Thursday, Oct 20, 2011 at 11:42
I got the Hema to replace our Navman. About six months old and perfectly happy with it.
Recently got extra detailed maps and loaded in - but that wasn't difficult.
Haven't had any trouble using iGO around
Sydney,
Canberra and Country areas. Actually, find it is a big improvement over the Navman in it's user interface. Just so much easier to insert intermediate stops, or change
routes while on the go. I like the way it shows lanes on multilane highways in
Sydney. So far it has always got us to the right place via a sensible route. I can't say that for the Navman which takes a lot of persuading to use our preferred route between
Canberra and SA. iGo wouldn't chart a route from home to Maree as it is 'isolated', Navman would. Lets be honest, I didn't need a GPS to tell me which road to use from
Hawker to Maree. It is also surprisingly accurate in it's estimates of my arrival time (I mean it's original estimates, naturally the estimate gets better as you get closer ;-)
It doesn't give the traffic updates that Navman does, but they were mostly wrong and irritating anyway, so losing those is a plus. Important things like current speed are easy to read.
Like being able to select Camps 6 sites using iGo. That works
well - it will navigate you right to the place without needing to find and input addresses etc.
Always use it plugged in, so no idea what battery life is like.
Use either iGO or OziExplorer depending on what I am doing. Will swap between them from time to time to check on things like arrival times - yes that can be slow, but the vehicle can keep moving while the navi pushes buttons, so it isn't a nuisance.
Also like that it is nice and rugged, so it stays put on the windscreen when you touch it too hard on a bumpy track.
Biggest downside for me is that some supplied maps don't have the (bitumen) roads I am using on them in OziExplorer mode - that happened a few times around
Mildura area for some reason. The roads always reappeared before we needed to make decisions to turn, so it was mostly amusing. That actually has nothing to do with the device - it is a problem with the maps.
Ozi Explorer on a tablet or mini laptop might be a cheaper way to go, and may have extra advantages, but you need to be willing to put in the research and faffing around to get that set up. My dash does not make mounting stuff easy, either. This time around I am happy enough to just be able to plug in 'Nagivator' (as we call it) and have it work. Time poor.
The Navman hasn't been used in months, and is due to be sent off to parents so they can use it.
468120
