12 volt and solar
I want to set up a 12 volt shower, separate to vehicle, can anyone tell me what size solar panel I would need to charge the 12 volt battery to just run the shower? Could I use an old 12 volt battery that isn't strong enough to start a car now?
Also what size solar panel to charge battery that I need to run a waeco fridge?
Hope someone can assist. That would be great.
First time, still learning. Hope I can be of assistance to other members at a later date.
Reply By: Notso - Wednesday, Dec 14, 2011 at 16:26
To run a solar shower you only need a very small battery and to carry a heavy and inefficient old car battery would be a waste of space. You could even rig up an extension lead and run it off the cigarette lighter in the car.
If you really want to carry an extra battery you'd be better off getting a small sealed lead acid battery say 7 or 8 AH, or a Jump Starter unit, which would potentially be useful for other things. A 20 or 30 watt solar panel would be plenty for that sort of thing.
For the Waeco you'd need to decide if it's going to be a fridge or freezer and what size it will be as it'll use lots more power as a freezer and the bigger the fridge the more power as well.
AnswerID: 472527
Reply By: Sand Man (SA) - Wednesday, Dec 14, 2011 at 20:32
If you are considering running a compressor fridge, you will need a battery in the order of 75-100Ah and preferably of AGM construction. An AGM battery is safe to use anywhere within a vehicle and can be tipped over or even operated on it's side without compromising safety or efficiency.
Although most of us set up the battery to enable charging from the vehicle alternator with an in-car charging kit which includes an isolator to protect the starting battery, a solar panel is a great addition to supply a charge to the battery when stationary at camp.
I found I could get a suitable charge back into the battery with a 40 watt panel (about 5 anps) in the few hours of daylight available, however a minimum of 80 watts is a better solution for greater flexibility, at a reasonable cost. I have since added another 40 watt panel to give me an 80 watt bi-fold panel which I have found to be adequate, however I don't use my fridge as a freezer.
Bill
AnswerID: 472544
Follow Up By: The Bantam - Thursday, Dec 15, 2011 at 12:07
NO battery is safe within a vehicle, and no battery should be charged or transported anything other than upright...this includes AGM
There is lots of misleading BS circulating about this, those who push the operate ay postition and in confined spaces are obvioulsy ignorant of the manufacturers specific restrictions and qualifications about operating sealed batteries other than upright, and in confined speces
Serioulsy dont get me started..I can quote chapter and verse on this matter from a variety of manufacturers.
As for maintaining any fridge on a continuous basis, you will need a hell of a lot more solar pannel than you think.
FollowupID: 747414
Follow Up By: pop2jocem - Thursday, Dec 15, 2011 at 13:42
Not sure where you get the bit about not mounting an AGM battery on it's side.
Mounting in a passenger cabin... yeah maybe not a good idea.
A brand of vehicle I was a dealer for came with an AGM side mounted. I queried the manufacturer about the battery mounting and was sent an info and MSD sheet from the battery manufacturer which clearly stated side mounting for their AGM WAS FINE.
Pop
FollowupID: 747422
Reply By: Member - John and Val - Wednesday, Dec 14, 2011 at 21:10
Hi Michelle,
Welcome aboard!
As already suggested, the shower doesn't need much power, so could be plugged into the car cigarette lighter through a reasonably long lead. (Or the fridge battery.) Certainly a tired car battery would be fine, though, again I'd agree with other posters, it's inconveniently heavy and not really needed if you can plug into the car. The other very big downside of vehicle batteries is that they contain lots of sulphuric acid which is dangerous corrosive stuff. If you do need a battery for the shower, suggest a small sealed type.
The fridge - power requirements depend on size and usage patterns. Fridges fall roughly into two groups - the small ones (less than about 60 litres) draw about half the power required by the larger ones. Obviously if you want them to run freezing cold they'll need much more power than if they just need to keep the milk cool. Opening the fridge frequently, especially in hot weather will also have a big impact on power requirements.
How much solar to power the battery that powers the fridge? Very roughly, for a small (say 40 litre) fridge you'll need a 100 amphour deep cycle battery (preferably an AGM type where the acid problem isn't an issue) and this will have the capacity to run the fridge for 2 or 3 days. To replace all the power used by the fridge in 24 hours you will need at least an 80 watt solar panel and a sunny day.
For a far more thorough treatment of this please see the blog Electricity for Camping where you'll find a lot of stuff that should be helpful in setting up your rig.
J and V
- Albert Einstein
AnswerID: 472546
Reply By: The Bantam - Thursday, Dec 15, 2011 at 12:17
Lets start at the beginning, its a very nice place to start.
Unless you are going away for more than 2 or 3 days, solar is pretty pointless.
If you chill your fridge down properly first, keep it in a cool place and maintain good fridge discipline, you should be able to run a small 30-40 liter fridge AS a fridge for 2 or 3 days off a decent N70 battery that is in good condition, without recharge.
If the fridge is in the vehicle and you are driving that vehicle for at least 2 hours a day, you should be able to run such a fridge indefinitely off a properly rigged second battery.
As for the electric shower......work out the consumption...you will probaly un it off just about anything
As for running the fridge off solar for longer periods, a minimum of an 80 watt pannel to be of any advantage at all and at least 160 watts for reliable continuous operation.
search this and other forums there is plenty to read on this subject.
AnswerID: 472575
Reply By: Michelle Gee - Thursday, Dec 15, 2011 at 14:35
Thank you for your assistance.
We are in the process of setting up a semi permanent camp for campers so transport of battery will not be a problem. Just keeping it charged without a vehicle on site would be more of an advantage.
So camp shower and toilet would be available on site and available for campers.
AnswerID: 472587
Reply By: The Bantam - Friday, Dec 16, 2011 at 09:45
NOW, if theis is a semi permanent site...that is a different game altogether.
Even more important to have adequate pannels to keep the batteries charged, and less of an issue about the size and weight of the batteries.
two 180 watt pannels and a 200AH deep cycle battery would be a good place to start...of course you will need a regulator for the solar pannels.
A basic 40 amp reguator would be a minimum, a maximum power point tracking regulator, would be better if you have the $$$
I'd steer away from using an old battery unless it was just for the shower and that was set up as a completly seperate system.
AnswerID: 472655
Follow Up By: The Bantam - Friday, Dec 16, 2011 at 09:49
If ya interested , Colin Rivers has written several good books on setting up solar, different ones for different markets.
Ther are pretty damn good and reasonably easy to read.
Colin has a background in electronics and has been living a solar powered lifestyle since before it was trendy.
FollowupID: 747495
