Front Wheel Drive , Versus Rear wheel drive, for small vehicles?.
Submitted: Thursday, Dec 08, 2011 at 20:33
Axle
Over the last two weeks i've travelled the same narrow twisting road going to work each day and have wittnessed three small cars that have shot over a bank, hit a tree, and one that did a 360' on a bend and took out another vehicle.... Ok its been wet, most of the time and i think speed to the conditions may be a major facter, But there all been little cars which made me think, ...Very light cars on the rear end!, front wheel drive with very punchy little donks, does the rear end break loose easier at speed on a wet road with front wheel drive over rear wheel drive?
Cheers Axle.
Reply By: Rockape - Thursday, Dec 08, 2011 at 20:48
Axle,
Over many years driving my very, very fast 2 door Hyundai excel sportz Ha. Ha.
This is what i have experienced. Although the little vehicle is mostly only driven on the highway I have found in heavy rain with
water on the road the front
wheels break traction and spin even at 100 kph. You can feel the thump through the transmission as the
wheels regain traction.
It is a little disconcerting when it happens in a bend and all I do is lock my arms and back off a little until traction is regained.
I have never had any problems otherwise, except when overtaking and waiting for the turbo to kick in. Damn!!!! then I remember it hasn't got a turbo.
RA.
471998
Follow Up By: Axle - Thursday, Dec 08, 2011 at 20:58
Hi RockApe,...
Well maybe these Dudes had Turbo"s ..Or Forgot to lock their arms and back off....LOL.
Cheers Axle.
746769
Reply By: Sir Kev & Darkie - Thursday, Dec 08, 2011 at 20:52
Axle,
I drive an Aurion (front wheel drive) for work on all road surfaces (some which shouldn't be driven on in such a low clearance vehicle) and I find that the front wheel drive once one is used to driving it, is very good on all road surfaces.
Loose gravel is where it beats a rear wheel drive as the front end drive to where you point it and the back end just gets pulled back into line.
I found that if the back end starts to lose shape then keep the right foot planted till it straightens and then gently back off.
Cheers Kev
| Russell Coight:
472000
Follow Up By: Axle - Thursday, Dec 08, 2011 at 21:03
Fair Enough Kev,.. I personally have not owned a front wheel drive vehicle only.
So interesting!
Cheers Axle.
746770
Follow Up By: Kimba10 - Thursday, Dec 08, 2011 at 22:47
Hi Kev how good do those Aurion's go eh ?? Go like a dog shot the rear end. I have driven a few of them including the TRD version, they are lethal and the power is unbelievable especailly in front wheel drive. One question I ask, have you ever had the traction control cut in ?? I have driven 3 of these things and been able to light them up in first and second (auto box, dont think they come in manual anyway) and not once has traction or stability cut in, just keep on wheel spinning. Curious to know if you have had it intervene on you.... PS I dont drive like that all the time was just having a bit of fun when we were test driving them (company cars from work). Wife and I actually looked at and drove the TRD version, WOW !! I have driven V8's, owned 1000cc bikes, turbo'd cars and this TRD was exciting, the constant power from the supercharger was unreal. Told the wife no, as neither of us would have a licence left...Awsome car.....Cheers Steve
746775
Follow Up By: Sir Kev & Darkie - Friday, Dec 09, 2011 at 08:42
Steve,
Traction control and Stability control do work :) Regularly cuts in on dirt and gravel roads.
I shouldn't have it much longer as the underbody is starting to fall apart due to the roads I travel on.
I have stuffed 3 sump pans, currently waiting for a new
fuel tank (as I hit a rock and caved half the
tank in), The plastic mini mud guards in front of the rear
wheels have been torn off.
Hopefully I will get a vehicle that will have some sort of ground clearance LOL
Cheers Kev
| Russell Coight:
746799
Reply By: Kimba10 - Thursday, Dec 08, 2011 at 22:55
Hi Axle, wifes current car is front wheel drive and as above it will wheel spin and carry on pulling up Mooney Mooney etc if its decent rain also Hawksbury if you keep the boot into and try to maintain 110k, you can see the tacho jumping around and this is with new good quality tyres. As far as cornering the only time Ive had issues is going into a sharp corner too quick and tapping the brakes which causes the rear of the car to step out especially under heavy braking. Other then that I enjoy the front wheel drive, pulls
well out of corners and at least you get some feed back through the steering as to wether your gassing it to much or not. But yes extremely light in the rear end i think would contribute to the issue, but like any of these incedents I put it down to driver error, going in too hard, braking hard mid corner, wet roads, inexperience. My old man always told me, brake before the corner and accelerate out of it. Nearly put the bike on its side due to braking mid corner scared the crappers out of me, never did it again, I always remember what the old man said...........
472013
Reply By: gbc - Friday, Dec 09, 2011 at 06:22
I wouldn't say the rear of a front wheel drive breaks out quicker than a rear wheel drive car. I'm guessing what you're watching is lift off oversteer which is an issue in both front and all wheel drives. Once committed to a corner in a front driver in low traction conditions it is suicidal to back off half way through. Most wrx's you see wrapped around phone poles have done the same.
