tracking will not load
Submitted: Wednesday, Jun 29, 2011 at 06:54
ThreadID: 87275 Views:2910 Replies:8 FollowUps:17
Has any members had trouble with tracking base map not loading or is it me doing something wrong .
Thankyou Peter r
Reply By: Member - Mike - Wednesday, Jun 29, 2011 at 07:16
Hi Peter
I have the same problem - I posted a query here a couple of weeks ago, although I had a couple of reply's from members having the same problem I received the following reply from Adele.
Hi Mike,
I’ve had a chat to the site developer and as we have not had this problem reported by anyone else, the problem must be associated with the set-up of your particular browser, please ensure you are using the most updated version of your browser, if you are/install updates and the site still doesn’t work, please try downloading an alternative browser such as Google Chrome, and try it again.
Adele Scala
I have an updated browser, so am unwilling to go to an alternative browser such as Google Chrome. Have you checked Westprint they have some good info on a lot of treks
Cheers 4 now
Mike
AnswerID: 458730
Follow Up By: Member - peter r (NSW) - Wednesday, Jun 29, 2011 at 07:24
thanks Mike i have been using tracker to follow a member we are joining up with next week ,and tracker now will not load ,there has been no changers to my pc .
FollowupID: 732249
Follow Up By: Member - sassenach.girl (QLD) - Wednesday, Jun 29, 2011 at 08:01
Tracker was not loading for me last night either. Just tried again this morning, and it sits on "Loading" for a while (up to 5 mins) then I gave up. Last night I noticed as an error in the section that is normally the map.
Sass.
FollowupID: 732251
P.S. I'm using Google Chrome.
FollowupID: 732252
Follow Up By: equinox - Wednesday, Jun 29, 2011 at 09:18
Click refresh in your browser
FollowupID: 732260
Follow Up By: ExplorOz - Wednesday, Jun 29, 2011 at 22:13
As per equinox - do a browser refresh and let me know how this goes!
I can force the browser to pick up an updated script but need to know if it foxes it before I force the browser updates.
David
FollowupID: 732354
Reply By: Member - Chris & Debbie (QLD) - Wednesday, Jun 29, 2011 at 11:11
I also had the same problem and reported it, but so far no fix. What version of IE are you using? I have found that with one computer on our network, which is running Windows XP and IE8 Treks will not load, use Google Chrome and is ok. On another network computer running Windows7 and IE9 Treks loads, so maybe the problem is with IE8. So if runnning IE8 it may be worth updating to IE9
Chris
AnswerID: 458751
Follow Up By: ExplorOz - Wednesday, Jun 29, 2011 at 22:20
Try a CTRL + REFRESH/RELOAD on your IE8 system and let me knwo what happens?
FollowupID: 732357
Follow Up By: Member - Chris & Debbie (QLD) - Thursday, Jun 30, 2011 at 09:44
I have tried this and still no go, the page takes a lot longer to load but still will not load the base map. This will happen for any page that has the base map on it, Treks, Places or EO trackme.. Don't know if this will help but this is the error details I get from clicking on the error message bottom right of IE, there is three different error messages one each from Treks, Places & EO Trackme.
webpage error, Places
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; CMDTDF; InfoPath.2)
Timestamp: Wed, 29 Jun 2011 23:29:54 UTC
Message: HTML Parsing Error: Unable to modify the parent container element before the child element is closed (KB927917)
Line: 0
Char: 0
Code: 0
URI: http://www.exploroz.com/Places/Default.aspx
Message: 'theMap' is undefined
Line: 323
Char: 50
Code: 0
Webpage error, Treks
Timestamp: Wed, 29 Jun 2011 23:31:14 UTC
Line: 0
Char: 0
Code: 0
URI: http://www.exploroz.com/TrekNotes/Default.aspx
webpage orror, EO Trackme
Timestamp: Wed, 29 Jun 2011 23:34:05 UTC
Line: 0
Char: 0
Code: 0
Line: 0
Char: 0
Code: 0
URI: http://www.exploroz.com/EOTrackMe/Default.aspx
Line: 359
Char: 50
Code: 0
Chris
FollowupID: 732397
Follow Up By: ExplorOz - David & Michelle - Thursday, Jun 30, 2011 at 12:57
Chris,
Do you have some Internet security product loaded, or an ad blocker enabled? If yes please try to disable these and let me know what happens?
It should not be IE 8 as this is on my machine and is one of the well tested platforms. The messages you are getting above would show that your browser is NOT loading some of the required script libraries and this is normally and ad blocker or security setting in the browser or security package.
The other thing to try is a reset of IE - Tools - Advanced - Reset button at the bottom and see how this goes.
Let me know how you go.
