Thursday, Aug 11, 2011 at 15:10
George
Its a common question actually.
Any
beacon that has been approved by cospas sarsat - they have a list at
Here can be used and will work anywhere in the world.
If all you are going to use it for is offroad/ hiking its not illegal. If you want to use it for an activity where you are required to carry a registered
beacon it wont be accepted
Big point though - you cant register it on Australia's database unless its coded with the Australian code. (we are not allowed to register overseas beacons) So if you set it off - we wont get all your details presented with the initial detection so we wont know who you are.
If it comes with a position we will still look for you as its an international agreement.
If a
beacon is detected without a position (which does happen even with initial alerts from GPS ones sometimes) the alert will go to the country that its coded for. So that add delays.
To be honest - just buy one here, GME ones are made and serviced here, which will be more useful when you need to get the battery changed or if you have a warranty issue (beacons do go off inadvertently for a variety of reasons.) I only mention GME as that is the type you are looking at.
We dont recommend it, buy it here and its coded for aussie, which means you can register it here and having those details is a real plus for us (and you)
There is some more info on the bottom of this page about buying from overseas.
http://beacons.amsa.gov.au/beacon-models.html#importantbuyer
Pete
736151
