Thursday, Dec 27, 2007 at 16:16
Cram,
All the brand name radios are good, so it gets down to what your budget is, specials that may be on at the time you are buying and of course, your expectations of a
UHF radio.
In itself, the humble
UHF radio is still the single most useful accessory to add to your vehicle. It may not be practical for emergency remote contact, where a HF set or satellite phone comes into it own, but in convoy use, (anywhere from 2 vehicles upwards) or communicating with anyone within a 20 kilometer range (excluding use of the repeater channels) you cannot do better.
A couple of years ago, a convoy of three vehicles we were in was heading up a very slippery
Birdsville Track, having just left Mungerannie. The lead vehicle was not towing anything whilst the other two of us had camper trailers.
We had no idea how far the "slippery bit" went for and whether it got worse or better, but as we were communicating between ourselves, another traveller heading down the Track towards us was able to give us an update on conditions at his end.
In this way we were able to make an assessment that the zigzagging "dance" we were performing was only for a relatively short distance and this made the difference on whether to proceed, or turn back.
There are many circumstances where "local" communication is all that is needed and you just cannot do this any better, or cheaper, than with a UHF transceiver. Travelling over
sand dune country is another practical use for the UHF set and the occasional use of the Truckies' channel to inform them you intend to overtake, or advising them to overtake you provides a safer way to travel.
If you keep in mind that a 20 kilometer range is about the limit for a UHF set, plus the use of the repeater channels in designated areas can be a means of getting possible help if necessary, then you can decide if you need additional facilities. One of these may be a cheaper handheld which you can use when ranging away from your vehicle, but still have the means of communication with someone still in the vehicle.
I rarely travel in remote areas alone, so if one vehicle in our convoy breaks down, the other vehicle can seek help. I also have an EPIRB should I require emergency assistance.
That's it. I have no justification at this stage, to invest in either a
HF radio, or a satellite phone.
If and when circumstances change, I will re-access our requirements and hire, or purchase, additional equipment at that time.
Hope this is of some value to you.
278615
