palm valley,NT
Submitted: Sunday, Oct 10, 2010 at 20:46
ThreadID: 81833 Views:7203 Replies:11 FollowUps:1
hey there, I keep getting conflicting reports can I take a camper trailer into palm valley or not. Its a cub off road
Reply By: Member - Wim (Qld) - Sunday, Oct 10, 2010 at 20:53
p_marns.
No problem. Nice little drive.
Enjoy.
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 432639
Reply By: Rangiephil - Sunday, Oct 10, 2010 at 20:54
IMHO you could take a camper trailer in . When I was there a coupleof years ago the road in was heavily corrugated and a guy in front of us broke a spring centre bolt and main leaf on his camper with the result that the axle turned 90degrees.
There are no clearance reasons not to take a camper trailer as long as you take it slowly. the road is unlikley to be much better now as it follows the river bed in.
Regards Philip A
AnswerID: 432641
Follow Up By: Member - Serendipity(WA) - Sunday, Oct 10, 2010 at 21:11
I agree - take it easy and have spare parts. Especially a spare leaf spring and centre bolt.
I was there a few years ago and a great little oasis in the middle of nowhere.
David
FollowupID: 703425
Reply By: Motherhen - Sunday, Oct 10, 2010 at 21:17
We took our caravan in to the camp ground with no problems; just took it slowly. It was very dry when we were there in 2008.
However you cannot take a trailer on the track into Palm Valley itself - but you wouldn't want to anyway.
A lovely camp ground. We stayed an on a third night just to enjoy it.
AnswerID: 432646
Reply By: Bushranger1 - Sunday, Oct 10, 2010 at 21:41
No problems. I took my camper trailer in.
As always, drive to the conditions & you wont break anything.
AnswerID: 432647
Reply By: happytravelers - Sunday, Oct 10, 2010 at 21:56
Took our camper trailer in there back in July. The track is sandy as it mainly follows the Finke river. No problems at all, the camp ground was full of trailers, and the best bit was, they all cleared out the following morning so we had the place to ourselves until late afternoon.
Jon
AnswerID: 432648
Reply By: p_marns - Sunday, Oct 10, 2010 at 22:05
thanks everyone, sounds like I m right to go
AnswerID: 432649
Reply By: Member - Bucky - Monday, Oct 11, 2010 at 07:39
Easy run in there mate !
Great campground, but the solar heaters were not working last year, but I had a cold shower anyway.
Well worth it
Bucky
AnswerID: 432669
Reply By: Jumankum - Monday, Oct 11, 2010 at 08:12
Don't let this sign freak you out, its only about half an hour from this point.
Easy dr and often graded to help out the constant stream of tour buses.
Cheers Jim
AnswerID: 432673
Reply By: WBS - Monday, Oct 11, 2010 at 08:50
Yes you most certainly can. I was there in July when the Finke was flowing nicely so the water crossings were longer but none were deep except for the last crossing that I came across about 1 km from the actual Palm Valley that is not that deep really. That's after the campground so by then you should have parked yourself in the campground anyway. I saw several campervans and trailers that made the journey easily.
I am an experienced although very timid 4wder so when I saw the sign saying "extreme 4wd conditions" at the beginning, I was more than somewhat perturbed but my only problem was on one crossing (the second or third you will encounter), that curves across the river so the exit point was not obvious when I first came across it. I just walked the route first with water at below knee height and I'm about 170 cm (5'7" in the old language) so its not deep. If there is no water there will be no problem.
WBS
AnswerID: 432675
Reply By: Member - Rob S (NSW) - Monday, Oct 11, 2010 at 20:12
Thats what the road looked like a few years ago.
And as said it is the section after the camping area that is not suitable for trailers. this section is just to drive further down the valley to the walking trails.
And get in early as the camping area fills up quick if you want a good spot.
Image Could Not Be Found
Rob
I only ever made one mistake
AnswerID: 432739
Reply By: MEMBER - Darian, SA - Wednesday, Oct 13, 2010 at 16:36
Yep re the above - took our 18' offroad caravan in to the campground a few weeks back - quite straight forward - clearance not an issue - some stones, some sand, some shallow water but nothing to trouble careful outback tourers :-o).
AnswerID: 432891