472027
Reply By: Ozhumvee - Friday, Dec 09, 2011 at 08:46
As a matter of interest and if you have the inclination and a large 4wd like a Landcruiser or Patrol remove the rear tailshaft and take it for a drive in H4, the front drive foibles are amplified to an extent that it is scary, torque steer is lane changing stuff and braking can be frightening.
I always remember driving a 47 troopy back to
Sydney from Albury after a trip when the rear pinion bearing went. Removed the rear axles and rear tailshaft and came home in H4 in the rain with the campertrailer on the back. Every gearchange resulted in a huge step sideways, braking was dangerous on an uneven surface and accelerator application needed to be very careful even with the puny output of the old 2H diesel.
As the others have posted front wheel drive cars can be touchy on slick surfaces and backing off mid corner can be an undie changing exercise.
Anyone ever driven one of those early Starion turbo's?
472044
Follow Up By: Kimba10 - Friday, Dec 09, 2011 at 10:20
Anyone ever driven one of those early Starion turbo's?.........sure did, the talk steer in those things was shocking, would try and rip the bloody steering wheel out of your hand every time when the turbo cut in and if mid cornering and planted it, it would head straight for the gutter. They went hard... Fun to drive but.........
746808
Follow Up By: get outmore - Friday, Dec 09, 2011 at 10:28
Broke the rear studs in my cruiser and had to drive it a couple of 00 ks fwd was surprisingly good but round town in the wet it needed babying and holds would have me backing right off to stop it spinning to the top
746810
Follow Up By: nsngood - Friday, Dec 09, 2011 at 12:18
The Starions, being rear wheel drive would allways kick out the rear end if not treated right. The boss use to modify these quite heavily by installing the 2.6
astron motor and better turbo and
fuel management systems etc. There are still a few of these floating around that havent been killed yet. also Harry Dutton was quite fond of these things from memory.
746827
Follow Up By: Kimba10 - Friday, Dec 09, 2011 at 16:24
Sorry Ozhumvee, it was the ET Pulsar I was thinking of not the starion. I have driven the Starion (was
bright yellow for memory) but dont really remeber how it went, but definately remember the pulsar, was light blue and when you planted the boot mid corner it would try and rip the wheel out your hand trying to staighten itself, was shocking..........
746856
Follow Up By: Kimba10 - Friday, Dec 09, 2011 at 16:41
Starion Above
Pulsar Below
746859
Reply By: Pebble - Friday, Dec 09, 2011 at 10:00
I would say that front wheel drive vs rear wheel drive just take different driving methods, especially when you're bordering on losing control (on gravel etc).
The fourby's we've had are rear wheel drive, the small car (old Lancer) is front wheel drive. It's just different how the lancer pulls through corners (have about 3km of gravel to our house) whereas in a rear wheel car that has a light rear end I think you'd be prone to start wanting to drift earlier.
But in having said that perhaps a drift is easier to control in a rwd car compared to fwd????
From my personal experiencel it's not comparing apples with apples, the old Hilux was very drifty on gravel corners compared to the small fwd drive cars, but it was easy to tell when it was wanting to drift and then back off. In a front wheel drive I'd tend to think once the back end starts to drift it would be harder to correct?
I'm thinking that if you combine modern tech (like traction control) and front wheel drive, you can go faster around corners so maybe when people do lose control it's a point where it's harder to recover even if they do know how?
472052
Reply By: Bushranger1 - Friday, Dec 09, 2011 at 10:34
G'Day Axle,
It's all a matter of lack of driving skills & people not knowing how to get a good feel for the cars handling characteristics!
In my early years I had a Mini Cooper which was front wheel drive & I could do some very finely controlled slides without coming to grief. I won't tell you how quick I could get over the Black Spur mountain range here in Vic.
I think that drivers should be made to do an advanced driving skills at a
young age as I did. It has helped me avoid many incidents over the years.
Stu
472057
Follow Up By: Bushranger1 - Friday, Dec 09, 2011 at 10:37
I forgot to add that back then there was no such thing as ABS or Stability control. The skill was all up to the driver which unfortunatly is a skill many people do not posses these days.
746812
Follow Up By: pop2jocem - Friday, Dec 09, 2011 at 21:34
Well said Stu, a mate of
mine (when we were know it all
young lads..lol) also had a Mini Cooper. He wanted the Cooper S really but the budget didn't stretch that far.
None of the modern aids like ABS, Active stability or traction control then. A quick flick of opposite lock and apply the hand brake to get the back end to step out and then stand on the loud pedal to pull you through the corner.
Very valid point about advanced
driver training, a lot of drivers get their ability mixed up with there ambitions after all isn't the car supposed to make up for their shortfalls in driver smarts and even if it gets so far out of shape that they collect some other poor unfortunate or a part of the scenery
well thats what crumple zones and 20 air bags are for.............right?????
What was that dopey driving instructor banging on about......."drive to the conditions"....what the hell does that mean.
Pop
746888
Reply By: Member - Royce- Friday, Dec 09, 2011 at 13:51
My understanding is that front wheel drive is actually better in poor grip cornering. The tail can drift out easier, but the front
wheels keep the car steering and moving around
the bend.
Meanwhile, a rear wheel drive loosing grip, also loses traction on the drive
wheels and therefore has less control.
Just 'what I'd heard', but really it's all about the driver driving to the conditions and experience isn't it?
472069