David
FollowupID: 732414
Reply By: On Patrol & TONI - Wednesday, Jun 29, 2011 at 12:49
Peter I have just got back from a trip to Darwin. We loaded trackme in Sydney seemed OK when we got to Cobar NSW I looked on the map to see our track only to find a straight line from Dubbo to Cobar. From there I got nothing at all and gave up at Broken Hill. I am using my iPhone & running it in the background but found it all too hard and just gave up, I feel a lot of others have done just that too.
Cheers Colin
AnswerID: 458756
Follow Up By: On Patrol & TONI - Wednesday, Jun 29, 2011 at 12:51
And yes the base map loaded when it felt like it, not when I wanted it to.
FollowupID: 732276
Follow Up By: ExplorOz - Wednesday, Jun 29, 2011 at 22:19
Colin,
Interested in your feedback - I have used the iPhone version and it worked really well provided the number of points to store was set high enough. This is controlled in the uTrackme program - accessed via the iPhone Settings App.
Also I am sus what happens when you turn off the phone/app before the updates have gone to the server. I must do some additional testing of uTrackme (this is not my app but one that seems to work for the EOTrackMe system).
David
FollowupID: 732356
Reply By: Member - Russler - Wednesday, Jun 29, 2011 at 17:46
I've experienced the same issue. My PC is running the newest version of Firefox. Last night the member tracking would not load at all. Tonight it started off the same, but then I hit the refresh and it worked OK.
AnswerID: 458781
Follow Up By: ExplorOz - Wednesday, Jun 29, 2011 at 22:15
Russler - yes thanks a refresh does in fact resolve it.
The system is tested with ie7, 8, 9 firefox 3, 4 & 5, google chrome, safari and opera os it should work.
David
FollowupID: 732355
Reply By: Member - Howard (ACT) - Wednesday, Jun 29, 2011 at 19:42
running XP sand IE8 and will not load.
Had reported earlier this week.
will load quickly thru google chrome
tried the refresh button suggestion a few minutes ago and no go.
hope David can sort it out
howard
Resigned to Retirement
AnswerID: 458795
Follow Up By: ExplorOz - David & Michelle - Wednesday, Jun 29, 2011 at 22:58
Howard,
Try it now please and let me know how you get on.
David
FollowupID: 732368
Follow Up By: Member - Howard (ACT) - Thursday, Jun 30, 2011 at 10:31
David,
no changes this morning still cannot load any application , ie treks , places. trackme,that requires the interactive map to open unless I go thru google chrome.
thanks
Howard
FollowupID: 732403
Follow Up By: ExplorOz - David & Michelle - Thursday, Jun 30, 2011 at 12:50
Howard,
I would suggest you try a clear history/cache operation in IE 8. Tools - Internet Options - Browsing History - Delete and accept the defaults and see what happens.
If this is no good I would recommend you try reseting Internet Explorer - Tools - Advanced - Reset button at the bottom. See how this goes.
Also can you try disabling your Internet Security program (if you have one) and see if it works with this disabled.
David
FollowupID: 732411
Reply By: Member - Mary W NW VIC - Wednesday, Jun 29, 2011 at 20:26
I too am having this problem but only in the lastcouple of days.Did speak to Adele .
I had changed nothing on my puta and still it won't load.
Leaving on the big AB,CSR saturday and hoping it will be tracking me.
Disappointing as wanted to be able to email friends a link to my profile to follow my trip
Hope it's sorted soon,
Mary
"Some people walk in the rain,others just get wet."
AnswerID: 458800
Follow Up By: ExplorOz - David & Michelle - Wednesday, Jun 29, 2011 at 22:55
Mary,
Try it again now please and let me know how you get on.
David
FollowupID: 732367
Reply By: ExplorOz - Wednesday, Jun 29, 2011 at 22:11
Please everyone - do a REFRESH/RELOAD in your browser when you are on the mapping page. Then let me know how this goes.
If this does not work try holding down the CTRL key and pressing refresh.
Let me know how this goes.
David
AnswerID: 458825
Reply By: ExplorOz - David & Michelle - Wednesday, Jun 29, 2011 at 22:27
OK I just reloaded the system and installed a force reload of the mapping scripts so see how it goes now and let me know?
David
AnswerID: 458826
Follow Up By: Member - Russler - Wednesday, Jun 29, 2011 at 22:45
It came up OK the first time. Thanks.
FollowupID: 732363
Follow Up By: Member - peter r (NSW) - Thursday, Jun 30, 2011 at 05:58
Thank you all very much ,using the refresh did get it open .Today its working fine .only 8 more sleeps before we head west to the CSR.
All has safe travels. Peter and Glenys
FollowupID: 732373
