaster, spent a lot of time comparing the two, and went for the Trakkie, because we felt it was more solid than the Getaway. Because we wanted to, as far as possible, go where we used to be able to, we kept the rig small and no frills. So it is 14 foot long inside, 6'6" wide. No bathroom -( we carry a porta-potti that has never actually been used). Have an oven, 4 burner stove, bar-sized fridge, sink,c two
water tanks, Heron air-con built in. The storage was adequate for life full-time on the road. When built, it weighed in at 1.3tonnes unloaded. Would be a bit more now, because we put solar panels on the roof.
We have been totally happy with this choice. Lived in it for 3 years, initially, and since then anything from 3 to 9 months in most years. It has been towed over 100,000km - probably about 40,000km of that off the bitumen.We have not had any towing issues with it - we both share the tow driving. At that length, it is quite manoeverable in the bush, too.
They do hold their resale value
well - which probably speaks for itself - but you would also get the benefit of that if you want to sell it on, later.
We generally take it back to the company for an annual service. Have had no significant issues - brake magnets, bearings etc get periodically replaced. Only real problem was that back in 1997, it was normal to use plastic cupboard and drawer handles. Over time, these began to wear out and replacements were no longer available - not the company's fault! We decided to do the job properly and replace the lot with the newer push button catches - but this meant that the doors and drawer fronts had to be re-made - luckily The Driver was able to do this himself after Trakmaster got him the materials needed - saved us money.
Happy to answer any questions you may have.
432518
Follow Up By: Members Pa & Ma. - Saturday, Oct 09, 2010 at 19:21
Hi mike 39 & Wendys,
Thanks for that, all the advice has been appreciated.
The Trakies are so expensive and very hard to find 2nd hand in our price range.
At present we definitely can't get a new one.
We just want the small ones max only 14' external at most for the time being to upgrade from canvas but still go where we can now. Still use the Oztent if we need to,both of us have debilitating illness.
Just want to crawl into bed each night as with only short holiday breaks, we move on most days to fit in what we want to see.
We would consider the
Kimberley later on when we may have to live in it.
Take care, safe travels.
Bye Ma.
703351
