Friday, Nov 11, 2011 at 20:44
Great
I believe what you should do is look at the following tracks. First is the
CREB track which starts at the
Daintree Village. But I suggest that you avoid it if it is wet. Lots of clay covered hills that make you think you are driving on ice.
There are three other tracks that you should visit. The OTL as you have already identified. I would add Frenchman's Track and as a good full day drive over 150Kms the Starckie Track. Frenchman's is quite
well traversed so if you break something you should be fine. The Starcke does not get a lot of traffic but it is an easy drive if taken carefully and not rushed. Just like travelling across a station paddocks. Take it easy and you will be fine. Lots of twisty bits through the savannah bush and some
washouts to look forward to. No doubt there are others. But that's all the tracks we had time for. We broke a shockie on the Starcke so you may want to put a spare in.
Now the vehicle. Being on your own you should do a few things. I would start by installing better shocks and a
snorkel and
UHF radio. There is only one track where you may need extra HF or Sat comms and that is the Starcke.
Fuel and
water are available at most
places so you should n'e have to carry more then three days
water. You shouldn't need a bullbar or winch. Just don't run into any animals. I do not think that you need lifts etc. But make sure the tyres are good. Muddies came in handy for us because we stuck a bit of rain. Didn't need the winch. Only used it to extract others. Put some maxtraks in.
A fire extinguisher is a must. I gather a fist aid kit is in already. You can work out the personal food and clothing stuff.
Throw in some good old fencing wire. I would also add a stiff bit of metal rod to remove the stuff that collects under the car. That is where fires can start.
Spares? Put a set of belts in. Do NOT BUY them. Use the set from the next service. Sometimes the purchased ones won't fit because maybe a previous owner (or you) made some mods. Possibly the alternator was changed or mounted in a different spot etc. A spare air cleaner wouldn't hurt either. One spare and a puncture repair kit should be fine. You can throw in an inner tube if you wish. Get a 12V pump. Either in a case or mounted, maybe in the engine bay.
There really isn't a lot to do. You can do heaps more but it is not necessary. Its your wallet. We were fully decked out but that's for future CSG and the like solo desert trips.
Is that enough for the moment?
744214
