Birdsville Track
Sorry if this has been on the Forum before, but just a couple of questions. We are planning to do the Birdsville Track heading off from Adelaide at Easter (22nd April) next year so which direction is the easiest and best. Also anything else we should be aware off. Thanks in advance for you feedback.
Rick P
Reply By: Sand Man (SA) - Monday, Nov 22, 2010 at 18:20
Hi Rick,
Either direction will be OK, depending on weather conditions of course.
The Track is gravel or rubble based for much of its length and easily navigable when conditions are dry.
Once rain has affected the surface however, the track surface can change to slippery sections and sometimes the track is closed due to floods at the river crossings.
At the moment the track is closed at the Cooper Creek crossing and a bypass to a ferry surface is in place. This is unusual however and the majority of time the track is easily drivable in either direction.
Bill.
Bill
AnswerID: 436635
Reply By: deserter - Monday, Nov 22, 2010 at 18:47
Drop your tyre pressures and keep the speed under 80k. In my opinion anything faster just invites tyre problems.
AnswerID: 436640
Reply By: Gossy - Monday, Nov 22, 2010 at 19:07
just got back. It's a freeway in regard to condition of the road. I don't travel any faster than 80km/h anyway as I like to drop my pressures a little bit for a softer ride and look after the tyres.
have to assume the worst though. A couple of years ago we were on it and it was a mud pit. high range 2nd gear for about 3 straight hours. I was surprised it was open but I think they were keen to get us out of birdsville before the next front came thru.
AnswerID: 436645
Reply By: Member - Stephen L (Clare SA) - Monday, Nov 22, 2010 at 19:27
Hi Rick,
There are 3 main ways from Adelaide.
The first and longest and the most boring is up Highway 1 to Port Augusta, then to Quorn, Hawker etc.
The next two options will take you through the Mid North and my home town of Clare. From Clare you then have 2 options and are 2 very different drives.
Option 1 and a very pretty drive is to head from Clare and travel through Yacka, Georgetown, Laura, Melrose and from Wilmington turn right and head for Quorn and there to Hawker.
Option 2 and the quickest is from Clare travel through Spalding, Jamestown, Orroroo, Carrieton, Cradock and Hawker.
From Hawker you will now have 2 options.
If time is no problem and you have never travelled through the Flinders, then head north east from Hawker and travel via Wilpena Pound, Blinman and then to Parachilna.
Option 2 from Hawker is to head straight north to Parachilna and beyond.
All of the above routes offer many varied and great things to see, and would take a lot of writing to fill you in on everything. Depending which way you travel to Parachilna, you then head due north towards Leigh Creek.
While you are driving past, take the small detour to Aroona Dam and see the great volume of water that is used for the Leigh Creek Township's water supply. The next stop just after Copley is to have a look at the Leigh Creek Coalfields from the lookout. Back on the main track and not very far out of Lyndhurst drop in and inspect the Ochre Pits. Next stop and still before Marree is the old ruins at Farina and the cemetery. From here you are nearly at Marree, with main sights to see.
Once on the Birdsville Track there are a number of good places to see including Lake Harry ruins, Clayton Bore for a Hot Spa if you are camping there.
Again if you have time the old Killalpaninna Mission ruins (You will have to collect the key from my friends, Patsy and Jason Dunn from Etadunna Station)
the old Brennan punt on the Cooper Creek, Mungarannie including the old graves behind the sand hill where campers stay, The old Mulka ruins, Mirra Mitta Bore, and many more locations.
Like I have said above I could keep on writing, but the above will give you a very good start to your planning.
AnswerID: 436647
Follow Up By: Sigmund - Tuesday, Nov 23, 2010 at 08:18
Good info; thanks Stephen.
FollowupID: 708070
Follow Up By: Member - Stephen L (Clare SA) - Tuesday, Nov 23, 2010 at 09:03
Hi Sigmund
Thanks for that. This is what the forum is all about, giving accurate information when people ask for details and hopefully letting them see far more than just a drive from point A to point B. Local information is always the best and I to have asked for information for areas that I have not travelled and have appreciated the help given by the many experienced travellers from EO.
FollowupID: 708073
Follow Up By: wicket - Tuesday, Nov 23, 2010 at 10:02
If you go through Copley don't forget to drop into the Copley bakery for a Quandong pie
FollowupID: 708078
Follow Up By: Sigmund - Tuesday, Nov 23, 2010 at 10:43
Ah yes, and a jar of Q. jam which they make themselves.
It's not everyone's cuppa though; x between rhubarb and plum. Quite tart.
And drop in on Cookes Outback motors. The boss gets around in a t-shirt emblazoned with the word 'Schadenfreude'. It fits.
Stephen, I agree. Too many folk aim to 'do' this or that track and miss out on the geology, history and flora and fauna of the area.
FollowupID: 708081
Follow Up By: wilco318 - Tuesday, Nov 23, 2010 at 14:24
Just read this and Thank you Stephen for the valuable info.
FollowupID: 708109
Reply By: Member - Duncs - Tuesday, Nov 23, 2010 at 12:27
I have just returned (yesterday) from a trip up the Birdsville Track. Thanks to Stephen L for good accurate advice.
The track from Marree north to Dulkanina Crk is in pretty good condition. The bypass track to the ferry is very wet and slow going but passable as long as you take your time and have a good look before commiting yourself to a route.
Camping near the ferry is excellent and it is truly amazing to see that much water where there really should not be any. It is so beautiful my great regret is that I did not have more time to spend there.
We were the first people north out of Mugeranie after the track opened. Most of it is still pretty good but there are places with deep water across the road. An area through Pandi Pandi about 100km south of Birdsville is still very chopped up. It is wet in patches and there is a long bypass which has soft spots that require some care.
Having said that it is all passable at the moment but there are storms about and conditions do change very quickly.
Duncs
AnswerID: 436698
Follow Up By: Member - Stephen L (Clare SA) - Tuesday, Nov 23, 2010 at 13:13
Hi Duncs
Great to hear that you have had a great trip and enjoyed the ferry crossing. I am still trying to get in contact with my Transport SA contact, as she has been away on sick leave. Did the ferry operators give you any indication on how much longer the ferry will run for? When I was last speaking to Jason from Etadunna Station he told me that with the amount of water still out there, he would have thought that the ferry would be running to at least Christmas.
I bet the countryside is still looking a million dollars.
FollowupID: 708101
Follow Up By: Member - Duncs - Tuesday, Nov 23, 2010 at 13:59
Stephen,
We did not hear directly from the ferry operators about the time the ferry is expected to keep running. We met the changeover crew in Marree but they had not started work when we got there and didn't say anything about how long it will keep running.
The water is still 3.7m under the ferry so I don't think it will dry up overnight. There was more rain in the Cooper catchment on Saturday night and Sunday. I know it has a long way to run to get to the ferry but it won't speed the drying process. We heard talk in Birdsville that they were talking about just 3 weeks but I would be suprised if that was the case.
You would win your bet about the countryside. In 2005 I spent a week at Innamincka and was struck by how harsh, dry and barren the area north of Nappa Merrie was. We travelled through there after visiting Haddon's Corner and I was stunned by how green it is. It is more like English meadows than the harsh Australian Outback.
I will post a review of the trip with some pics when I get organised.
Duncs
FollowupID: 708108
Reply By: Member - Rick P (NT) - Wednesday, Nov 24, 2010 at 10:19
Thank you everyone for your feedback, great to hear the place is looking a treat. We are now thinking we might head back via the French Line after doing the the Track. How will we go doing it east to west.
Rick P
AnswerID: 436790
